  1. Mar 4, 2016 at 9:20 PM
    because_wumbo-truck
    because_wumbo-truck TTC#036 1st Degenerate Urban Off-Roader
    Jon
    Houston, Texas
    2006 Gordita Blanca V8 4x4 aka "Penelope"
    Sliders and bumper, DDI injectors, flowmaster 40
    What were you teaching them?
  2. Mar 4, 2016 at 9:21 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    What happens when you don't have 4WD? :notsure:
    Silver02Taco, nagorb and DustStorm4x4 like this.
  3. Mar 4, 2016 at 9:22 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Well you could put filters on the grounds.
    ClevSix likes this.
  4. Mar 4, 2016 at 9:23 PM
    because_wumbo-truck
    Jon
    Houston, Texas
    No more pipboy? :pout:
  5. Mar 4, 2016 at 9:23 PM
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    Got a link for such filters? I learned about a rf choke( think that's what it was) studying for my ham radio license. Is that the same thing?
  6. Mar 4, 2016 at 9:23 PM
    WheelInTheSky
    WheelInTheSky Ramblin' Man
    G
    Jackson Hole
    02 XtraCab 4x4 SR5-speed
    Did your radio work without fail before installing the retros?
  7. Mar 4, 2016 at 9:25 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yep.
    The only other filter is installing a capacitor across the power and ground of them. Which is a bit more advanced.
    gray223[QUOTED] likes this.
  8. Mar 4, 2016 at 9:25 PM
    Speedytech7
    I was in search of something that no one else had. So far only one person on this forum knows this character...
    RustyVT likes this.
  9. Mar 4, 2016 at 9:26 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Oh, I misunderstood. I thought you were interested in a way of eliminating the static.
  10. Mar 4, 2016 at 9:27 PM
    because_wumbo-truck
    Jon
    Houston, Texas
    Deathclaw + mirelurk king baby
    Jk
    A quick Google image search reveals the truth ;)
  11. Mar 4, 2016 at 9:27 PM
    gray223
    SE Missouri
    2014 Tundra Limited
    Well.... The only time I tried it since I got the truck rebuilt was when I was using a cheap wlmart antenna. I thought the radio sucked cause of it. So I got an oem antenna. Then I realized all the static happens when the headlights are on... Or the staic gets worst anyways.
    The radio doesn't seem to work good in general to be honest. I get less reception in places where my 96 tacoma never lost reception.
    Could the bed liner have an effect on the radio waves????
  12. Mar 4, 2016 at 9:28 PM
    gray223
    SE Missouri
    2014 Tundra Limited
    I am...
  13. Mar 4, 2016 at 9:30 PM
    Speedytech7
    :thumbsup:
  14. Mar 4, 2016 at 9:37 PM
    WheelInTheSky
    G
    Jackson Hole
    Disconnect the retros and run the radio with lights turned "on" and "off."
    Is your "OEM" antenna attached properly? Eliminate one variable at a time..
  15. Mar 4, 2016 at 9:40 PM
    gray223
    SE Missouri
    2014 Tundra Limited
    Ok yeah I will just have to do that. And it is attached just like the other oem that came with it.
  16. Mar 4, 2016 at 9:46 PM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    I'm gonna guess custom.
    BroTaco likes this.
  17. Mar 4, 2016 at 9:47 PM
    -40
    -40 Well-Known Member
    North Dakota
    01 DC Camburg LT & 17 OR OME BP-51
    1 st Gen TRD Supercharger. URD 7th Inj. Camburg 4x4 LT Kit. Tundra Brakes. 3rd Gen just get’n started, OME BP51 Dakar HD, Camburg UCA & various armor.
    20" Baja Designs Onx 6.
  18. Mar 4, 2016 at 9:47 PM
    WheelInTheSky
    G
    Jackson Hole
    Electrics can be a total pain in the arse. Blackdog is right, a capacitor is a pretty good fix-all for static issues and I've considered putting one in to isolate my CB unit even further upon install.. but really it shouldn't be necessary. If your radio is F-ed then there's something wrong with either the antenna's ground or the unit itself.
  19. Mar 4, 2016 at 9:51 PM
    WyoRoam
    WyoRoam Well-Known Member
    Brian
    Sebring, FL
    1st HomerTaco Ghost Raptor Grille, Softtopper
    New headlights and grill today!
  20. Mar 4, 2016 at 9:53 PM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Got my prinsu installed, I'll post some pics tomorrow. A bit tired ha
    TacoVio likes this.
