  1. Feb 17, 2016 at 9:03 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    It's not that I'm too lazy it's just I want to get everything put on at once. It's my daily so it'd suck to have to wait for the shocks to get in and out everything back on.
  2. Feb 17, 2016 at 9:08 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Recommending proper shock lengths over the internet is hopeless. At the same time, 99% of people on here will never break down a leaf pack and measure, nor will they find it necessary. And there's no shock that will work perfectly for 0" of lift and 2.5" of lift.
    Most off the shelf shocks for 'lifted' applications will most likely be sufficient for most on here.
    Speedytech7 likes this.
  3. Feb 17, 2016 at 9:08 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Shocks can be done after everything else is on, takes like 15 mins to swap them and you can do it all on the ground with hand tools.
  4. Feb 17, 2016 at 9:11 PM
    JKO1998
    Utah
    So just ride around basically just one the springs? The shocks I have now wouldn't be any help after the AAL
  5. Feb 17, 2016 at 9:16 PM
    Speedytech7
    Obviously use your best judgement, but I did it for a bit when I first put my lift on. Leaf springs have a bit of natural damping because of the friction between them. There is always the chance that your shocks you have now will fit (albeit a bit over extended) for the couple days your new ones are in transit. If you do decide to measure your compression and droop make sure you have no shocks on for the measurement. Also make sure to measure from the center of the bottom shock mount to the center of the top shock mount. It is super easy to pick shocks once you have those numbers FOR BOTH SIDES.... MEASURE BOTH SIDES!
  6. Feb 17, 2016 at 9:16 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Dude, I don't get it. You ask for help, and when you get it you give reasons why that wont work for you. :facepalm:
    Listen to these guys, they have all learned the hard way and are trying to save you some coin and frustration.
  7. Feb 17, 2016 at 9:18 PM
    Speedytech7
    It's the only way I learn... :rofl:
  8. Feb 17, 2016 at 9:19 PM
    Wadar
    Wadar Not Well Know, But Shows Up From Time to Time.
    Wade
    Western Slope, Colorado
    ‘02 XC TRD-OR, & ‘20 DCSB TRD-OR
    A few.
  9. Feb 17, 2016 at 9:21 PM
    JKO1998
    Utah
    I just don't want to do anything wrong. Trying to be careful with what I buy. Sorry for being ignorant.
    Thank for your help. Sorry for asking questions.
    Speedytech7[QUOTED] likes this.
  10. Feb 17, 2016 at 9:25 PM
    alphabravo
    alphabravo Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    Just press on the brakes with a bar. Then you can get the nut loose.
  11. Feb 17, 2016 at 9:25 PM
    Speedytech7
    I don't mind lending a hand if I can :)
  12. Feb 17, 2016 at 9:28 PM
    JKO1998
    Utah
    Fine, one more. When measuring do you do it when you have one sides spring flat or? I'm sure I can just look it up but it's to late now. Sorry.
  13. Feb 17, 2016 at 9:32 PM
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Hex drain plugs for the rear diff and transfer case to match the front diff.
    Speed bleeders for the brake calipers:
  14. Feb 17, 2016 at 9:36 PM
    Speedytech7
    There are different ways to go about it, I was a lazy bastard and put my floor jack under the ubolt mounting plate and jacked until she wouldn't go any higher (with a load of junk in the bed, about as heavy as my usual wheeling/camping gear) and then measured between the points. You only need to jack one side up at a time. Some people back sideways down a loading ramp too, you can look that method up.
  15. Feb 17, 2016 at 9:39 PM
    Adventurer_Alex
    Adventurer_Alex Generic mall crawler
    Alex
    AZ
    2013 Nissan XTERRA
    Second method is what i did on my last truck, super easy.
  16. Feb 17, 2016 at 9:39 PM
    Speedytech7
    I got those too, I was kinda disappointed that it didn't fit the transfer case though, just a bit too long. Works great for the rear axle though!
  17. Feb 17, 2016 at 9:40 PM
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Aww, no way. Maybe I can find shorter ones or cut them down.
  18. Feb 17, 2016 at 9:43 PM
    Speedytech7
    I tried it and felt resistance at a certain point and didn't feel ballsy enough to keep tightening and actually hear if it was rubbing on something. But looking through the drain hole there is certainly something not too far from the plug directly in there, also there is already a magnet built into the t-case, it is hiding in there.
  19. Feb 17, 2016 at 9:46 PM
    Digiratus
    Roaming the PNW
    The RedHead
    If you have access to a forklift...
  20. Feb 17, 2016 at 9:46 PM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    Yea, the shocks might be a bit extended, but if you're not cycling the suspension (ie driving on flat surfaces) it's fine because you're just using the travel that's built into the shocks.
    I know some people have driven with only springs in the back temporarily...I drove my truck for 3 miles with only springs and it was bouncing all over the place due to shit roads in PA
