  1. Mar 4, 2016 at 1:03 PM
    BroTaco
    BroTaco Well-Known Member
    Ian
    Cashmere, WA
    2017 TRD OR
    Sweet! I want to see how the white looks
  2. Mar 4, 2016 at 1:34 PM
    KeptOnChooglin
    KeptOnChooglin Well-Known Member
    Phil
    Houston, TX
    2003 Crew Cab PreRunner L4 Auto
  3. Mar 4, 2016 at 1:41 PM
    KeptOnChooglin
    Phil
    Houston, TX
    Question: Where to get a stock wheel cap? Anything cheaper than the dealer? Ebay?
  4. Mar 4, 2016 at 2:34 PM
    Kchapp
    Kchapp Active Member
    Kevin
    Birmingham
    02 Double Cab SB
    General Grabber At2 on Helo He791 wheels, LED interior dome and map lights , Opt7 Led headlights, Pioneer In dash DVD, Parking brake bypass for DVD, Husky liners, Drop in UTR liner, Stainless D Cab toolbox, K&N air filter, Westin nerf bars, Mounted aux/usb input from head unit. Bluetooth OBDII module.
    New wheels and tires! Helo He791 and General Grabber At2!
    JKU3000 likes this.
  5. Mar 4, 2016 at 2:43 PM
    TheSaint
    TheSaint Regular Guy
    Mark
    Prescott, Arizona
    White 2003 4x4 TRD DC
    OME lift, 265/75s, pickup shell, couple of dents.
    Not sure how much your dealer is charging. ~$30 used on Ebay here. Conicelli has them new for ~$54 here. I've seen them as low as $20 for a set of four on Craigslist, but they don't come up that often.
  6. Mar 4, 2016 at 4:44 PM
    JBTacoma
    JBTacoma Well-Known Member
    Jeff
    Cullman Alabama
    2000 SR5, 2003 Double Cab and a Suzuki Samurai
    Finally got this fixed today.
    When I was swapping out my front diff I found the bronze bushing in the drivers side hub was messed up, found out it is not something Toyota conceders a replacement part. So it is not something you can just get anywhere.
    Thanks to Off Road Solutions I got the part I needed because they carry them!!!
    Deathbysnusnu and Silver02Taco like this.
  7. Mar 4, 2016 at 4:47 PM
    TuckGraham
    TuckGraham Keep it straight
    Tg
    Montana
    I need recommendations for a cheap, but good rear bumper with swing out! Thanks guys!!
  8. Mar 4, 2016 at 5:26 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Don't think one exists. In fact I can't think of any other options besides Relentless and CBI. Neither of which you can get in high clearance IIRC. If you get really desperate, I'm planning on buying a proper welder in the next couple months. Buy the steel, consumables, and a shit ton of beer and I'll help you fab one. Keep in mine I'm no expert so don't expect perfection.
    TuckGraham[QUOTED] likes this.
  9. Mar 4, 2016 at 5:28 PM
    Tacomang
    Tacomang Well-Known Member
    Norcal
    Trd Taco
    Pay your local fabrication shop to make you one :)
  10. Mar 4, 2016 at 5:31 PM
    Tacomang
    Norcal
    Trd Taco
    Looky looky what i got in the mail! Shout out to toytec and jaker for the group buy
  11. Mar 4, 2016 at 6:29 PM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    4xinnovations can build one too, but there is no such thing as a cheap bumper with a swingout.
  12. Mar 4, 2016 at 6:33 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    What do you guys use to clean your engine - um area - under the hood? Mines pretty greasy/ dusty....
  13. Mar 4, 2016 at 6:34 PM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    Mines pretty muddy and dusty too. I'm interested to hear the results, but I think most people just use Simple Green and a light spray with a hose.
  14. Mar 4, 2016 at 6:37 PM
    JKO1998
    Utah
    Like spray everything with simple green, let it soak a little and hose it off?
  15. Mar 4, 2016 at 6:38 PM
    westhumboldt
    westhumboldt Well-Known Member
    Arcata,Ca
    97 Tacoma sc 4x4
    Doug Thorley headers, urd 7th and Trd Supercharger, bilstein lift, trd locker just installed.
    I just use a mild degreaser and power spray it works like a charm just mind the electronics.
  16. Mar 4, 2016 at 6:38 PM
    DustStorm4x4
    U S A
    04 Jeep LJ
    I think. Idk, last time I just pressure washed everything from a distance with the engine on. Just try not to get the fuse box.
  17. Mar 4, 2016 at 6:49 PM
    FirstGen Jer
    FirstGen Jer Well-Known Member
    Jeromey
    big bear lake, CA / lake havasu, AZ
    1999 toyota tacoma 3.4l v6 sr5 4x4
    I found a lot of helpful info in this thread... https://www.tacomaworld.com/threads/cleaning-engine-bay.173916/
    DustStorm4x4[QUOTED] likes this.
  18. Mar 4, 2016 at 6:53 PM
    Madjik_Man
    Colorado Front Range
    :anonymous:
  19. Mar 4, 2016 at 6:54 PM
    Madjik_Man
    I'd cover your alternator and belts as best as possible.
  20. Mar 4, 2016 at 7:05 PM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    I'd suggest against this unless it's one that builds bumpers. It won't look or function as well as those made by companies that have experience.
