  1. Feb 9, 2016 at 11:04 PM
    SafetyDang
    SafetyDang get your facts straight
    Dang
    Anaheim, CA
    DC with 4x4 & MT Conversion
    Swapped to Manual Trans & 4x4
    Trail gear or ruff stuff. Not sure.
    TacoVio[QUOTED] and alphabravo like this.
  2. Feb 9, 2016 at 11:27 PM
    alphabravo
    alphabravo Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    Yeah. A new spring pack fixed my clunk which I though was in the tranny but turned out to be axle wrap. I still have a rattle in the front end that is driving me crazy. It sounds like it is in the coilovers. every little slow speed bump causes a rattle.
    I'm thinking though that you could still be axle wrapping since I believe most of the load on the spring comes from the braking and not the driveline. After the stop and the truck rocks back then the spring unloads and clunks. Just a thought.
  3. Feb 9, 2016 at 11:35 PM
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Yay. It's SafetyDang.
    I remember your 5spd DC project was one of the first I saw when I got my Tacoma. Some day...either that or I will massacre a poor 5 spd Xtra and stick my cab on it.
  4. Feb 9, 2016 at 11:54 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    My leafs are pretty beefy, also it does it just rolling without any throttle or braking and tranny in neutral. So IDK, I'm not too worried, truck is a symphony of noises, I basically have to have the radio at deafening levels to avoid all the noises. Sound deadening is moving up the list. Everything else is going to be changed soon, I have new axle gears to put in, I'm growing tired of my 5100s and Eibachs so I'm going to launch them as well, will redo the front diff bushings as well. Eventually the noise will just one day disappear. :annoyed:
  5. Feb 9, 2016 at 11:56 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    I just ended up replacing my whole drive shaft since it was dented, needed the carrier bearing replaced, and maybe a u-joint. Absolutely no more play, axle wrap feel, or clunk anymore haha
    Speedytech7[QUOTED] likes this.
  6. Feb 9, 2016 at 11:59 PM
    Speedytech7
    I think I may have all the u-joints/carrier bearing done soon, mine is still in otherwise good shape. But I have definite play in the diff I can turn the drive shaft with the wheels on the ground and make it clunk, surprisingly it doesn't make noise on the road (except possibly the clunk I hear occasionally).
  7. Feb 10, 2016 at 5:19 AM
    Trim taco
    Trim taco Just one more stupid question
    Bourbon capital of the world
    Was: 96 SR5 5MT Is: 19 OR 6MT
    Bunch 'o random stuff
    Had some fun in Windrock this past weekend.
  8. Feb 10, 2016 at 5:43 AM
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    No I haven't. Sorry guys.
  9. Feb 10, 2016 at 6:37 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
  10. Feb 10, 2016 at 6:51 AM
    Scenekyd
    Scenekyd Not much of a member
    Jay
    Hendersonville, NC
    2015 Ford F-250, 2016 4runner Trail
    Been carpetless since Christmas :cool: pulled it out then put the seats back in.
    JKU3000 likes this.
  11. Feb 10, 2016 at 7:15 AM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    I know a lot of people have used the Napa eclipse calipers. I got a good deal on reman units from powerstop with no core, so I'll be trying those. Really, I'm not an expert on it.
    As of now, planning on trying Hawk LTS pads this go around with Centric premium rotors. I think my EBC sport rotors I have now attract dust and dirt and shit in the dimples and slots. So I'm not convinced that's an upgrade for someone who wheels a lot. Also, not going back to EBC greenstuff pads. Performance was excellent, life was terrible. Hoping to find an good compromise.
    tibblits920 likes this.
  12. Feb 10, 2016 at 7:27 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Do these just go over the carpet or do you pull the carpet and put this in as a replacement?
  13. Feb 10, 2016 at 7:31 AM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    it replaces the carpet. You need to trim to fit--it comes big around door sills and front/back but the trans hump and what not is molded in.
  14. Feb 10, 2016 at 7:34 AM
    JKO1998
    Utah
    That's really tempting. Know anyone that has used it?
  15. Feb 10, 2016 at 7:39 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    If I did get it I would seal the bottom and make the drain holes come up through the vinyl so you can just drain it this way instead of needing to pull the vinyl if you submarine.
    SilverGhost likes this.
  16. Feb 10, 2016 at 8:01 AM
    TacoVio
    TacoVio Well-Known Member
    Kolton
    CO/WY
    R.I.P '04 Roy Super White ^^
    '00 Imperial Jade Flatty / '14 Spruce Mica, 6MT, Sick
    Yeah I was thinking of going hawk lts because I heard the greenstuff just wear out way too fast. I will try to find some from powerstop!
  17. Feb 10, 2016 at 9:06 AM
    TacoVio
    Kolton
    CO/WY
    Cracked my damn radiator on the side of the top!!! Replacements? Will my radiator from my totaled 04 work?
  18. Feb 10, 2016 at 9:07 AM
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    If your talking about a vinyl floor check my build.
  19. Feb 10, 2016 at 9:35 AM
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    It should. My 2.7 worked on the 3.4
  20. Feb 10, 2016 at 9:38 AM
    TacoVio
    Kolton
    CO/WY
    Think? I have a 2000 now?
