  1. Apr 14, 2016 at 9:51 AM
    Burnett
    Burnett Well-Known Member
    Nolan
    North Georgia
    98' Xtra cab v6 4x4 evergreen pearl
    Bilsteins 5100's & 5125's, OME Dakar leafs Custom toolbox Custom bedstep/towhook/reverse light combo Custom Bedrack
    That looks more like mounts for a skid or something
  2. Apr 14, 2016 at 9:51 AM
    because_wumbo-truck
    because_wumbo-truck TTC#036 1st Degenerate Urban Off-Roader
    Jon
    Houston, Texas
    2006 Gordita Blanca V8 4x4 aka "Penelope"
    Sliders and bumper, DDI injectors, flowmaster 40
    I thought you already had a winch
  3. Apr 14, 2016 at 9:51 AM
    because_wumbo-truck
    Jon
    Houston, Texas
    I know, not those, I am aware of how bumpers connect to a first gen.
  4. Apr 14, 2016 at 9:59 AM
    Burnett
    Nolan
    North Georgia
    Don't get all butt hurt dude damn
  5. Apr 14, 2016 at 9:59 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Ive had one for years. Was just showing where i put my solenoid since that was the discusion at hand.
    The small bracket on the bottom is for the two lower bolts for mounting. There is the main stud that goes through the winch plate as well plus too more side bolts not really pictured there.
    Its pretty standard mount...not sure why people are surprised by anything. Relentless is almost identical mounting..
    TacoVio likes this.
  6. Apr 14, 2016 at 10:00 AM
    because_wumbo-truck
    Jon
    Houston, Texas
    Nobody is butt hurt :confused:
    ebbs15 likes this.
  7. Apr 14, 2016 at 10:02 AM
    Burnett
    Nolan
    North Georgia
    You seemed a bit offended by my post
  8. Apr 14, 2016 at 10:03 AM
    because_wumbo-truck
    Jon
    Houston, Texas
    Definately looks like a sturdy design using the frame mount for the stock bumper on the side and the tow hooks on bottom. The metal mounts just look thin compared to the bumper. Could just be the photo not doing justice :thumbsup:
  9. Apr 14, 2016 at 10:03 AM
    because_wumbo-truck
    Jon
    Houston, Texas
    Nah :)
  10. Apr 14, 2016 at 10:06 AM
    Burnett
    Nolan
    North Georgia
    :thumbsup:
  11. Apr 14, 2016 at 10:12 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    That is the way I had mine initially but the last time I had the bumper off the truck, I ended up mounting it inside the bumper behind the passenger side wing, similar to what you see in Monte's pic.
    If I ever take the bumper off again (not looking forward to that), I am going to use extended cables, maybe upgrade to 2 ga. or even 1/0 and relocate the solenoid box again. Probably to somewhere under the hood.
  12. Apr 14, 2016 at 10:15 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    It's all 3/16s. Other then the winch plate witch i added 1/4'' too..so..i guess it would be 7/16'' mounting point now..haha
    math is hard
  13. Apr 14, 2016 at 10:49 AM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    I think it might just be the picture then. The mounting for the 2 bolts that go to the frame just looks really skinny. I know it's not the main mount
  14. Apr 14, 2016 at 11:41 AM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Can the ac compressor pulley bearing be replaced on a 3rz? Or do I need a whole new compressor?
  15. Apr 14, 2016 at 11:45 AM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    I think it's just easier to replace the pulley. Mine froze up on me and $30 later I had it back up and running
    Shit I have the 5vz.... not sure then
    Edit: I was thinking the idler pulley not the actual AC pulley
  16. Apr 14, 2016 at 11:54 AM
    Reh5108
    Idaho
    I can't seem to figure out how to get the pulley off right meow. I'm guessing it's pressed on?
    EDIT: looks like there is a snap ring
  17. Apr 14, 2016 at 11:58 AM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    It should be bolted on :notsure: from the quick google search it seems bolted on. Unless I'm missing something
  18. Apr 14, 2016 at 11:59 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Hmmm maybe I'll try that before I rebuild my ac system. The pulley on the compressor itself right? How difficult was it? Can you do it without pulling the compressor?
  19. Apr 14, 2016 at 12:01 PM
    Madjik_Man
    Colorado Front Range
    JKU3000 likes this.
  20. Apr 14, 2016 at 12:03 PM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    You talking about the ac idler pulley? Because that's what I'm talking about ha
