  1. Mar 3, 2016 at 8:14 PM
    BroTaco
    BroTaco Well-Known Member
    Ian
    Cashmere, WA
    2017 TRD OR
    I vinyl wrapped some interior plastics.
  2. Mar 3, 2016 at 8:21 PM
    because_wumbo-truck
    because_wumbo-truck TTC#036 1st Degenerate Urban Off-Roader
    Jon
    Houston, Texas
    2006 Gordita Blanca V8 4x4 aka "Penelope"
    Sliders and bumper, DDI injectors, flowmaster 40
    Makes me miss my 99. It had that same shot when I got it. What are the switches for?
  3. Mar 3, 2016 at 9:08 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    IMO, unless a bumper is designed as a swingout in the first place, it will have difficulty with the leverage the swingout arm can place on it.
    m3bassman likes this.
  4. Mar 4, 2016 at 1:02 AM
    westhumboldt
    westhumboldt Well-Known Member
    Arcata,Ca
    97 Tacoma sc 4x4
    Doug Thorley headers, urd 7th and Trd Supercharger, bilstein lift, trd locker just installed.
    what type of vinyl wrap is that? I need a cheap mod to get me by right now.
    because_wumbo-truck likes this.
  5. Mar 4, 2016 at 5:27 AM
    alee891
    alee891 Destination: unknown
    Austin
    Black Hills
    Tacomaless
    In regards to the all pro bumper, where do you suspect the troubled spots would be? Is it as simple as beefing up the platform for a swingout, or would it require more work than its worth?
  6. Mar 4, 2016 at 5:46 AM
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    It's about the mount to the frame itself. You don't want any flex in the bumper when the swing out is opened. The bumper itself should be strong enough, since it's going to bounce off trees and rocks anyway.
    Mine was never designed for a swingout, but I don't think it will be a problem to fab something up, since the actual mount to the frame is well done.
  7. Mar 4, 2016 at 6:02 AM
    alee891
    Austin
    Black Hills
    Tacomaless
    I'm just weighing my options right now. I would love to do high clearance with a swing out, but wanted to entertain the idea of fabbing one up for a tube bumper.
    What bumper do you have, Brett?
  8. Mar 4, 2016 at 6:09 AM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Mine is custom :D Only two in existence. It is a Rucas Built.
  9. Mar 4, 2016 at 6:11 AM
    alee891
    Austin
    Black Hills
    Tacomaless
    Off to your build thread I go:)
    Deathbysnusnu[QUOTED] likes this.
  10. Mar 4, 2016 at 6:12 AM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Post 233 starts the rear bumper
    BYJOSHCOOK and alee891[QUOTED] like this.
  11. Mar 4, 2016 at 6:17 AM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    What are the red switches for?
  12. Mar 4, 2016 at 6:25 AM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    That's nice! Kinda how I want to do mine except that top tube only goes to the side of the bumper
  13. Mar 4, 2016 at 7:22 AM
    BroTaco
    Ian
    Cashmere, WA
    2017 TRD OR
    The right switch is for my 30" light bar mounted on the roof rack, and the left is for aux lighting up front. I messed up and tried to fit a third switch in between. There wasn't enough of a gap between the other two, so I had an unsightly hole in my panel that is now covered.
    bowyer2002 likes this.
  14. Mar 4, 2016 at 7:25 AM
    BroTaco
    Ian
    Cashmere, WA
    2017 TRD OR
  15. Mar 4, 2016 at 8:18 AM
    Suggs12
    Suggs12 Well-Known Member
    Logan
    Johnson City, Tennessee
    2004 PreRunner
    3" Lift kit, Bilstein 5100 front and rear, 2881 EMU coils, 2" Deavers AAL, 18x9 KMC rockstar 1 wheels and 33" Nitto Terra Grapplers, Debadged, Grillcraft insert, clear corner and turn lights, 6k Leds, 30" Led light bar, 4 Pod fog lights.
    About to do this to mine! Except going with a white carbon fiber. How tricky was it?
  16. Mar 4, 2016 at 9:49 AM
    BroTaco
    Ian
    Cashmere, WA
    2017 TRD OR
    To be honest it took a lot longer than I would have liked haha. It took about 2 1/2 hours to do both control panels, the dash face thing, and both of the plastic covers on the side of the seats. I would strongly recommend a heat gun, it makes it easier to manipulate the material without causing creases.
  17. Mar 4, 2016 at 10:17 AM
    Jarob11
    Jarob11 Well-Known Member
    Hilo/Tacoma/Evanston
    99 Taco Limited
    Badlands custom frt winch mount bumper. badlands RR bumper w/ spare swing out, jerry can holder. Leer Camper shell. Royal Purple synthetics. Baja fender flares. Entire truck rhino lined. 31's. Custom sound system. More to come.
    your camp card in the back window looks like the ones they give out at the bi-mart music festival in Brownsville!!!! am I close??
  18. Mar 4, 2016 at 10:31 AM
    SlipperyTaco
    SlipperyTaco Slippery when Wet
    Chandler, AZ
    04 Tacoma 4x4 & 2014 4Runner Trail Premium
    FOX 2.5 C/O, CAMBURG UCA, FOX 2.0 REAR, SMP CUSTOM FRONT BUMPER, BAMF LCA SKIDS, SCS RAY 10 MATTE GREY WHEELS, 305/70/16 BFG KO2, ALL PRO STANDARD LEAF PACK, ALL PRO SLIDERS, U-BOLT FLIP KIT, MARLIN CRAWLER REAR BUMPER, TIMBREN REAR BUMPSTOPS, WHEELERS SS BRAKE LINE F/R, D-BADGED, GIBSON CAT BACK, K&N CAI, LINE-X , GREY WIRE MOD, APOLLO 3.0 SHROUDS, D2S XB 5500K HID BULBS, LED HALOS, LED DEMON EYES, TRS LED BULBS, BHLM, IGGY PODS, CALI RAISED PODS, 30" CALI RAISED 4D LIGHT BAR, BESTOP SUPERTOP, TRASHAROO , WET OKOLE SEAT COVERS. 4 RUNNER- 2014 TRAIL PREMIUM W/KDSS KINGS FRONT AND REAR DIRT KING BALL JOINT UCA METAL TECH LONG TRAVEL SPRINGS METAL TECH UPPER/LOWER LINKS SONORAN STEEL KDSS TRACK BAR URD EXHAUST URD Y PIPE URD MAF CALIBRATOR PEDAL COMMANDER PRINSU ROOF RACK RIGID ADAPT LIGHT BAR SCS SR8 17" GUNMETAL 285/70/17 FALKEN WILDPEAKS TRS FOG LIGHTS TRS HID KIT SS OFFROAD SLIMLINE WITH SIDE PROTECTION COASTAL REAR SWINGOUT HEFTY FAB SKIDS
    LAMIN-X Gas tank lid.
    Did bumper fillers too and pod lights
  19. Mar 4, 2016 at 10:42 AM
    Digiratus
    Roaming the PNW
    The RedHead
    It might require a lot of work. But I have never seen the bumper your are referring to up close so I really can't comment on it directly. Whether you can do this or not will also depend on how much weight/leverage you will be applying to the pivot.
    I can only speak about my experiences which is in helping to build my plate bumper.
    Structurally, mine is very, very stout by design. We did this so the bumper itself will not flex when the swingout arm is open. For the most part, the design was successful but the arm itself does still flex some and the main plate the spindle is mounted to does 'creek' a bit when the arm is swung out and the full weight of a 33 and steel wheel and 10 gallons of gas are on it.
    Pics and more details about the bumper build:
    https://www.tacomaworld.com/threads...trail-rig-and-bs.159436/page-507#post-9868553
    BYJOSHCOOK likes this.
  20. Mar 4, 2016 at 10:47 AM
    Suggs12
    Logan
    2004 PreRunner
    Cool, I just got my heat gun and wrap, just waiting to find time to do it.
