  1. Mar 25, 2016 at 12:16 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Not sure what that trim piece is called specifically, are you in need of new ones?
  2. Mar 25, 2016 at 12:17 AM
    LogCabins
    LogCabins Well-Known Member
    Robert
    Oahu
    99 SR5 3.4L 4WD
    Yes indeed, I mean mine aren't totally fubared but the pretty much just lay in there since the clip on the backsides are all broken
  3. Mar 25, 2016 at 12:23 AM
    LogCabins
    Robert
    Oahu
    99 SR5 3.4L 4WD
    Think I found it...moulding, side door step plate
  4. Mar 25, 2016 at 12:24 AM
    Speedytech7
    Ahh, good luck. Hopefully someone still has them
  5. Mar 25, 2016 at 12:31 AM
    LogCabins
    Robert
    Oahu
    99 SR5 3.4L 4WD
    Hope so.....and I'm back to square 1 that wasn't it :facepalm:
  6. Mar 25, 2016 at 12:36 AM
    LogCabins
    Robert
    Oahu
    99 SR5 3.4L 4WD
    Scuff plate!
    Speedytech7 likes this.
  7. Mar 25, 2016 at 12:38 AM
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    I need those too
  8. Mar 25, 2016 at 12:42 AM
    LogCabins
    Robert
    Oahu
    99 SR5 3.4L 4WD
    Well figured out what they are called....search scuff plate, extended cab.....pretty sure that is it
  9. Mar 25, 2016 at 12:48 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    To add to the discussion: The scuff plates are the same for a standard cab as for an extended cab. I own both and recently compared. I don't know if four door trucks are the same.
    LogCabins likes this.
  10. Mar 25, 2016 at 2:34 AM
    alphabravo
    alphabravo Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    Got some rubber caps for my shock bolts to keep the threads clean. Seems silly but I had to clean the threads whenever I pulled the shocks otherwise the studs backed out of the aluminum shock head. Better now that I set them with red Locktite and the caps will help.
    Finally got the battery cage hold downs fabbed up and installed the 31 series battery.
    One without the battery. Modified cage to use stock hardware plus the bracket and sleeve nut I had to machine.
    Also replaced the gasket on the air box intake.
    BYJOSHCOOK and JPinFL like this.
  11. Mar 25, 2016 at 4:51 AM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
  12. Mar 25, 2016 at 6:58 AM
    TacoVio
    TacoVio Well-Known Member
    Kolton
    CO/WY
    R.I.P '04 Roy Super White ^^
    '00 Imperial Jade Flatty / '14 Spruce Mica, 6MT, Sick
    Drove to Wyoming this morning to look at UW
    BYJOSHCOOK and FirstGen Jer like this.
  13. Mar 25, 2016 at 7:05 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Nice. UW is good. I hate Laramie though.
    @alphabravo where did you get the caps? Be just nice to not have to clean the dirt and mud off every time
  14. Mar 25, 2016 at 7:11 AM
    TacoVio
    Kolton
    CO/WY
    Lol why do you hate Laramie!! I think it's a pretty cool town...well comparing it to Pueblo lol! Where are you at? Other than St. Louis
  15. Mar 25, 2016 at 7:30 AM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    I'm pretty sure most everywhere looks cool compared to Pueblo.....
    CU alum here. Not much against UW though.
  16. Mar 25, 2016 at 7:34 AM
    TacoVio
    Kolton
    CO/WY
    Yeah pueblos sucks... CU is still pretty big though! Wish I was graduated :(
  17. Mar 25, 2016 at 7:38 AM
    bowyer2002
    bowyer2002 always tinkering
    NE Missouri
    01 Taco SR5 D-cab 4WD
    OME 882s, OME shocks all around and OME Dakar spring packs, ARB, Warn 8000, ARE shell, Custom rear bumper w/ reciever, 5-235/80R17 Cooper Discoverer ST MAXX on FJ wheels, grey wire mod, Hi-Lift, Hellas, Red-Line hood lifters, Scion radio, sliders, Safari snorkel & LED Ditch lights on CBI mounts.
    Thanks a bunch!
    I have access to a full size plotter/printer so I can pdf these, scale them to 1:1 and have an instant pattern.
    Thanks again for your help!
  18. Mar 25, 2016 at 9:18 AM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    When I lived in the Springs back in 2005 and before Pueblo sucked haha
    TacoVio[QUOTED] likes this.
  19. Mar 25, 2016 at 9:26 AM
    JBTacoma
    JBTacoma Well-Known Member
    Jeff
    Cullman Alabama
    2000 SR5, 2003 Double Cab and a Suzuki Samurai
    Your welcome
    The full sized pattern is in the attached pdf for anyone that does not have access to a full size plotter/printer. You can print them on any printer.
  20. Mar 25, 2016 at 10:21 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    the bottom one looks like a dog outline ;)
