  1. Apr 5, 2016 at 9:18 AM
    MatthewMay1
    MatthewMay1 I'm an amateur professional.
    Matthew
    Lone Star Republic
    Supercharged '01 TRD
    Anybody know what is needed in order to get a 2nd gen Softtopper to fit on the 1st gen bed?
    Edit: I found the answer.
  2. Apr 5, 2016 at 9:18 AM
    FirstGen Jer
    FirstGen Jer Well-Known Member
    Jeromey
    big bear lake, CA / lake havasu, AZ
    1999 toyota tacoma 3.4l v6 sr5 4x4
    Thanks! Ya I read the old seat is usually disintegrated. Was going to use a shop vac as I go in there so none falls through. Is there a seal that is supposed to go under the seat? Also what type of grease is good to use?
  3. Apr 5, 2016 at 9:22 AM
    Gear Head
    Gear Head Well-Known Member
    Jacob
    Winston Salem, NC
    96 Tacoma
    fj60 front, fj80 rear, full hydro, 5.29's, welded, twin sticked 2.28/4.70 duals, 39.5's, inboarded 63's
    My electrically inclined buddy has a log in to one of those sites and we used that last time but he's busy all week so I'm trying to see where I can get.
    I'll start a thread later today when i get off work and tag you in it if you would be willing to help out
  4. Apr 5, 2016 at 9:23 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    No seal, it won't fit if you leave that old rubber seal that was under the stock seat. I used some basic red NLGI 2 Lithium grease I think. I assume your using the marlin seat. Don't worry if a piece here or there falls in, its rubber and shouldn't mess anything up. I scooped it clean with my fingers :p but mine was basically putty. Couldn't get into 3rd or 4th without pulling the shifter up, was annoying.
  5. Apr 5, 2016 at 9:25 AM
    Speedytech7
    Always willing to lend a hand, I can give you a link to the FSM as well.
  6. Apr 5, 2016 at 9:35 AM
    FirstGen Jer
    Jeromey
    OK cool. Ya I read on some guys thread there was a seal that go's under the seat. I just received the seat and socket from marlin crawler this morning. They actually made a mistake and sent me two of each and told me to just keep them! :yes:
    My shifter is just real sloppy and there is no resistance to keep it in 1st gear if I hit a bump or something it will just pop out. So I hope this will do the trick from what I have heard.
  7. Apr 5, 2016 at 9:36 AM
    Gear Head
    Jacob
    Winston Salem, NC
    96 Tacoma
    That would be awesome. I found a bunch of links for the full PDF version that was circulating years ago but I'm pretty sure the original poster received a takedown notice so all the links are dead.
  8. Apr 5, 2016 at 9:37 AM
    Speedytech7
    Cool, I'll dig it up when I get home!
  9. Apr 5, 2016 at 10:30 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    I finally found a shop that'll do my shocks.... But they won't just check, they will only recharge, which is still cheaper than. 3 hour drive.
    Anyway, what's a good all around nitrogen psi, I guess that's what it's be?, to put inside my shocks. I do a lot of on the pavement driving but I also a lot of dirt road/ trail driving. I'd say about 55/45. Any recommendations?
  10. Apr 5, 2016 at 10:40 AM
    JKO1998
    Utah
    I'd like it to have a kinda soft ride. Not like feather pillow soft but not slab of rock. Maybe a good memory foam firmness.
  11. Apr 5, 2016 at 10:58 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Mr Dirty Pool has it covered. VVVVV
    The amount of nitrogen pressure is not what will determine how the truck rides. The coil springs and the shock valving are what determine that.
  12. Apr 5, 2016 at 11:07 AM
    JKO1998
    Utah
    Mm ok thanks. I'll just have them fill to 200. Thank you.
  13. Apr 5, 2016 at 11:07 AM
    sente3
    sente3 -
    North Jersey
    '04 Xtracab 4x4 V6 5-Speed TRD SR5
    Sliders, rear bumper, front skid, lifted
    Bought new wiper blades. Decided to try the Rain-X Latitudes. Their universal adapter looks a bit much, but the blades are quite nice.
    I also got a new fuel cap. In addition to the other evap code I've had, there's another pending one. So I'm going to try that first before I do anything bigger. Are these cheap Duralast caps reliable for fixing fuel cap issues, should that be the issue?
  14. Apr 5, 2016 at 11:12 AM
    Speedytech7
    I'm a fan of Stant when it comes to pressure caps or vacuum stuff. Napa sells Stant in their Balkamp boxes as well for some products.
  15. Apr 5, 2016 at 11:12 AM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
  16. Apr 5, 2016 at 11:27 AM
    KeptOnChooglin
    KeptOnChooglin Well-Known Member
    Phil
    Houston, TX
    2003 Crew Cab PreRunner L4 Auto
    I saw those at Pep-Boys a couple weeks ago.
    I thought the adapter looked hideous as well, and couldnt get myself to pay what they wanted for them, so I got the cheaper Rain-X wipers.
    The previous owner had some Bosches on it, and they still look OK, so I didnt put the Rain-X ones on yet.
  17. Apr 5, 2016 at 11:31 AM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    This /\would be your best bet. Different brands and set ups have different recommended pressures. More is generally not better.
  18. Apr 5, 2016 at 11:32 AM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    Stant's logo is on my gas cap opposite Toyota's logo. They make a lot of stuff that is OEM and not replacement parts.
    Speedytech7[QUOTED] likes this.
  19. Apr 5, 2016 at 11:38 AM
    Robmonster117
    Robmonster117 Well-Known Member
    Robert
    Gilroy
    02 ext. cab 4x4
    Truck parts
    Yikes zip ties? That sounds dangerous. These plates are waay to heavy for zip ties to hold safely
  20. Apr 5, 2016 at 11:40 AM
    sente3
    sente3 -
    North Jersey
    Stant's part catalogue shows part number 10834. Advance Auto says they have it in stock nearby. I'll head over there and pick it up since the store is not even 10 minutes away. Thanks, guys.
