  1. Mar 8, 2016 at 8:58 PM
    DOGTRD
    DOGTRD The Dude Abides.....
    02 Xtra Cab
    Thanks bro!!! Will definitely post more pics soon.
    Speedytech7 likes this.
  2. Mar 8, 2016 at 9:07 PM
    TacoVio
    TacoVio Well-Known Member
    Kolton
    CO/WY
    R.I.P '04 Roy Super White ^^
    '00 Imperial Jade Flatty / '14 Spruce Mica, 6MT, Sick
    Good man! That's what I like to hear lol!
  3. Mar 8, 2016 at 9:15 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I've thought if getting some for my double cab. Also can't find photos. It would be about 1-1.5" taller then how my tent on Frank sits now though
  4. Mar 8, 2016 at 9:19 PM
    Tacomang
    Tacomang Well-Known Member
    Norcal
    Trd Taco
    Im also curious to see this. Im getting a cvt rtt this summer for camping trips and Im not sure which tent to get or which rack to mount it on. I have bilstein 5125s and dakars.
  5. Mar 8, 2016 at 9:21 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I can tell you this. Mount it as low as you can to make it fit your style. I had mine 14.5" above the bed rail and am now around 2-3". HUGE difference in handling. So worth it.
    And I'm all for the Bachelor or Shasta if you can spare the extra cash. I have a Shasta. Love it. Going on 4 years now
    FirstGen Jer likes this.
  6. Mar 8, 2016 at 9:24 PM
    Tacomang
    Norcal
    Trd Taco
    Haha funny you say that I was leaning toward the batchelor as well. And that makes sense about handling, on their website it says its almost 200lb! I was going to mount it pretty high so I could retain some height in my bed, but I guess that isnt such a good idea... which rack are you using?
  7. Mar 8, 2016 at 9:34 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Totally custom. It rasies and lowers. I built them both. Pre made ones your choices are pretty limited.
  8. Mar 8, 2016 at 10:02 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Really easy to remove the spindles, I'd just take em out and change the ball joints while you're in there.
    Reh5108 likes this.
  9. Mar 8, 2016 at 10:31 PM
    Tacomang
    Norcal
    Trd Taco
    Did you use aluminum? It cant be too hard to fab up a simple one..
  10. Mar 8, 2016 at 10:32 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    No steel.
    It's easy to do steel. Not so with aluminum. Shit is hard to weld with a spool gun and TIG is no easy matter either.
  11. Mar 9, 2016 at 12:16 AM
    alphabravo
    alphabravo Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    Mocking up for an LED light bar. Might go double 6" if single 20" is too tight. Would need an extra pair of down drops in that case.
    Anybody know how hard it would be to relocate the two AC hard lines? I don't understand why it wanders back and forth across the grill.
  12. Mar 9, 2016 at 12:30 AM
    Speedytech7
    Unless you know of a company or person willing to cut and braze lines together for you then it'd be pretty hard to move those as they have a special end on the part that mates to the receiver/dryer. Not worth it, just find a different way to mount the bar, likely just up slightly higher.
  13. Mar 9, 2016 at 12:37 AM
    DOGTRD
    02 Xtra Cab
    I installed a Rigid Industries dual row 30" bar in my lower grill with minimal trimming of the bumper support. 20160305_183305.jpg
  14. Mar 9, 2016 at 12:37 AM
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Well that's good to know. I was thinking maybe they were more like brake lines with a simple flare. Here is a closer pic of the two lines. There doesn't seem to be any reason for the line to stick out across the radiator when it could be like 12" shorter :crazy:
  15. Mar 9, 2016 at 12:38 AM
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Well as of last week I don't have a lower grill anymore so I'm back to finding room in the main grill.
  16. Mar 9, 2016 at 4:36 AM
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    Too poor to list anything interesting.
    Chipskip likes this.
  17. Mar 9, 2016 at 7:28 AM
    KeptOnChooglin
    KeptOnChooglin Well-Known Member
    Phil
    Houston, TX
    2003 Crew Cab PreRunner L4 Auto
    After seeing Seafoam at 11.99 at the local Advance Auto Parts, I ordered a case off Amazon for 80 shipped.
    JKU3000 likes this.
  18. Mar 9, 2016 at 7:38 AM
    j0shu4
    j0shu4 98 TRD 4x4, 3.4 Turbo, Full LT, Fully Locked
    98 TRD, Turbo, 3.4L, 4x4, LT
    Turbo, Fiberglass, Full Long Travel, Lockers, T100 axle, King Shocks
    Hey guys, need some help please.
    Any ideas on my speedometer? I shorted out a wire (smoked) on my old instrument cluster. I replaced it with another one from a salvage yard but the speedo still doesn't work properly. It's like way off. I'll be going 30 and it says 10. And it doesn't move regularly through the range like it did before. I was thinking VSS? Any ideas or suggestions?
  19. Mar 9, 2016 at 8:23 AM
    WheelInTheSky
    WheelInTheSky Ramblin' Man
    G
    Jackson Hole
    02 XtraCab 4x4 SR5-speed
  20. Mar 9, 2016 at 8:39 AM
    Robmonster117
    Robmonster117 Well-Known Member
    Robert
    Gilroy
    02 ext. cab 4x4
    Truck parts
    Yea Im definitely taking them out myself. Ive done it 3x over already so Im pretty good at it lol. My ball joints all less than a year old so I shouldn't need new ones unless they look messed when I get the spindles out
