  1. Mar 6, 2016 at 7:36 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Probably the difference is in the plastic compound. Good ridgid plastic is reinforced with glass fibers whereas cheapo is essentially just melted ABS with no thought of inner structure.
  2. Mar 6, 2016 at 7:36 PM
    Kevinbobo123
    Kevinbobo123 Well-Known Member
    Houston,TX
    2010 Tacoma
    i knew they did it way too fast. i was in and out in 30 mins.
    I'm lifted on 5100 and eibachs stock uper control arms.
    whats a stock tacoma specs for caster?
  3. Mar 6, 2016 at 7:42 PM
    WheelInTheSky
    WheelInTheSky Ramblin' Man
    G
    Jackson Hole
    02 XtraCab 4x4 SR5-speed
    I can't remember of the top of my head, maybe 1.8-2.5? I'm not sure, someone else can chime in.
  4. Mar 6, 2016 at 7:42 PM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Hey Brett what tires are those?
  5. Mar 6, 2016 at 7:47 PM
    Kevinbobo123
    Houston,TX
    2010 Tacoma
    Yea i knew something wasn't right after throwing a 3 inch lift on.
    The tech at NTB literally only turned a wrench on the truck for 10 mins or less. so i knew something was fishy. Should have trusted my gut. I just didn't know what specs i was looking for. I figured that print out was generic for the Red Green in spec out of spec.
  6. Mar 6, 2016 at 7:47 PM
    TacoVio
    TacoVio Well-Known Member
    Kolton
    CO/WY
    R.I.P '04 Roy Super White ^^
    '00 Imperial Jade Flatty / '14 Spruce Mica, 6MT, Sick
    Ouch! Your not gonna get good caster at all then.
  7. Mar 6, 2016 at 7:48 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Went to the 4x4 swap meet today at the fairgrounds. Its an annual thing. Lots and lots of stuff there. Some is "another man's junk" but also some really good stuff. Lots of people...
    Mostly for heeps but Toyota is well rep'd and even Some Tacoma specific stuff. Picked up these for $40. Brand new.
    JKU3000, FirstGen Jer and Delta00 like this.
  8. Mar 6, 2016 at 7:48 PM
    TacoVio
    Kolton
    CO/WY
    Toyo open country mt 285/75r16! Maybe my next tire!
    BYJOSHCOOK[QUOTED] likes this.
  9. Mar 6, 2016 at 7:49 PM
    Kevinbobo123
    Houston,TX
    2010 Tacoma
    I'm not expecting perfect. any numbers i should be shooting to get close too?
  10. Mar 6, 2016 at 7:50 PM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    I may go with hankook MTs next, not sure yet
  11. Mar 6, 2016 at 7:50 PM
    Kevinbobo123
    Houston,TX
    2010 Tacoma
    Jarob11, JKU3000, Fernando and 4 others like this.
  12. Mar 6, 2016 at 7:52 PM
    Speedytech7
    Looks good :) Sometimes wish my truck was white
  13. Mar 6, 2016 at 7:53 PM
    WheelInTheSky
    G
    Jackson Hole
    The fact that their machine shows negative caster as being in the green is a major red flag... You need to take it back to them and demand they fix it or refund you. A major problem a lot of us go through is finding a shop that is willing to do alignments for trucks with aftermarket lifts on them. Sometimes with a lift you need numbers that are not "factory spec." Places don't want to go out of factory spec because they fear being blamed for damage and tire wear down the road. You can use this to your advantage in this situation, because they did not put you in spec for caster. Go shove your fist up their ass and get a proper alignment bruddah!
    Fernando likes this.
  14. Mar 6, 2016 at 7:56 PM
    TacoVio
    Kolton
    CO/WY
    Towards 2 as always but you're lucky if you get 1! This is mine and that's as much as he could get without messing with my camber and what not in order to get closer to 2
  15. Mar 6, 2016 at 7:59 PM
    TacoVio
    Kolton
    CO/WY
    Those come in a 295/75r16 too... About a 34 and they look good! Ask @Squeaky Penguin how they perform too!
  16. Mar 6, 2016 at 7:59 PM
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Yep.
    Get them siped if you do.
    TacoVio[QUOTED] likes this.
  17. Mar 6, 2016 at 7:59 PM
    Kevinbobo123
    Houston,TX
    2010 Tacoma
    10-4 I got the 1 year alignment so i can go back an annoy them as many times as possible.
    TacoVio likes this.
  18. Mar 6, 2016 at 8:00 PM
    WheelInTheSky
    G
    Jackson Hole
    :thumbsup:
    That's the spirit!
    Kevinbobo123[QUOTED] likes this.
  19. Mar 6, 2016 at 8:03 PM
    BroTaco
    BroTaco Well-Known Member
    Ian
    Cashmere, WA
    2017 TRD OR
  20. Mar 6, 2016 at 8:07 PM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Yeah that's who I went to first, the 2 tires look a lot alike ha. Not sure if I'll go 295s or 285s
