  1. Mar 11, 2016 at 8:50 AM
    FirstGen Jer
    FirstGen Jer Well-Known Member
    Jeromey
    big bear lake, CA / lake havasu, AZ
    1999 toyota tacoma 3.4l v6 sr5 4x4
    What size you running? What you run the psi at? I'm running 285 ko2's.
  2. Mar 11, 2016 at 9:04 AM
    alee891
    alee891 Destination: unknown
    Austin
    Black Hills
    Tacomaless
    I have been eyeballing the STTs quite a bit, actually, so my decision isn't entirely made yet. The MTRs are always a contender. I've heard good and bad about all tires. The KO2s just seemed appealing given their use across the board. I'll be going with steel 17's, just trying to determine what I need for backspacing at the moment. My rig isn't daily driven.
  3. Mar 11, 2016 at 9:09 AM
    TacoVio
    TacoVio Well-Known Member
    Kolton
    CO/WY
    R.I.P '04 Roy Super White ^^
    '00 Imperial Jade Flatty / '14 Spruce Mica, 6MT, Sick
    I'm goin with like a lot lol I've put a 35x12.5 on my truck up front on a 15 with 3.75 and I could barely turn lol! But I think a 17" 35 is only like 12" wide correct?
  4. Mar 11, 2016 at 9:14 AM
    alee891
    Austin
    Black Hills
    Tacomaless
    They are 35x12.5x17. I'm looking at these wheels specifically: http://www.summitracing.com/parts/pcw-98-7983s3-5/overview/
    Not a huge fan of Summit due to past ordering issues, but they are the only place I could find 17x9s with 3.5 backspacing. I have spacers right now that I can use if the frame rub is that bad.
  5. Mar 11, 2016 at 9:35 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I'm running 265/75/16, BTW with metric sizes you really need all the numbers to identify the sizes. All 285 tells me is that it is 285mm wide. I run the front at 34psi and the rear at 32psi. How do you like em?
  6. Mar 11, 2016 at 9:38 AM
    Speedytech7
    Yeah, if it isn't daily driven I think there are much better tire choices out there. Mine is a DD, if it wasn't I'd be thinking STTs or MTR, really want MTRs when I jump up to 33 or 34.
  7. Mar 11, 2016 at 9:46 AM
    chowwwww
    chowwwww Well-Known Member
    Orange County
    03 Doublecab 4x4
    Billys 5100/Eibach and Wheelers Progressive 1.5 AAL with overload in
    I still cant decide if I want to stick with 16in wheels or move to 15in wheels. If I decide to stay with 16in then I will surely do the tundra.
  8. Mar 11, 2016 at 9:47 AM
    chowwwww
    Orange County
    03 Doublecab 4x4
    Perhaps I will go this route for the time being until I decide whether or not to stick with 16in wheels. Thanks for you input.
  9. Mar 11, 2016 at 9:50 AM
    alee891
    Austin
    Black Hills
    Tacomaless
    KO2s are still in consideration. I'll post up once I decide on a tire. I need to figure out a gawt damn wheel first!
  10. Mar 11, 2016 at 9:59 AM
    FirstGen Jer
    Jeromey
    My bad, they are 285/75/16. Guess most of the first gen guys I talk to running these is the 285/75/16. I really like them so far. I live in the mountains so they see a lot of snow and have performed well. Think I'm going to try them at 34-35 psi. Why do run the rear lower?
  11. Mar 11, 2016 at 10:07 AM
    Robmonster117
    Robmonster117 Well-Known Member
    Robert
    Gilroy
    02 ext. cab 4x4
    Truck parts
    Really thats surprising. Just to get my 33s to fit i had to trim the seam welds and beat the inner to hell to stop rubbing at full stuff/ and full lock.
  12. Mar 11, 2016 at 10:15 AM
    Speedytech7
    The front has more weight and they squish down a bit more I run lower pressure to get the same contact patch in the rear, just keeping even wear.
    FirstGen Jer[QUOTED] likes this.
  13. Mar 11, 2016 at 10:26 AM
    TacoVio
    Kolton
    CO/WY
    I think you'll rub but not too horribly bad!
  14. Mar 11, 2016 at 10:39 AM
    alee891
    Austin
    Black Hills
    Tacomaless
    Hopefully wheel bs and spacers can take care of it! And tubbing, of course:stirthepot:
  15. Mar 11, 2016 at 10:44 AM
    TacoVio
    Kolton
    CO/WY
    Yeah but tubbing will probably suck balls lol! How do you tub the wheel wells anyway? BFH lol
  16. Mar 11, 2016 at 10:48 AM
    Speedytech7
    You don't have to tub the front so much as remove parts of firewall/footwell and sliders to make enough room, there's no way to go further up. The back is as simple as cutting the arch a bit.
  17. Mar 11, 2016 at 10:48 AM
    alee891
    Austin
    Black Hills
    Tacomaless
    Cut out what you need to clear the tire, weld in a new piece of metal to fill the hole. BFH was good for 285s, but I'll need more room for the 35s now.
  18. Mar 11, 2016 at 10:48 AM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Cut a lot and weld :sawzall::welder:
  19. Mar 11, 2016 at 10:50 AM
    TacoVio
    Kolton
    CO/WY
    Sounds terrible unless you have a plasma cutter and good welder I guess lol
  20. Mar 11, 2016 at 10:51 AM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    I have no plans to do that haha. I'll stick with 285's when the time comes!
