  1. Apr 4, 2016 at 10:52 AM
    Robmonster117
    Robmonster117 Well-Known Member
    Robert
    Gilroy
    02 ext. cab 4x4
    Truck parts
    Ran Into a little snag with my skidplates. Turns out I dont have the second skid mounting points because they were cut out when the PO installed the drop bracket. Seems like my only option is to weld some plates back to those spots, drill and tap holes to mount the skids. Anyone have any easier suggestions? I got no pics right now..
  2. Apr 4, 2016 at 10:58 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    I just got told it was gonna be 50$ to check the nitrogen in my Kings. All you have to do is unscrew the cap and put the gauge on right? Like a tire? The shocks aren't even on the truck.
  3. Apr 4, 2016 at 10:59 AM
    thumper72
    thumper72 Well-Known Member
    Jon
    Ogden Utah
    2000 toyota tacoma prerunner v6 auto
    5100's, ome dakar leafs and ome coils, problem solver tie rods, eazycompany ditch light brackets and auxbeam osram 4" led pods, 2014 4runner wheels, 265/70/17 goodyear authority tires, soon to have 50" led bar on roof
    lol call a bike shop and ask them how much to check it... thats what i did on my old saw's
    Speedytech7 likes this.
  4. Apr 4, 2016 at 11:00 AM
    JKO1998
    Utah
    Will they do nitrogen though? Do you have to have a special gauger thing.
  5. Apr 4, 2016 at 11:00 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    While that sounds like a PITA the good thing is that you can make it ten times stronger than stock was.
  6. Apr 4, 2016 at 11:04 AM
    thumper72
    Jon
    Ogden Utah
    nitrogen is used in my shocks on my specialized mtb and i just walked in and asked and the guy said np at all.. so your results may vary but call and ask
  7. Apr 4, 2016 at 11:06 AM
    thumper72
    Jon
    Ogden Utah
    does anyone know if you happen to get 33*10.5*15 tires if you have to do pinch mod or a cab mod at all? just a future reference question is all...
  8. Apr 4, 2016 at 11:06 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Yeah, the bike shops around here are pretty cool about using special tooling to help out our local offroad guys too. They should be able to charge shocks no prob @JKO1998 if they say they have the nitrogen.
    Sounds like you encountered a suspension shop that likes "bread and butter" work, shit that makes a lot of money because it "seems" complicated. Like charging shocks or installing lift kits, charging a lot for literally just turning a wrench, no fab work or design. 4WP is a great example of a place that pulls this kind of garbage.
  9. Apr 4, 2016 at 11:23 AM
    Robmonster117
    Robert
    Gilroy
    02 ext. cab 4x4
    Truck parts
    This is true, might even tac weld a nut behind the plate for redundancy. Theres always a bright side I guess
  10. Apr 4, 2016 at 11:27 AM
    Speedytech7
    Definitely want to do that, I don't think just a tapped plate, unless it's quarter inch would be strong enough if something grabbed the edge of the skid. Hardware is usually heat treated or hardened to a certain degree whereas threads carved in regular plate steel may not be.
  11. Apr 4, 2016 at 11:29 AM
    Robmonster117
    Robert
    Gilroy
    02 ext. cab 4x4
    Truck parts
    Some light trimming and some love taps with the sledge hammer should be all that you need.
    I still rub a bit at full lock and stuff but nothing major
  12. Apr 4, 2016 at 11:35 AM
    ClevSix
    ClevSix Well-Known Member
    IL/IA
    01 DCSB SR5 TRD, 13 T4r SR5
    Suspension, 33s, some armor... Rust, Gray wire and 2Low, and more. T4r is stock.
    For $90ish you can get the gauge from King and do it yourself.
  13. Apr 4, 2016 at 11:38 AM
    Robmonster117
    Robert
    Gilroy
    02 ext. cab 4x4
    Truck parts
    Thats what I was thinking too its going to be a while before I have time to do this so the skids will be sitting for a while. Gotta upgrade my welder game soon. All I got is my gramps old stick welder. Thinking about getting a miller 211.
  14. Apr 4, 2016 at 11:50 AM
    quetzal
    quetzal Well-Known Member
    Mario
    Long Beach, CA
    '02 XtraCab SR5 TRD 4x4 5spd
    All-Pro UCAs, King 2.5 C/Os, All-Pro Expo Leafs, Bilstein 10" Shocks
    I'm having the same issue with my Kings. You need the spherical bearing. I'm still doing my research on the part number but this one looks like it might be it. Googl search: spherical bearing fkb-wssx10t.
    Good luck.
  15. Apr 4, 2016 at 11:57 AM
    JKO1998
    Utah
    Checked with 5 or 6 shops.... No one does it. Fingers crossed on the bike shop I guess.
  16. Apr 4, 2016 at 12:00 PM
    tacomatrd22
    tacomatrd22 TRD SuperCharged Tacoma
    Daniel
    Fort Smith, AR
    Supercharged tacoma
    FlowMaster Super 44 2" lift Gray wire Fog light
    Thanks! Good to know before hand.
    At least you have a better filter than mine lol I'm still running that crummy K&N oil air filter and heard that dirt gets past that filter and into the engine.
  17. Apr 4, 2016 at 12:01 PM
    JKO1998
    Utah
    I don't think I need these. I think my shocks are ready to go just wanna double check the pressure. Might end up running out to the city and having it done there.
    quetzal[QUOTED] likes this.
  18. Apr 4, 2016 at 12:14 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Save me a search since I'm on this thread all the time and you guys know your shocks. What kinds of N2 pressure do those shock run at?
  19. Apr 4, 2016 at 12:22 PM
    JKO1998
    Utah
    To be honest, I don't know. I was gonna see what they're at and go from there.
  20. Apr 4, 2016 at 12:26 PM
    Crock112
    Crock112 Well-Known Member
    Crock
    New England
    '04 2.7l SR5 4x4 xtracab
    The original factory battery gave up the ghost in my '04 this morning. Figures I have to do a parking lot battery swap in the middle of a friggin snowstorm in april...
