  1. Feb 7, 2016 at 7:14 PM
    JBTacoma
    JBTacoma Well-Known Member
    Jeff
    Cullman Alabama
    2000 SR5, 2003 Double Cab and a Suzuki Samurai
    Does yours have two connectors
  2. Feb 7, 2016 at 7:33 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
  3. Feb 7, 2016 at 7:43 PM
    JBTacoma
    Jeff
    Cullman Alabama
    If the two connectors is your issue, one of them goes to a low fluid light, you don't really need it.
  4. Feb 7, 2016 at 8:13 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Yep. Just cut the low fluid sensor off. I never once had it come on anyways. Also, I ended up taking a sawsall to my PVC POS after it got in the way one too many times. Now have a 1/2 gallon bottle in front of the airbox. Has been working well.
    tibblits920 and bayareataco like this.
  5. Feb 7, 2016 at 8:37 PM
    LogCabins
    LogCabins Well-Known Member
    Robert
    Oahu
    99 SR5 3.4L 4WD
    Finally got the sliders welded on by a fellow TW friend @hacklerjason
  6. Feb 7, 2016 at 9:06 PM
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    2002 Toyota Tacoma 4WD
    Check Build
    What brand?
  7. Feb 7, 2016 at 10:44 PM
    LogCabins
    Robert
    Oahu
    99 SR5 3.4L 4WD
    AllPro
  8. Feb 7, 2016 at 11:10 PM
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    Check Build
    Nice... I have those just neeto burn them in.. Any other pics of them on your rig?
  9. Feb 8, 2016 at 2:14 AM
    glass guy
    glass guy Active Member
    scott
    2004 tacoma trd
  10. Feb 8, 2016 at 2:17 AM
    glass guy
    scott
    2004 tacoma trd
    also from nh stuck in fla, ive been looking for mudd flaps for mine you interested in getting rid of them.
  11. Feb 8, 2016 at 6:12 AM
    Toyo129
    Toyo129 Member
    Southern Indiana
    1998 Tacoma pre runner
    I drove to school
  12. Feb 8, 2016 at 7:49 AM
    Kneeboarder1025
    Kneeboarder1025 member-in-training
    Walt
    Broken Arrow, OK
    '03 Forester
    Used it to move some logs around.
    JKU3000 likes this.
  13. Feb 8, 2016 at 8:59 AM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Sweet! Thanks gents :)
  14. Feb 8, 2016 at 11:27 AM
    bowyer2002
    bowyer2002 always tinkering
    NE Missouri
    01 Taco SR5 D-cab 4WD
    OME 882s, OME shocks all around and OME Dakar spring packs, ARB, Warn 8000, ARE shell, Custom rear bumper w/ reciever, 5-235/80R17 Cooper Discoverer ST MAXX on FJ wheels, grey wire mod, Hi-Lift, Hellas, Red-Line hood lifters, Scion radio, sliders, Safari snorkel & LED Ditch lights on CBI mounts.
    I hope you were using the winch to move the logs and not reverse.
  15. Feb 8, 2016 at 11:38 AM
    Kneeboarder1025
    Walt
    Broken Arrow, OK
    '03 Forester
    Used the winch. I've seen the front diff grenade in two different jeeps pulling in reverse. Don't plan on making that mistake ( Though I'm sure I'll find other equally expensive mistakes to make)
  16. Feb 8, 2016 at 11:38 AM
    Nebrasker
    Nebrasker Member
    Scott
    2002 TRD Double Cab
    Drove a couple hours straight today and haven't put a picture up on here yet. Coming up on 90k and considering taking it to toyota for all the scheduled maintenance. Want the frame inspected and what not before I put some money into the suspension and new tires.
    JKU3000 and malburg114 like this.
  17. Feb 8, 2016 at 11:56 AM
    bowyer2002
    NE Missouri
    Nebrasker - get the frame inspected and then fall down the rabbit hole of modifications!
    Have your Visa, tools and friends ready for installs!
    Welcome to TW!
  18. Feb 8, 2016 at 12:17 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Never knew that was a risk. Good to know.
  19. Feb 8, 2016 at 12:23 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I feel sorta bad, my truck was so dang caked with mud the car wash guy checked in on me and wanted to help.
    Some places had mud around 4 in thick caked on, I got it mostly clean but it isn't spring yet so it doesn't get its yearly wash yet.
  20. Feb 8, 2016 at 1:39 PM
    Wadar
    Wadar Not Well Know, But Shows Up From Time to Time.
    Wade
    Western Slope, Colorado
    ‘02 XC TRD-OR, & ‘20 DCSB TRD-OR
    A few.
    It may be a bit late for a reply, but I used a 2" sanitary tee for my 90*. I put an end cap in the bottom of the sanitary tee for the low fluid sensor, and used a 1-3/8" hole saw to drill for the fitting/seal. Off the curved 90* of the sanitary tee I used a 2" tee with a 1/2" female opening trimmed short for the pump fitting/seal. Then added the rest of the 2" pvc beyond that for the rest of the reservoir. Above the sanitary tee I added two 45* elbows to move the vertical tube over the frame and away from the fan shroud.
    Fluid level sensor:
    2" tee w/ 1/2" female for pump
    Top 45*
    View from above
    Sorry the pics aren't better.
