  1. Feb 18, 2016 at 11:30 AM
    MatthewMay1
    MatthewMay1 I'm an amateur professional.
    Matthew
    Lone Star Republic
    Supercharged '01 TRD
    Rear Billy 5100's are supposed to be installed boots down. Not sure about the OME's though
  2. Feb 18, 2016 at 11:31 AM
    chota07
    chota07 Member
    nic
    2000 toyota tacoma trd
    2.5" leveling kit 31.5 mastercraft A/T Double din radio Two 12 inch rockford fosgate punches
    Comtemplating a locker in the front but dont know much about it, anyone have any advice as to where and what to start looking at?
  3. Feb 18, 2016 at 11:32 AM
    MatthewMay1
    Matthew
    Lone Star Republic
    ARB air locker. Consider your research done. :D
  4. Feb 18, 2016 at 11:36 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Have you been in a situation that required one? Putting a locker in the front of our trucks asks a lot of the diff and CVs. But yeah unless you want a lunchbox locker the ARB is the best choice cause you can go full open diff when your done.
  5. Feb 18, 2016 at 11:39 AM
    fiziks
    fiziks Well-Known Member
    Isaac
    El Paso TX
    01 DC Prerunner 4x4 5pd Conversion
    5 sp 4x4 conversion, OME lift, SCS F5s
    Has anyone had to take off the door panel and unlock a door that is stuck shut? My front passenger door is currently stuck shut. I am sure the door lock actuator and/or the locking mechanism is messed up. The handles won't engage even if i try pulling up on the tab to try to manually unlock the door.
  6. Feb 18, 2016 at 11:43 AM
    TacoVio
    TacoVio Well-Known Member
    Kolton
    CO/WY
    R.I.P '04 Roy Super White ^^
    '00 Imperial Jade Flatty / '14 Spruce Mica, 6MT, Sick
    Well I ran them like this on my other truck through many water crossings and trails without problems!
  7. Feb 18, 2016 at 11:44 AM
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    I don't know about the panel but maybe these or a creatively bent coat hanger, and fish around in there to see if you can trip it.
    http://www.truckntow.com/slim-jim-t...1LFU2iyCm8bAKtXln-P6_Cna8KOtLtEEgJRoCP5Hw_wcB
  8. Feb 18, 2016 at 11:48 AM
    tibblits920
    tibblits920 Tacos Everywhere!
    Stephen
    Jumbo Shrimp Taco
    32x11.5R15 BF Goodrich KM2's siped, 3" old man emu suspension lift kit (881 coils) w/ rear add-a-leafs, 4.56 Nitro gears, c4 fabrication custom built weld on sliders, LCE header, relentless fab rear plate bumper, LCE short shifter, rear diff breather relocation mod, removed front sway bar, aFe pro dry air filter, LROR hub shift knob, 36 led dome light, husky catch all floor liners, skid row offroad tcase and tranny skids, deka intimidator agm battery w/ lror battery box, 1st gen electrical upgrade, c4fab custom plate bumper/skid, rigid dually d2s, ComeUp 9.5rs winch, URD o2 simulator w/ LCE test pipe,
    Drove it to work, again
  9. Feb 18, 2016 at 12:35 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    This. It's something I'm really trying to think hard about because it's a ton of investment on something that should be used relatively sparingly in our diff's as the skinny pedal and a front ifs diff is likely to shred a CV pretty easily. Half of me is like DO IT LOCKED FRONT AND REAR IS THE BEES KNEES but at the same time it's $800 that can easily be better spent elsewhere right now. Only reason I'm considering it is because I plan on re-gearing the diff very soon and I'm told if you do that you may as well install the FL at the same time.
  10. Feb 18, 2016 at 12:37 PM
    MatthewMay1
    Matthew
    Lone Star Republic
    Well it is the bees knees, soooooooo
  11. Feb 18, 2016 at 12:40 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    I'm having the same thought process. I probably don't need a front locker, but if I'm going to regear I'd rather get it done and not regret it later.
  12. Feb 18, 2016 at 12:46 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Exactly why I'm budgeting for both, worst case scenario. Definitely hard on the wallet since I want to do it relatively all at once though. I knew it was going to be expensive but not couple thousand expensive (including the tires that require the regear in there too).
  13. Feb 18, 2016 at 12:47 PM
    alphabravo
    alphabravo Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    LED strips ready to mount under the doors. I'm gonna hook them up to the courtesy light circuit.
  14. Feb 18, 2016 at 12:50 PM
    Speedytech7
    Sounds cool, pics when your done plz
  15. Feb 18, 2016 at 12:51 PM
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
  16. Feb 18, 2016 at 12:52 PM
    gray223
    SE Missouri
    2014 Tundra Limited
    Have a link of where you got them?
  17. Feb 18, 2016 at 12:54 PM
    MatthewMay1
    Matthew
    Lone Star Republic
    x2
  18. Feb 18, 2016 at 12:58 PM
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    gray223 and MatthewMay1 like this.
  19. Feb 18, 2016 at 1:07 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    That's an awesome idea that I will probably steal eventually :anonymous:
  20. Feb 18, 2016 at 1:31 PM
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    I've been wanting to do this for a long time but nobody was making a nice aluminum strip with high quality LEDs. It sounds like these are really nice and bright SMDs, maybe 5050s or something better.
