  1. Mar 21, 2016 at 1:42 PM
    FirstGen Jer
    FirstGen Jer Well-Known Member
    Jeromey
    big bear lake, CA / lake havasu, AZ
    1999 toyota tacoma 3.4l v6 sr5 4x4
    thanks, ya I have takin a look a marlins custom one before. I have been looking at these though
    652824_7958004d3e9b4112ab6b6a063139e58a.jpg_srz_p_560_374_75_22_0.5_1.jpg 652824_fe76231a749343289e2c059fec8b7482.jpg_srz_p_560_374_75_22_0.5_1.jpg
    SWYPER likes this.
  2. Mar 21, 2016 at 2:08 PM
    YotaTank
    YotaTank Well-Known Member
    Road Salt Hell
    1995 Tacoma SX 4x4
    Did the deckplate mod. Ran it with the K&N drop in filter beforehand and it helped slightly with MPG and air flow. With the deck plate open throttle response is a bit better.
  3. Mar 21, 2016 at 4:20 PM
    WheelInTheSky
    WheelInTheSky Ramblin' Man
    G
    Jackson Hole
    02 XtraCab 4x4 SR5-speed
    Bent a tie rod end in J Tree couple days ago. Replaced it as well as the inner yesterday. Seems impossible to find a replacement boot with a clamp...
  4. Mar 21, 2016 at 4:22 PM
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    I just got one of camelback and used a zip tie.
  5. Mar 21, 2016 at 4:24 PM
    WheelInTheSky
    G
    Jackson Hole
    Ok, I'll order a couple and replace those at the same time I replace my cv's. They started leaking pretty bad a couple days ago:pout:
  6. Mar 21, 2016 at 4:26 PM
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    My driver's side tie rod boot has been oil stained for two years now....alignment holds true.... soo :notsure:
  7. Mar 21, 2016 at 4:45 PM
    gray223
    SE Missouri
    2014 Tundra Limited
    I think its that you can get dirt in there if its ripped and wear the tie rod out sooner.
  8. Mar 21, 2016 at 4:52 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    The boot is there more to protect the rack cylinder seals. With that said, you would have to do some extreme wheeling on a regular basis to make those part wear out faster with torn boots. Most mall crawlers won't see those parts wear out from bad boots.
  9. Mar 21, 2016 at 5:14 PM
    FirstGen Jer
    Jeromey
    So opening my hood just got a lot cooler!:rofl: Ordered these bad boys today through the group buy
    My wallet cringes now every time I open up a group buy thread
  10. Mar 21, 2016 at 7:51 PM
    JBTacoma
    JBTacoma Well-Known Member
    Jeff
    Cullman Alabama
    2000 SR5, 2003 Double Cab and a Suzuki Samurai
    "disconnect the alternator from the fuse box by disconnecting the "WHITE" wire inside the fuse box and tape it up good. Then run a bigger wire from the alternator to the 150amp breaker and then to the + side of the battery."
    That should be all you need to do, didn't you say you already upgraded all your ground wires?
  11. Mar 21, 2016 at 8:20 PM
    alphabravo
    alphabravo Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    My wire colors are different now but I think the white wire was the one that went in the bottom of the fuse box and then secured with a nut at the top.
    I did the @BamaToy1997 Big 3 (actually big 4) several months ago and just got the all the heat shrink finished today. I didn't notice when I did the upgrade but I see that both wires from the fuse box go to the battery now (redundant) so I don't have to worry about the alternator going through the fuse box anymore. I'll install a 250A ANL fuse between the alternator and the battery.
    Also gonna finish the mockup on the battery install.
  12. Mar 21, 2016 at 8:42 PM
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
    So if I want to color match a plate bumper what's the best way to do that, duplicolor color match cans?
  13. Mar 21, 2016 at 8:45 PM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    I don't think I've ever seen a good looking color matched plate on 1st gens. 2nd gens don't turn out too badly because they're already boxy, but first gens have more curves and a "look at me" plate bumper just doesn't go well with the lines.
    BUT, yea using anything that is specific to your paint code will work.
  14. Mar 21, 2016 at 8:53 PM
    TashcomerTexas
    I agree with that sentiment, however given my front end "cool factor" at a bedazzling 7.9/10 I'm trying to visualize how this would look in red
    JKU3000 and SWYPER like this.
  15. Mar 21, 2016 at 8:57 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Not good.
    Would not do it
    Chipskip and because_wumbo-truck like this.
  16. Mar 21, 2016 at 8:58 PM
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    2002 Toyota Tacoma 4WD
    Check Build
    Dang, what a great photoshop job.
  17. Mar 21, 2016 at 8:59 PM
    koditten
    Kirk
    Central Michigan
    I don't think it would look good colored either.
    because_wumbo-truck likes this.
  18. Mar 21, 2016 at 9:01 PM
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Hiya Tash.
    Long time no see.
    Yeah, I think the color match would have to be factory color codes and professionally primered and painted in order not too look cheap and matchy matchy.
    TashcomerTexas likes this.
  19. Mar 21, 2016 at 9:02 PM
    TashcomerTexas
    I know right. I had to fish that out.
    I'm on the fence.
  20. Mar 21, 2016 at 9:03 PM
    because_wumbo-truck
    because_wumbo-truck TTC#036 1st Degenerate Urban Off-Roader
    Jon
    Houston, Texas
    2006 Gordita Blanca V8 4x4 aka "Penelope"
    Sliders and bumper, DDI injectors, flowmaster 40
    That looks good. The color match is a no from me.
