  1. Mar 1, 2016 at 11:58 AM
    chowwwww
    chowwwww Well-Known Member
    Orange County
    03 Doublecab 4x4
    Billys 5100/Eibach and Wheelers Progressive 1.5 AAL with overload in
    Driver side for front diff. same problem as the 2nd gen.
  2. Mar 1, 2016 at 12:44 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    ...okay..I've taken apart my diff..and there is no needle bearing anywhere in our diffs.
  3. Mar 1, 2016 at 12:48 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I believe he is referring to the bushing that locates and supports the CV shaft concentrically in the diff. Mine has play and clunks too but I'm not gonna bother replacing it until it leaks.
  4. Mar 1, 2016 at 12:50 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    That goes in the roller bearing. That makes sense.
    Needle bearing...come on guys. Totally different bearing.
    Speedytech7[QUOTED] likes this.
  5. Mar 1, 2016 at 12:52 PM
    Speedytech7
    Yeah, the only place in the front I can recall a needle bearing is in the tulip joint.
  6. Mar 1, 2016 at 1:14 PM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    It's a needle bearing. The only technical difference between a roller and a needle is the length to diameter ratio of said needle/roller.
  7. Mar 1, 2016 at 1:21 PM
    jaycub
    jaycub Well-Known Member
    jacob
    Paulding, Georgia
    that GRILLE is beautiful. ill have to get one myself
  8. Mar 1, 2016 at 1:23 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    I like monty, he should run for president! :)
    Lol, for reals Monty, love all the knowledge you pass along
    Blackdawg, TacoVio and FirstGen Jer like this.
  9. Mar 1, 2016 at 1:24 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    What's wrong with this?
  10. Mar 1, 2016 at 1:26 PM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    It's not a 2006
    TuckGraham likes this.
  11. Mar 1, 2016 at 1:26 PM
    because_wumbo-truck
    because_wumbo-truck TTC#036 1st Degenerate Urban Off-Roader
    Jon
    Houston, Texas
    2006 Gordita Blanca V8 4x4 aka "Penelope"
    Sliders and bumper, DDI injectors, flowmaster 40
    Not 2006, hideous wheels, too much jpeg...
  12. Mar 1, 2016 at 1:28 PM
    Speedytech7
  13. Mar 1, 2016 at 1:31 PM
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    Too poor to list anything interesting.
  14. Mar 1, 2016 at 1:33 PM
    JKO1998
    Utah
    Am I douche for tellin him that
  15. Mar 1, 2016 at 1:34 PM
    Speedytech7
    Douche is a bit relative, you can correct him on year because that's straight up factually incorrect. But calling him out on those "wheels" would be douchy.
  16. Mar 1, 2016 at 1:42 PM
    JKO1998
    Utah
    Just the year.
  17. Mar 1, 2016 at 1:43 PM
    Speedytech7
    Yeah I'd correct him...
  18. Mar 1, 2016 at 1:44 PM
    JKO1998
    Utah
    I know, that's what I did.
  19. Mar 1, 2016 at 1:49 PM
    jaycub
    jacob
    Paulding, Georgia
    can one of you please tell me how many pieces if i have to replace for my front bumper. all of it is damaged including the grill so im gonna replace it all. but i dont know where to locate it or what exactly im looking for /:
  20. Mar 1, 2016 at 1:51 PM
    tbr3345
    tbr3345 Well-Known Member
    Tom
    Sacramento, CA
    2010 TRD Sport DBL Cab Silver Streak Mica
    Installed new Front Struts. Took the old off last night. Took them over to tire shop first thing this morning and had them disassemble the old struts and install the new struts on Coil Springs. Got them back took about 30 minuets to install on truck. Used the hints I found on the site to help me get them back on. Bad weather this weekend so that's when I will do the Valve Cover Gaskets, PCV valve, spark plugs and wires. The truck rides better, still a Tacoma but smoother.
    Tom
