  1. Mar 26, 2016 at 9:04 PM
    WildLand
    WildLand Does Ursus arctos defecate in deciduous forest?
    Josh
    NM
    16T4RSR54WD
    Yeah I guess I should move the bump back up to keep it steady.
    It is a used hood so that may be a problem (did a conversion to this year). I think it has something to do with the latch not holding it tight enough.
    I'll see if my latch is bolted too high and see if I can lower it a few cm to maybe hold it better
  2. Mar 26, 2016 at 9:26 PM
    alphabravo
    alphabravo Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    Anybody have a preference on towing shackles. The new warn ones look nice but I'm not sure they are worth a Ulysses S Grant each :D especially now that I have 4 spots for them.
  3. Mar 26, 2016 at 9:45 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    Go with DZUS fasteners !!!!
  4. Mar 26, 2016 at 10:12 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Looks like it lights up a wide area, nice! :D
  5. Mar 26, 2016 at 10:14 PM
    Speedytech7
    I need to buy more pods so I can fill the bumper, which ones you get?
  6. Mar 26, 2016 at 10:20 PM
    Speedytech7
    I'll reweld the mounts if need be, thanks I'll buy some of those.
  7. Mar 26, 2016 at 10:33 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Id get the new 40w 3" pods you can get now.
  8. Mar 26, 2016 at 11:04 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Of course you would captain light
  9. Mar 26, 2016 at 11:11 PM
    thumper72
    thumper72 Well-Known Member
    Jon
    Ogden Utah
    2000 toyota tacoma prerunner v6 auto
    5100's, ome dakar leafs and ome coils, problem solver tie rods, eazycompany ditch light brackets and auxbeam osram 4" led pods, 2014 4runner wheels, 265/70/17 goodyear authority tires, soon to have 50" led bar on roof
    Installed some lights and ditch brackets.. Now to get them all wired up...
  10. Mar 26, 2016 at 11:34 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Be awesome. Probably what i'll get too
  11. Mar 26, 2016 at 11:34 PM
    Adventurer_Alex
    Adventurer_Alex Generic mall crawler
    Alex
    AZ
    2013 Nissan XTERRA
    @m3bassman what are you planning for the back seat area?
  12. Mar 26, 2016 at 11:41 PM
    BroTaco
    BroTaco Well-Known Member
    Ian
    Cashmere, WA
    2017 TRD OR
    5 gallons of emergency fuel. Now I can enjoy 60-75 more miles of trail
    And took off the flares to see how it would look. I like it
  13. Mar 27, 2016 at 7:41 AM
    Gear Head
    Gear Head Well-Known Member
    Jacob
    Winston Salem, NC
    96 Tacoma
    fj60 front, fj80 rear, full hydro, 5.29's, welded, twin sticked 2.28/4.70 duals, 39.5's, inboarded 63's
    PSA: If you don't carry a fire extinguisher, spend the $30 and pick one up. My truck caught fire yesterday while wheeling and thankfully I had one on hand. $30 could save your rig or someone else's from burning to the ground.
    Got a little warm under there
  14. Mar 27, 2016 at 7:59 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yep!
  15. Mar 27, 2016 at 8:35 AM
    mountain mike
    mountain mike Woodsbum
    the backwoods...
    2003 DCSB 4x4
    just what I need to do what I want
    Then I did this, Coxey Road-AppleValley to Holcomb Valley. Big Bear (So Cal)Big Bear Feb 2016 #2.jpg
    JKU3000, tacomatrd22, SWYPER and 3 others like this.
  16. Mar 27, 2016 at 9:31 AM
    Digiratus
    Roaming the PNW
    The RedHead
    It all depends on placement and their planned use. I got the rugged ridge pods, and amber covers for them, because I wanted them as daytime driving lights. Essentially so I can be seen during the daytime rather than them helping me see at night. Tho, with the amber covers, it may help a tiny, tiny bit in foul weather, at night.
    Without the covers, these are just barely on the edge of being obnoxious to other drivers. So for everyday use they are ok. I feel like a 40 watt pod would be too much for my purpose.
    Unfortunately, there will be more road noise come though the back wall without those panels. I put in some sound deadener and it did cut that down.
  17. Mar 27, 2016 at 9:54 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Eh. Dtrl I justhave my marker lights on. Or mirror lights.
  18. Mar 27, 2016 at 10:14 AM
    scocar
    scocar Patron of the Farts
    Trips in the dark, goes Full Monte.
    Alternative B:
    Or the Full Monte version
    Blackdawg, Chipskip and SWYPER like this.
  19. Mar 27, 2016 at 10:23 AM
    98 Taco Max
    98 Taco Max Well-Known Member
    Max
    Calgary, AB
    v6 Tacoma 4x4
    Glad you saved it before it got out of hand! Looks like Turbo got too hot?
  20. Mar 27, 2016 at 10:29 AM
    WildLand
    Josh
    NM
    16T4RSR54WD
    Through the hood?
