  1. Mar 29, 2016 at 8:50 PM
    ClevSix
    ClevSix Well-Known Member
    IL/IA
    01 DCSB SR5 TRD, 13 T4r SR5
    Suspension, 33s, some armor... Rust, Gray wire and 2Low, and more. T4r is stock.
    Agreed on both counts. It is possible mine started to sag or the PO wanted more lift.
  2. Mar 29, 2016 at 8:50 PM
    TacoVio
    TacoVio Well-Known Member
    Kolton
    CO/WY
    R.I.P '04 Roy Super White ^^
    '00 Imperial Jade Flatty / '14 Spruce Mica, 6MT, Sick
    I'd say yeah but fitting 35's has a lot to do with tubbing and a lot of trimming and cutting even if you have 3"+ of lift.
    EDIT: That's if you, persay, actually wheel it. Ask @Blackdawg what it takes to fit 35's he has a really good write up for tubbing/trimming/cutting for clearance when under flex
  3. Mar 29, 2016 at 9:06 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
  4. Mar 29, 2016 at 9:17 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    You can crank them up just fine. I would wait till you have a bumper or something so it won't be quiet as stiff. Can always swap coils too.
    Yes..and no..
    The 5 Luger fenders will bolt right up. However. They have no flare at all. Stock 4wd fenders flare about 1.5" or 2" compared to the 5 Lugers. I have some photos with some 5 lugger fenders on. Doesn't look good and didn't line up with my bumper
  5. Mar 29, 2016 at 9:41 PM
    RustyVT
    RustyVT Well-Known Member
    Vermont
    98 4Runner limited, 12 S60 T6
    OME overload springs, airlift bags, Hayden 679, 33x12.5 X-ATs
    Well, looks better than what I got I'm sure lol.
  6. Mar 29, 2016 at 9:52 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Ouch.
    Yea. But you can buy new fenders pretty cheap new.
  7. Mar 29, 2016 at 10:07 PM
    RustyVT
    Vermont
    I was most likely gonna go that route if it didn't sell. I may end up keeping the thing but in reality I just want it gone. Didn't wanna dump any real money into it. It's back on all 4s now and driving but I'm having a hell of a time selling it.
  8. Mar 29, 2016 at 10:31 PM
    Willbeck
    Willbeck Well-Known Member
    Will
    Huntington Beach
    00 Reg Cab 4x4
    Bug deflector
    I paid $400 for mine. Rebuilt them with a $25 seal kit, and they're good as new.
  9. Mar 29, 2016 at 10:33 PM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    Out of curiosity how much are you asking for?
  10. Mar 29, 2016 at 10:33 PM
    Willbeck
    Will
    Huntington Beach
    00 Reg Cab 4x4
    Bug deflector
    Picked up a bar for my truck. Anyone mounted a 30" bar in the front of a 98-00'? Need to do more fiddling S, but if anyone has pictures I'd like to see what you did to mount it.
    SWYPER likes this.
  11. Mar 29, 2016 at 10:34 PM
    Willbeck
    Will
    Huntington Beach
    00 Reg Cab 4x4
    Bug deflector
    2nd post because I have no clue how to properly attach multiple files from an iPad.
    JKU3000 likes this.
  12. Mar 29, 2016 at 10:34 PM
    Digiratus
    Roaming the PNW
    The RedHead
    If you have access to a spring compressor and way to recharge them with nitrogen, then that job isn't too bad.
  13. Mar 29, 2016 at 10:36 PM
    Willbeck
    Will
    Huntington Beach
    00 Reg Cab 4x4
    Bug deflector
    Did mine with an autozone set (don't recommend it) and shop air till I was able to charge them properly. Can be done in an afternoon with simple hand tools.
  14. Mar 29, 2016 at 10:38 PM
    Digiratus
    Roaming the PNW
    The RedHead
    There is no way I would do my 700# coils with a vatozone coil compressor. Waaaaaaaay to scary.
  15. Mar 29, 2016 at 10:39 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    best way is to make brackets off the frame horns. Should be pretty easy with some angle iron and drill bit.
  16. Mar 29, 2016 at 10:42 PM
    Willbeck
    Will
    Huntington Beach
    00 Reg Cab 4x4
    Bug deflector
    That's what I am thinking, no crash bar on mine...
  17. Mar 29, 2016 at 10:43 PM
    Willbeck
    Will
    Huntington Beach
    00 Reg Cab 4x4
    Bug deflector
    Haha yeah, the 600's were quite sketchy.
  18. Mar 29, 2016 at 10:43 PM
    thumper72
    thumper72 Well-Known Member
    Jon
    Ogden Utah
    2000 toyota tacoma prerunner v6 auto
    5100's, ome dakar leafs and ome coils, problem solver tie rods, eazycompany ditch light brackets and auxbeam osram 4" led pods, 2014 4runner wheels, 265/70/17 goodyear authority tires, soon to have 50" led bar on roof
  19. Mar 29, 2016 at 10:47 PM
    RustyVT
    Vermont
    Trying to get 1350 out of it. If it doesn't sell its getting a flatbed, tube bumper and bed liner paint. It's not in great shape by any means. But for 1350 you can't buy crap around here that runs and drives.
  20. Mar 29, 2016 at 10:50 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    So what you're saying is $850 buys it and ships it to my doorstep. :evil:
    Haha jk, I can't even swing $20, stupid textbooks have me by the nuts right now.
    JKU3000 likes this.
