  1. Apr 13, 2016 at 10:02 AM
    Box Rocket
    Box Rocket Well-Known Member
    Adam
    Syracuse, Utah
    1995 FZJ80 Land Cruiser
    3xLocked, lifted, well used
    C'mon man, I know you're smarter than this. I know you don't like me, that's fine. Still doesn't change the facts of what I said. But in case you really don't get it, or for anyone else that's trying to actually learn something...here's a simple diagram to show the concept of how you can get more than 8" of suspension travel from a shock with an 8" stroke. Feel free to check dimensions of the shock body and 1" increments, they match. Like I said before had my shocks been mounted vertically then yeah that would only allow 8" of travel. As you can see, that's not what's happening here. Don't be dumb, just because you want to take a jab at me.
  2. Apr 13, 2016 at 10:06 AM
    Madjik_Man
    Colorado Front Range
    Only one way to settle this....
    ....FLEX OFF!!!
    fiziks, Reh5108, nagorb and 4 others like this.
  3. Apr 13, 2016 at 10:08 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Sounds gross... IM IN! :cool: Gotta get my creeper shackle mounts first.
  4. Apr 13, 2016 at 10:09 AM
    Madjik_Man
    While you do that, I'm going to wax my chest and oil myself up.
    Speedytech7[QUOTED] likes this.
  5. Apr 13, 2016 at 10:10 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Yea vertical travel get tricky when you start to angle things
    Again, angling shocks decreases their overall effectiveness on dampening but nothing tuning can't solve. It'll just be harder to tune. The only point to angling shocks it to maximize travel of a smaller shock.
    It's a game of compromises if you don't want shocks poking through the bed.
    Speedytech7 and Box Rocket like this.
  6. Apr 13, 2016 at 10:10 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    The more you lean the shock over, the more vertical wheel/axle travel it allows within the range of the spring. Leaning it over also means a loss of dampening. This compromise is best met with shocks that you can revalve for optimal performance.
    chowwwww and Blackdawg like this.
  7. Apr 13, 2016 at 10:10 AM
    KeptOnChooglin
    KeptOnChooglin Well-Known Member
    Phil
    Houston, TX
    2003 Crew Cab PreRunner L4 Auto
    Question:
    For running wire in the engine bay (lighting harness/LED harness/etc) I am looking at getting some wire loom on Amazon.
    Is the 1/4 inch too small? I also see 3/8 inch and 1/2 inch?
    Yeah, its for the Taco, but it is also for a 2003 Dodge B2500 camper van, which has a tight engine bay, and I figure is a hotter engine bay. I also guess, maybe there is cheapo loom (for tidying up lines) and more protective loom for auto/engine bay usage.
  8. Apr 13, 2016 at 10:11 AM
    Box Rocket
    Adam
    Syracuse, Utah
    Exactly!
  9. Apr 13, 2016 at 10:11 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    We aren't talking about flexing. Vertical travel. As in, if you jumped your truck how much would the axle travel be straight up and down.
    Flexing is different. I can easily flex out a 35" tire below the slider. But vertically I can't come close to that.
  10. Apr 13, 2016 at 10:12 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The simple version for the simple folk....I hope anyways
  11. Apr 13, 2016 at 10:12 AM
    Madjik_Man
    Come on Monte...you can't seriously be taking my post seriously.
    Seriously?!
  12. Apr 13, 2016 at 10:13 AM
    Speedytech7
    I get the 1/2 in stuff at HF cause it is cheap, the only down side to the 1/4 is that it is harder to get the wires into it and you can't add to the loom later cause it is so small
  13. Apr 13, 2016 at 10:13 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Seriously...
    Bruh
    :luvya:
  14. Apr 13, 2016 at 10:15 AM
    Digiratus
    Roaming the PNW
    The RedHead
    Just speaking from experience.
  15. Apr 13, 2016 at 10:16 AM
    chowwwww
    chowwwww Well-Known Member
    Orange County
    03 Doublecab 4x4
    Billys 5100/Eibach and Wheelers Progressive 1.5 AAL with overload in
    This explanation and the diagram from boxrocket makes it a lot easier to understand.
    Digiratus[QUOTED] and Box Rocket like this.
  16. Apr 13, 2016 at 10:18 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    It only gets more complex. The more inboard the mounts, it's changes. The more angled in any direction, it changes.
    Pretty cool really. But can be complex fast.
  17. Apr 13, 2016 at 10:26 AM
    chowwwww
    Orange County
    03 Doublecab 4x4
    Yea, I am sure it does.
  18. Apr 13, 2016 at 10:30 AM
    TacoVio
    TacoVio Well-Known Member
    Kolton
    CO/WY
    R.I.P '04 Roy Super White ^^
    '00 Imperial Jade Flatty / '14 Spruce Mica, 6MT, Sick
    Yeah I believe I am apart of starting this whole thing. I apologize for that lol! But this is a lot of new info to take in, especially when you don't know too much about it. Gets pretty overwhelming. A lot of different opinions. But what I am getting out of it is...Since I have acquired 10" shocks. It is better for me to mount them as vertical as possible to help dampening load at higher speeds and just all together etc. More outboard to control load for stability since I use it as a DD and do a lot of mountain driving and I still get decent wheel:shock travel considering what my truck is for. It's not gonna be 1:1 travel but enough for me as I do not do a lot of crawling yet considering my truck is a Daily for the time being. I feel I have a basic understanding of this whole thing. I'm young and I still have a lot to do to the truck and I have a lot more to learn about the geometry aspect of the suspension. But I think for now I have I setup brewing that I think will be good for me right now. Now am I rightish? Yes or no?
  19. Apr 13, 2016 at 10:34 AM
    Box Rocket
    Adam
    Syracuse, Utah
    You're a genius. I love how you describe my setup as "shit" (which I have never claimed to be ideal) and then talk like you know what you're doing, only to show your setup that is more or less identical to mine. Crossmember in the same place, shock mounts all at the same places, shocks at the same angle. :rolleyes:
    Fernando and Blackdawg like this.
  20. Apr 13, 2016 at 10:34 AM
    KeptOnChooglin
    Phil
    Houston, TX
    Meh, I checked. The Horrible Freight stuff is not cheaper on the 3/8 a little cheaper on the 1/4 and not as temp resistant. 10 feet of 3/8 good for -30° to 200° Fahrenheit @ 2.99. The 1/4 gets you 14 feet, same price, specs
    http://www.amazon.com/gp/product/B005KLBJOK/ref=crt_ewc_img_srh_1?ie=UTF8&psc=1&smid=A2BG7YHXUODUGA
    25 feet of 3/8 good for -40° to 300° Fahrenheit @ 7.25. The 1/4 is 6.95 for 25 feet. free shipping
