  1. Jan 29, 2012 at 5:47 PM
    #9201
    Stubbs95tacoma
    Stubbs95tacoma Well-Known Member
    Blake
    Wichita
    07 SR5
    6 Inch Lift
  2. Jan 29, 2012 at 6:06 PM
    #9202
    sir1123
    sir1123 Tacomas FTMFW!!!!
    Charleston
    99 SR5 Prerunner, Black,3.4L
    3"Ebaich with 5100 Bilstiens, K&N cai, 5% 3M Tint, Magnaflow 18", Hella 500s with 35w 3000k hid retro, 33x9.5x15 BFG A/T
    we have 9003 size bulbs...i just got the zxe sylvainas and they are real good
  3. Jan 29, 2012 at 6:50 PM
    #9203
    TIPICOTACO
    TIPICOTACO Well-Known Member
    Tyler
    nw nj
    '01 DC 4X4 TRD "RAD BARON"
    Some lift, some armor, some scratches..
    I got the Ultraguage like 2 weeks ago and had it temporarily sitting on top of the steering column but wanted a better spot to mount it. I decided to utilize the blank on my dash where the "airbag key" goes on other yr Tacomas.
    I used a Dremel to cut the suction cup mount UG provided right at the square "clip" portion; then drilled into the blank and squared it off. The square back of the "clip" fit into the hole I made perfectly tight as hell. I'm really happy with the end result!! Check it out VVVVV
  4. Jan 29, 2012 at 7:02 PM
    #9204
    whatatoy
    whatatoy Galt/Rearden 2012
    SO CAL
    I like it
    This truck is a work truck - not a lot of fancy mod's here, but it's getting the job done!
    ^^ I like this ^^
    I just ordered mine and expect to see it here Wed or Thurs this week... I like your mount position - would like some pics of the mount (behind the gauge - from both sides)
    My big question on your mount location is how it affects airflow from vents in center.
  5. Jan 29, 2012 at 7:12 PM
    #9205
    Warhorseforever
    Warhorseforever Will The Thrill
    Will
    Sand Lapper
    2001 Toyota Tacoma Pre-Runner SR5
    Kenwood KDC-348U HU Kicker DS65 Front Doors Only 2 Polk Audio MM840 Kenwood KAC 8105D for subs SuperCrewSound.com behind rear seat sub box
  6. Jan 29, 2012 at 7:28 PM
    #9206
    Warhorseforever
    Will
    Sand Lapper
    No but I've seen the add-a-fuse things on here before and figured I give that a shot, but what plug would I put it for it to turn on/off with the ignition? I've done the cig lighter always on mod so I'd rather not wire it in with that.
  7. Jan 29, 2012 at 7:35 PM
    #9207
    Warhorseforever
    Will
    Sand Lapper
    I ain't going anywhere.:)
  8. Jan 29, 2012 at 7:57 PM
    #9208
    Warhorseforever
    Will
    Sand Lapper
    Riggghhhttt finish up "some" stuff.:D
  9. Jan 29, 2012 at 7:59 PM
    #9209
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    That is a bit misleading though because "white" is somewhat subjective. Sunlight at noon is up around 5500K so a 6000k bulb will look pretty "white" with a hint of blue.
    4300k on the other hand may appear less "white" (slightly more yellow) but gives the most lumens (lumens=brightness) 4300k is about 10% brighter than its 6000k counterpart.
    If you want light performance, go 4300k. If you want a whiter appearance that you cant see because you are the one driving, go with 6000k.
  10. Jan 29, 2012 at 8:12 PM
    #9210
    Slodgetto
    Slodgetto Über Posre
    Silas
    Dirty Terc
    Scratches, dents, and junkyard parts.
    Drove 2 hrs... picked up a front diff,tranny mount, and various mounting brackets/bolts...drove 2 more hrs.... dropped off some tires and BS'd with Raymond (Dead Heretic) at his house... drove half an hour and went wheeling on a whim.... got stuck in sand..... aired down reeeeeally low and used a mudflap i got at the junk yard to get out..... borrowed an air pump from a dude with a blazer.... gave him 5 bucks.... followed him for a few miles and watched him coast to a stop.... he had run out of gas lol...... he said he was fine and his girlfriend was coming with a can of gas.... i said you sure? ok peace dude and drove 1 hour home
    used more than 3/4 tank of gas! :eek:
    all in all it was a good day!! lol :D
  11. Jan 29, 2012 at 8:30 PM
    #9211
    sir1123
    Charleston
    very eventful
  12. Jan 29, 2012 at 8:32 PM
    #9212
    Slodgetto
    Silas
    Dirty Terc
    YEAH!! lol
  13. Jan 29, 2012 at 9:11 PM
    #9213
    tc98tacoma
    tc98tacoma Well-Known Member
    Nik
    San Antonio, Texas
    98tacoma4x4
    3inch toytec coils 5100's, aal(soon to be replaced), 33/12.5 km2s, + a money hole...
    took a nice pic on top of the mall parking garage
  14. Jan 29, 2012 at 9:25 PM
    #9214
    Taco76087
    Taco76087 Well-Known Member
    Robert
    Weatherford,Texas
    04 Tacoma prerunner TRD SR5
    Rockford Fosgate p2 10'', Q-Logic Enclosure, JVC KD-PDR30 Ipod Connection, Rockford p200.2 Amp, Clear Corners, KING Coilovers, Rancho Rear shocks FJ TRD Trail Teams Wheels with 285/75/16 Duratracs
    Looks great :thumbsup:
  15. Jan 29, 2012 at 9:52 PM
    #9215
    mrp192
    mrp192 REALLY!!
    Brent
    Cheney WA
    98 V6 4x4 limited
    Stereo, boobies
    Yea man Just a little. really you just move the bend then just snip off the extra metal. I think it looks really clean.
  16. Jan 29, 2012 at 11:46 PM
    #9216
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 v6 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
  17. Jan 30, 2012 at 12:18 AM
    #9217
    Lostoam311
    Lostoam311 YETI
    Jon
    Gulf Breeze, FL
    2013 YETI
    LED's in headlights/fog lights and all interior lights Just got a set of Nitto Terra Grappler G2's and couldn't be happier! I don't do a lot of off roading, but they definitely pack some Grip! Plastidipped Stock wheels, emblems, and Bull Bar. Holding up well!
    6000K 55watts are Great!!! A lot brighter than the 35 watts or regular halogens...
  18. Jan 30, 2012 at 12:19 AM
    #9218
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I actually prefer my 4300k 55w HIDs better then the 6000k. A blend of the two is great tho.
  19. Jan 30, 2012 at 12:28 AM
    #9219
    Lostoam311
    Lostoam311 YETI
    Jon
    Gulf Breeze, FL
    2013 YETI
    I'd like to swap out my Hella 500's with HID's... 4300's huh??! might just have to go with those... I wouldn't want to be driving towards me... it's already bright, but it's not quite Daylight YET.....
  20. Jan 30, 2012 at 12:33 AM
    #9220
    Blackdawg
    Monte
    Wyoming/St. Louis
    dude..my hella 500 HIDS are stupid bright lol I couldn't believe it. i though two was epic till i had all 4 on :eek: was ridiculous...i liked it :cool:
