  1. Mar 27, 2016 at 9:36 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Idaho Point?
  2. Mar 27, 2016 at 9:51 PM
    Digiratus
    Roaming the PNW
    The RedHead
    That trip was lots of fun
  3. Mar 27, 2016 at 10:42 PM
    Adventurer_Alex
    Adventurer_Alex Generic mall crawler
    Alex
    AZ
    2013 Nissan XTERRA
  4. Mar 28, 2016 at 3:15 AM
    Bobert14
    Bobert14 .
    Finally got my rear shocks back on. Couldn't find anyone to charge them after I rebuilt them, so now I have my own nitrogen set up!
    koditten likes this.
  5. Mar 28, 2016 at 3:49 AM
    alphabravo
    alphabravo Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    Completely tore down the front end to clean and regrease everything with SuperLube instead of the Redline I had in there. That SL is awesome. It plays nice with my poly bushings so no more squeaks. It doesn't stain everything like Redline and works nice in a grease gun. Also it is food grade so you can use it on your toast if you run out of butter.
    LCA bushings regreased.
    New bolts and boots for the LBJ that I installed a couple of months ago.
    Mocked up the limit straps for the control arms.
    Crock112 and FirstGen Jer like this.
  6. Mar 28, 2016 at 4:17 AM
    Boerseun
    Boerseun Well-Known Member
    Ferdie
    Sarasota, Florida
    2018 Tundra TRD Sport 4x4
    Upgraded 2002 Tacoma to 2018 Tundra
    White out. Black in.
  7. Mar 28, 2016 at 6:08 AM
    FirstGen Jer
    FirstGen Jer Well-Known Member
    Jeromey
    big bear lake, CA / lake havasu, AZ
    1999 toyota tacoma 3.4l v6 sr5 4x4
    Mmmmm toast:sandwich: :rofl:
  8. Mar 28, 2016 at 6:49 AM
    KeptOnChooglin
    KeptOnChooglin Well-Known Member
    Phil
    Houston, TX
    2003 Crew Cab PreRunner L4 Auto
    Mazola-Lube!
  9. Mar 28, 2016 at 7:30 AM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    Just missing the Factor 55 thimble. Then you're ready for anything.
  10. Mar 28, 2016 at 9:48 AM
    BenCO
    BenCO Well-Known Member
    CO
    04 Tacoma DC 4x4
    FirstGen Jer likes this.
  11. Mar 28, 2016 at 11:06 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Went and tried to call in some coyotes. Got a little distracted and ended up at Moonshine Arch. Really isn't a bad trail, most people just take their side by sides or walk.
    Look what I found on the trail.
    Yes my frame has some rust.
  12. Mar 28, 2016 at 12:08 PM
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Backup floods from Amazon (about $40 I think for the pair).
  13. Mar 28, 2016 at 12:25 PM
    ClevSix
    ClevSix Well-Known Member
    IL/IA
    01 DCSB SR5 TRD, 13 T4r SR5
    Suspension, 33s, some armor... Rust, Gray wire and 2Low, and more. T4r is stock.
    Isn't that a cute little jack...
  14. Mar 28, 2016 at 12:35 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    Aint about the size. Its about how you use it. :spy:
  15. Mar 28, 2016 at 12:48 PM
    JKO1998
    Utah
    Hey dude, it was free
  16. Mar 28, 2016 at 12:54 PM
    Beee1985
    Beee1985 Well-Known Member
    That is a gorgeous grill and headlight mod you got there.
  17. Mar 28, 2016 at 12:58 PM
    Beee1985
    Replaced the oil in the rear end, the took Aspen for a drive up the mountains. Rear ends are fun ;)
  18. Mar 28, 2016 at 1:01 PM
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    2002 Toyota Tacoma 4WD
    Check Build
    Thanks man! Changing up the headlights here soon.
  19. Mar 28, 2016 at 1:46 PM
    quetzal
    quetzal Well-Known Member
    Mario
    Long Beach, CA
    '02 XtraCab SR5 TRD 4x4 5spd
    All-Pro UCAs, King 2.5 C/Os, All-Pro Expo Leafs, Bilstein 10" Shocks
    Question regarding rear shocks and All-Pro Expo Leafs:
    Hey guys,
    I've been doing a lot of reading and am still a little confused. I want to purchase a set of AP Expo leafs to replace my sagging Deaver F42s. In the stock location, what size shock should I get? Can I run some Bilstein 5125s (8",8.5") or longer shocks?. Thanks guys.
  20. Mar 28, 2016 at 1:58 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    you'll likely need 9-10'' shocks as you'll have so much lift. BUT you will probably also have to extend your bump stops to keep from bottoming out the shocks.
    The best way to to measure yourself after you get the leafs.
    quetzal[QUOTED] likes this.
