  1. Feb 1, 2016 at 4:25 PM
    puddle
    puddle Well-Known Member
    Kris
    ID
    2020 TRD OR
    Cool dealer placard
    Put on OEM inner and outer tie-rod ends, and lower ball joints. Total Chaos upper control arms. I think i'm done for at least a week or two.
  2. Feb 1, 2016 at 4:49 PM
    malburg114
    malburg114 Well-Known Member
    Las Vegas, NV
    2001 Toyota Tacoma TRD
    Did some of the Logandale Trails the other weekend. Whered you guys go by in mesquite?
  3. Feb 1, 2016 at 4:58 PM
    WheelInTheSky
    WheelInTheSky Ramblin' Man
    G
    Jackson Hole
    02 XtraCab 4x4 SR5-speed
    Well I lucked out, looks like cranking the nut on wayyyyy too fucking tight solved the problem. No need to buy line wrenches or hard lines now!:humble:
  4. Feb 1, 2016 at 5:00 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    Did an oil change in the middle of doing the timing belt, much easier to get to the oil filter with the radiator, belts, and timing cover off.
    Switched to full synthetic finally, ended up with valvoline full syn, been running the valoline semi-syn so I think i'l be happy with this.
  5. Feb 1, 2016 at 5:07 PM
    ToyoTaco02
    ToyoTaco02 Well-Known Member
    Scott
    Decatur,IL
    02 PreRunner DC 2.7L
    OME 881 1/4" top plate spacer OME Dakars OME Nitrochargers Light Racing UCA
    What shackles are these? How much lift did they provide?
  6. Feb 1, 2016 at 5:11 PM
    yota yoter
    yota yoter Well-Known Member
    Jordan
    Wet Side Oregon
    02' Imperial Jade Mica, V6, TRD 4X4
    Custom Real Tree Camo Interior.
  7. Feb 1, 2016 at 8:49 PM
    tbr3345
    tbr3345 Well-Known Member
    Tom
    Sacramento, CA
    2010 TRD Sport DBL Cab Silver Streak Mica
    Installed a new Radiator in my 02 Double Cab. Didn't read the repair manual completely so I didn't know about removing the Grille to get at the four bolt on radiator support. Then installed new radiator but couldn't the the fan shroud to fit. New Radiat or was to short by 6" although the Part number was the one for the VIN took it out and back NAPA along with old radiator. took a little work but they found the correct one. Took one hour after I got back to intall it and fill it with coolant. While it was warming up cleaned up the garage and put everything away. Not bad for a 73 year old who hasn't really worked on a car since he retired other than a couple of brake jobs and oil changes. It took a little bit for things like using a ratchet in tight places and getting the old hand to work. We will see how good I am Friday when I tackle replacing the valve cover gaskets and Spark Plugs and wires. Project after that in new tires and windshield. Then the cosmetic stuff like either painting or Plasitic Diping the fender flares and front valance I must say I did enjoy it Got get it ready for Road Trip to Idaho in March to see the Grandkids. Oh forgot gotta do a brake job front and rear and probable replace the steering rack bushing, sway bar bushing and new Shocks. The truck has a 152k and has had very little done to it it's been almost bullet proof. After my son used this past year as work truck after his divorce it needs a little TLC He didn't tear it up or damage it kept it fairly clean and now new scratches or dents. Like to find a shell for it so the dogs can be in the bed. This is a great site and have learned a bunch of stuff and renewed my interest in working on my cars.
    Tom
  8. Feb 1, 2016 at 9:07 PM
    ervmcd
    ervmcd Well-Known Member
    Evan
    SLC, UT
    2014 TRD Off-Road DCSB
    The tunnels actually run under the freeway, just a few miles north of Mesquite. The other tight trails were on the west end of the city. Not sure if there were any names but they were a blast to run
    malburg114[QUOTED] likes this.
  9. Feb 1, 2016 at 9:49 PM
    alphabravo
    alphabravo Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    I can't remember the last time I saw a first gen single cab.
  10. Feb 1, 2016 at 9:50 PM
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    6" to short... Meaning in height wise? Because the radiator I have is shorter then my original and it works fine. I'm even running it with the 3.4. It helps with clearance in the front for the skids I have. Just letting you know would would of been fine with the shorter one. But good job either way :thumbsup:
  11. Feb 2, 2016 at 4:32 AM
    CC HUNTS
    CC HUNTS New Member
    Cale
    98 Tacoma 4x4 2.7L
    Reworked frame to remove rust, 2 1/2" flow master exhaust from cab back. 31-10.50-r15
    image.jpg image.jpgSo here is what I ended up with on the rear bumper. I may move the hitch in the future but for now it doesn't get in my way. I don't rock crawl or do any serious wheeling in this truck as much as get firewood and drive it off road while hunting and fishing so I'm not needing the clearance some like. Thanks for all the tips. After looking at this vs my first design I'm happy.
  12. Feb 2, 2016 at 4:51 AM
    imcafee195
    imcafee195 Well-Known Member
    Isaiah
    Chattanooga TN
    98 tacoma on 35s
    Lift Raptor lined
    Is anybody running the method double standard 15x10?
  13. Feb 2, 2016 at 4:59 AM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    There are different height radiators, the standard auto trans radiator hands waaaaay down. I re mounted mine about 1.5" higher to add a bit of clearance and still have the same cooling ability.
    SilverGhost[QUOTED] likes this.
  14. Feb 2, 2016 at 6:18 AM
    CelsisTaco
    CelsisTaco Well-Known Member
    Anthony
    Des Monies, IA
    2011 DCSB
    2 inch lift. LED fog lights (Cali fab) Alpine head unit. Kicker door speakers. Skar subwoofer.
    Thanks i think? :)
  15. Feb 2, 2016 at 6:29 AM
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    These? They are the double standard but I don't know if they are 15x10.
  16. Feb 2, 2016 at 6:30 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I see one every day...of course I walk right past it to get to my truck.
    Wife has a 1998.
  17. Feb 2, 2016 at 8:09 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Single cabs are rare, therefore cool. My neighbor has a 'step-side' version. Really cool.
  18. Feb 2, 2016 at 10:09 AM
    TheSaint
    TheSaint Regular Guy
    Mark
    Prescott, Arizona
    White 2003 4x4 TRD DC
    OME lift, 265/75s, pickup shell, couple of dents.
    This weekend I touched up my hood. The guy I bought the truck from ran a paving company, I suspect it spent a lot of time driving behind dump trucks, because the front of the hood had a bazillion little chips taken out of it. After about half a day with the touchup paint and clear coat, and a lot of wet sanding and rubbing compound it now looks...better. If you look at it from the side you can still see where the gloss is off and the texture is uneven, but just walking by in the parking lot you probably wouldn't even notice. Which is all I was shooting for. As I said to my wife, it no longer looks like it is covered in zits, now it just looks like it has acne scars.
    I got my weatherpack connector kit from Amazon yesterday, so tonight I'm going to work on installing that on the electrical connections between the shell and the truck (right now it's just crimped together). The parts for the valve cover gaskets should be here on Thursday, so I'll be doing that on Saturday.
    Speedytech7 likes this.
  19. Feb 2, 2016 at 10:28 AM
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    It reminds me of my old 88. I miss that truck :)
    CelsisTaco[QUOTED] likes this.
  20. Feb 2, 2016 at 10:30 AM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    you'd cream your pants if you saw scubas.
