  1. Feb 27, 2016 at 8:19 PM
    WheelInTheSky
    WheelInTheSky Ramblin' Man
    G
    Jackson Hole
    02 XtraCab 4x4 SR5-speed
    Yep, you have to clip vice grips to the fender wall and bend it out of the way. Also, you'll need to disconnect a bit of electrics on the passenger side and something else I forget what it is on the driver's side (maybe a hose holder or something?) This will require removing the battery.
    Edit: Use the TC video for the second gen. It's essentially the same deal on a first gen. https://www.youtube.com/watch?v=bbsTJgb6S_c
  2. Feb 27, 2016 at 8:23 PM
    Tacomang
    Tacomang Well-Known Member
    Norcal
    Trd Taco
    I think its the abs wiring and a 10mm wiring loom bolt under the battery. Hmm okay well when I get the I'm going to install them in my driveway so hopefully nothing is seized!
  3. Feb 27, 2016 at 8:27 PM
    WheelInTheSky
    G
    Jackson Hole
    I don't have ABS... but there is something that's needs disconnecting on the passenger side. Wiring loom? That sounds right... It was a loom. It held wires... it was probably a wiring loom!:D
  4. Feb 27, 2016 at 8:28 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    AGAIN !??!
  5. Feb 27, 2016 at 8:31 PM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    OoOoooooo somebody paid attention in chemistry class :p
  6. Feb 27, 2016 at 9:03 PM
    00yotasr5
    00yotasr5 Well-Known Member
    lee
    merced, ca
    00 SR5 4X4 RED DEVIL
    Icon ext travel expo leafs rear billies 5125 10'' travel bamf bpv relocate Brute Force Fab Sliders allpro ss brake lines f/r LR UCA 22in wetokled bar RAT Products ifs skid ARB rear locker Ultra gauge Redline Hood Struts Blue Sea Fuse box smittybilt xrc 9.5 w/TJM synthetic rope trail-gear rock assault low profile bumper LED bed strip 12v/usb charger in truck bed
    I had to remove the SRS crash sensor if that what they called it.
  7. Feb 27, 2016 at 9:21 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Yup, it would appear so. :annoyed:
  8. Feb 27, 2016 at 9:24 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    Chemistry or science?
    I never took Chem, and the last science class I took (that I remember) was 8th grade.
  9. Feb 27, 2016 at 9:26 PM
    pittim
    Pennsyltucky
    Boujee Prius
    I remember doing light spectrum stuff in chem, but I'm betting general science classes teach it also. Cuz like, how are rainbows made n stuff.
  10. Feb 27, 2016 at 9:30 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Smoke stack please!!! :)
    westhumboldt likes this.
  11. Feb 27, 2016 at 10:39 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Time to break the leafs down and clean them up too..damn.
    No
    tibblits920, Speedytech7 and TacoVio like this.
  12. Feb 27, 2016 at 11:18 PM
    Speedytech7
    I did a thing and got some 4K drone footage too... have a whole bunch more pics and footage from today but I'm too tired to edit it tonight.
    https://youtu.be/rHrmT4l8wbU
  13. Feb 27, 2016 at 11:24 PM
    Yetimetchkangmi
    Yetimetchkangmi Well-Known Member
    Benjamin
    Newcastle, WA
    03 Tacoma 4x4 The Yeti
    ARB front locker, Custom high clearance rear bumper, Custom plate front bumper, mile marker winch PE8, safari snorkel, Deck Plate Mod Fox 2.5 rr DSC, Camburg UCA, squeaky Dakar leafs, 5125 10" and custom 7.5" shackles, thee finest PNW pinstripes, MT-R, Nissan crew cab roof rack??? wtf is that about??? Allpro skids, Rigid duallys President McKinley CB with PA Recaro SRD with Wedge Engineering Morimoto retrofits Champion Rad - Failed Tundra brakes
    Located the front/rear diff breathers as I know the prior owner relocated them but I couldn't find them.
    If they were snakes, they would have struck me = right next to firewall above the vacuum booster for the master cylinder.
    Yes, it was a DUH moment.
  14. Feb 27, 2016 at 11:39 PM
    sente3
    sente3 -
    North Jersey
    '04 Xtracab 4x4 V6 5-Speed TRD SR5
    Sliders, rear bumper, front skid, lifted
    These pictures are great. Truck looks damn good on them rocks. And that footage is fantastic. I love and fear the capabilities of them drones.
    tibblits920 likes this.
  15. Feb 27, 2016 at 11:44 PM
    Robmonster117
    Robmonster117 Well-Known Member
    Robert
    Gilroy
    02 ext. cab 4x4
    Truck parts
    Sliders are on they are looking great
  16. Feb 27, 2016 at 11:47 PM
    Speedytech7
    Thanks, it was cool getting to play on the rocks. I forgot to grab my DSLR in the midst of grabbing all our other equipment so I used my point and shoot that I leave in the truck and it was surprisingly good. My roommate just bought the drone (DJI Phantom 3 Pro) and it is scary cool, we had it on auto follow mode for part of it and manual for part too. Thing even has a live 720p video feed to his phone. Have some GoPro footage too, but it isn't 4K...
  17. Feb 27, 2016 at 11:51 PM
    sente3
    sente3 -
    North Jersey
    It seems there aren't many "bad" cameras these days. There are definitely better ones, but even most cell phones have decent cameras for when you're on the go. As someone who is not into photography, but likes to mess around a little, the manual mode on my V10 is pretty cool.
    Seems like a pretty high end drone, at least from the footage. And live 720P is very impressive. On the smaller screen size of a phone, regardless of resolution, 720P will look pretty good as a feed.
    Speedytech7[QUOTED] likes this.
  18. Feb 28, 2016 at 12:00 AM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Is that with a lift? Blowing boots seems to be my biggest issue.
    Also are these lifetime warranty? I forgot to ask.
  19. Feb 28, 2016 at 12:04 AM
    alphabravo
    alphabravo Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    You could do this...
    2004TacomaNavy likes this.
  20. Feb 28, 2016 at 12:06 AM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    A negligible amount of diff oil will spill out. I don't normally bother adding fluid. But it doesn't hurt to refill if you'd have more peace of mind by doing so.
