  1. Feb 15, 2016 at 1:21 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    I'd probably go with toytec but my hours got cut, only 6 hours a week, so my budget get shot in the eye with a thumb tack. Probably shouldn't do anything but my suspension needs attention.
  2. Feb 15, 2016 at 1:35 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Quiet a bit faster. I refilled my 33x12.5r15s with a ARb and my 35x12.5r15 with a twin. The twin filled the 35'' tire about a minute faster id guess. Quiet a bit faster then the normal one.
    Is it worth the money? idk. Depends on usage i think. Id run the twin if i where to get an OBA compressor. Which ive considered. But just too expensive.
  3. Feb 15, 2016 at 3:09 PM
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
  4. Feb 15, 2016 at 3:27 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I considered those tires until I found they don't come in any 15" sizes. Your truck looks amazing. A great stance. Are you running a body lift too?
    I love my twin. The CKMTA is significantly faster than the CKMA. The twin is essentially 2 CKMAs put together into a single unit.
    The twin is rated at 100% duty cycle. Mine has never reached any limit. I've aired up 3 rigs in a row with it, on a hot summer day, with maybe the slightest slowdown on the 11th and 12th tires. It is stout and faster than anything out their except a CO2 setup.
  5. Feb 15, 2016 at 3:32 PM
    because_wumbo-truck
    because_wumbo-truck TTC#036 1st Degenerate Urban Off-Roader
    Jon
    Houston, Texas
    2006 Gordita Blanca V8 4x4 aka "Penelope"
    Sliders and bumper, DDI injectors, flowmaster 40
  6. Feb 15, 2016 at 3:40 PM
    Tacomang
    Tacomang Well-Known Member
    Norcal
    Trd Taco
    Im considering selling my current setup has 20k mostly commute miles. Bilstein coil with all pro spring and 5125s in the rear. Maybe sell the dakars too.
  7. Feb 15, 2016 at 3:41 PM
    JKO1998
    Utah
    For how much and where are you located?
  8. Feb 15, 2016 at 3:48 PM
    Tacomang
    Norcal
    Trd Taco
    Bought some lower ballsack joints from toyota, the right side was more than the left for some reason 290 bucks out the door both sides.
    Debating on replacing the uppers or just getting tc or camburg ucas with a uniball.
    tibblits920 likes this.
  9. Feb 15, 2016 at 3:49 PM
    Tacomang
    Norcal
    Trd Taco
    I can send you a pm, im located near sacramento ca
  10. Feb 15, 2016 at 3:49 PM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
  11. Feb 15, 2016 at 3:50 PM
    Tacomang
    Norcal
    Trd Taco
    Link por favor?
  12. Feb 15, 2016 at 3:50 PM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Check my edit ^^^^
  13. Feb 15, 2016 at 3:52 PM
    JKO1998
    Utah
    Too far I'll pass thank you
  14. Feb 15, 2016 at 3:52 PM
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    It was weird because the truck didn't want to start. I did buy gas this morning. I just removed the cap and put it back on and cleared the code. The truck started right back up with no problem. I also check the lines around the charcoal canister and in the engine compartment. everything looked good to go..... thanks for the link tho :thumbsup:
  15. Feb 15, 2016 at 4:13 PM
    Kotayota
    Kotayota Well-Known Member
    Sean
    Charleston, SC
    04 White DC
    Bilstein/Eibach combo, 1.5 rear shackles, 33/12.5/15 Duratracs wrapped around MT Classic IIIs, flowmaster 40, K&N intake, 4way pioneer speakers, mini d2s headlight retrofit, satoshi grill, interior leds
    I wanted to maybe go back to some chrome on my truck but was worried those aftermarket grills the chrome wouldn't be as "shiny"
  16. Feb 15, 2016 at 4:26 PM
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    Sorry bud. I never had that code. I wouldn't know what to do. Its just say random misfires. odd....
  17. Feb 15, 2016 at 6:40 PM
    YotaBoater
    YotaBoater Well-Known Member
    Bryant
    757
    02 TRD 4x4
    Thanks! Yes sir I got a 1" body lift
  18. Feb 15, 2016 at 6:45 PM
    Ice Horse
    Ice Horse Stalking horse
    Lauren
    Florida
    Two 1998’s and a 2025. All TRD Offroads.
    ADS Racing Shocks 2.5" Extended Travel Coilovers with Reservoirs, 3 inch All Pro rear suspension kit, factory E-locker, Trail Gear sliders and front stinger bumper, CBI Offroad rear tube bumper, XRC8 Winch, 33 inch BFG KM2's, 16 inch Ivan Stewart Wheels, Uniden CB radio, flip up license plate, white tail lights, LED front signals, Tundra front brake upgrade, new radio, rock lights, sub woofer, remote start, satoshi grille with Prius emblem, Rigid DOT/SAE Fog Lights, 12" Light Bar
    Any pics of your setup? I was looking at them both today and I'm not sure how I'd make the twin fit.
  19. Feb 15, 2016 at 7:49 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    Ordered TC cam tab gussets today, gonna start the teardown tomorrow if weather permits so I can get the alignment done and try to straighten the bumper.
    alphabravo likes this.
  20. Feb 15, 2016 at 7:49 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Do you have abs?
