  1. Feb 29, 2016 at 10:05 AM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    I was thinking I need a reference size of some sort. Hard to tell they are 15.5" wide. Massive meats.
  2. Feb 29, 2016 at 10:37 AM
    Roll Tide
    Roll Tide COO COO KACHOO
    Q
    Here and there. Sometimes.
    01 T4R
    Head unit. That's it.
    New light bar mounts.....lol
  3. Feb 29, 2016 at 10:41 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    So when I turn sharp, like into a parking spot, something start to scream. I'm guessing something with power steering, maybe low fluid?
  4. Feb 29, 2016 at 10:49 AM
    TuckGraham
    TuckGraham Keep it straight
    Tg
    Montana
    TacoVio likes this.
  5. Feb 29, 2016 at 11:26 AM
    TacoVio
    TacoVio Well-Known Member
    Kolton
    CO/WY
    R.I.P '04 Roy Super White ^^
    '00 Imperial Jade Flatty / '14 Spruce Mica, 6MT, Sick
  6. Feb 29, 2016 at 11:32 AM
    BroTaco
    BroTaco Well-Known Member
    Ian
    Cashmere, WA
    2017 TRD OR
    Cleaned the carpets/upholstery with Woolite and put in new floor mats. That stuff is magical.
    mohavestubbs and alphabravo like this.
  7. Feb 29, 2016 at 11:46 AM
    -40
    -40 Well-Known Member
    North Dakota
    01 DC Camburg LT & 17 OR OME BP-51
    1 st Gen TRD Supercharger. URD 7th Inj. Camburg 4x4 LT Kit. Tundra Brakes. 3rd Gen just get’n started, OME BP51 Dakar HD, Camburg UCA & various armor.
  8. Feb 29, 2016 at 1:18 PM
    ClevSix
    ClevSix Well-Known Member
    IL/IA
    01 DCSB SR5 TRD, 13 T4r SR5
    Suspension, 33s, some armor... Rust, Gray wire and 2Low, and more. T4r is stock.
    Probably a belt.
  9. Feb 29, 2016 at 1:32 PM
    JKO1998
    Utah
    But only at sharp turns?
  10. Feb 29, 2016 at 1:37 PM
    Adventurer_Alex
    Adventurer_Alex Generic mall crawler
    Alex
    AZ
    2013 Nissan XTERRA
    Check your fluid at least to eliminate that possibility, look at the belts abs see if they need to be replaced and look at the rack to see if it's leaking. Is not like anyone can give you a perfect answer without more details or looking at your truck
  11. Feb 29, 2016 at 1:48 PM
    WheelInTheSky
    WheelInTheSky Ramblin' Man
    G
    Jackson Hole
    02 XtraCab 4x4 SR5-speed
    This is a pretty common indication that your PS pump will need to be replaced at some point in the near-ish future. You can wait until the scream is frequent and obnoxious and then wait some more. You'll know it's time to change the pump when you frequently lose power steering ability on turns. A quick fix to get rid of the noise is to clean the screen at the bottom of the pump, but this will not extend the life of the pump at all. It will still need to be replaced at some point in the next 5k to 25k miles regardless.
  12. Feb 29, 2016 at 1:50 PM
    ClevSix
    IL/IA
    The belt is more likely to sequel the harder you turn especially if you are turning and there is back pressure on the wheels (like turning against a curb or the stop).
  13. Feb 29, 2016 at 2:06 PM
    alphabravo
    alphabravo Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    If it only squeals during hard cornering or when the rack reaches the stops (or for a few minutes when cold) then it is most likely just the belt tension. When the tension is too loose then the belt slips under heavy load but seems to be fine under normal driving when the steering is lightly loaded.
    ClevSix likes this.
  14. Feb 29, 2016 at 2:31 PM
    tbr3345
    tbr3345 Well-Known Member
    Tom
    Sacramento, CA
    2010 TRD Sport DBL Cab Silver Streak Mica
    Finished painting plastic fender molding with Dipit. Tomorrow tackle the front struts, then all that is left is plugs, wires, valve cover gaskets. Then some time off to take of some Honey Do's then new rear spring poly bushing and steering rack bushings. Some time in the near future will take it in and have Trans fluid flushed and new trans filter. I did change the 3qt in the pan it's due the whole thing. By then Trout Season will open in the Sierras.
    Tom
  15. Feb 29, 2016 at 2:36 PM
    JBTacoma
    JBTacoma Well-Known Member
    Jeff
    Cullman Alabama
    2000 SR5, 2003 Double Cab and a Suzuki Samurai
    Got some parts from 4Wheel Parts to extend my winch controls to inside my cab.
  16. Feb 29, 2016 at 3:18 PM
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    2002 Toyota Tacoma 4WD
    Check Build
    Put some stickers on the rims...
    BYJOSHCOOK likes this.
  17. Feb 29, 2016 at 4:12 PM
    because_wumbo-truck
    because_wumbo-truck TTC#036 1st Degenerate Urban Off-Roader
    Jon
    Houston, Texas
    2006 Gordita Blanca V8 4x4 aka "Penelope"
    Sliders and bumper, DDI injectors, flowmaster 40
    Doesn't even get said rim stickers in the focus
    Silver02Taco likes this.
  18. Feb 29, 2016 at 4:15 PM
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    Check Build
    JKU3000 and BYJOSHCOOK like this.
  19. Feb 29, 2016 at 4:31 PM
    because_wumbo-truck
    Jon
    Houston, Texas
    Much better. Now what are they?
  20. Feb 29, 2016 at 4:41 PM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    The SCS vinyl on the rim in silver
    Delta00 likes this.
