  1. Apr 21, 2016 at 7:30 PM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Are you gonna get a trans skid? The one I'm building is gonna be both
  2. Apr 21, 2016 at 8:04 PM
    Lux
    Lux @jamesgrouss
    James
    NJ
    2001 tacoma sr5 4x4
    OME 3" lift 881 coils, Dakar's 33" General Grabber AT2's TG low profile front bumper
    Just read through your build thread too, I had no idea toyota still replaces bad frames, I don't think mine is bad enough to be replaced (yet) but seeing a fresh frame on a first gen brought a huge smile to my face, great lookin truck
  3. Apr 21, 2016 at 8:06 PM
    alphabravo
    alphabravo Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    Spliced on a Factor55 thimble in place of the thin metal one that comes with the line.
    jubei, -40 and Silver02Taco like this.
  4. Apr 21, 2016 at 8:35 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Anyone anyone...
  5. Apr 21, 2016 at 8:36 PM
    CHPTR11
    CHPTR11 Team Impulse Red
    Dan
    Pacific NW
    2004 TRD Tacoma
    OME, Hankook, ARB, SCS
    Not all that cool, but I painted the bolts on my SR8s today. Looks much better (IMO) than the silver bolts.
  6. Apr 21, 2016 at 8:40 PM
    LogCabins
    LogCabins Well-Known Member
    Robert
    Oahu
    99 SR5 3.4L 4WD
    If you got the standard Kings then you can use your stock UCAs but if you got the extended travel, then you must get a uniball style or equivalent UCA
  7. Apr 21, 2016 at 8:41 PM
    JKO1998
    Utah
    Pretty sure they're standar. They are pretty close to my CVs though. I'll take. A picture when I get home
  8. Apr 21, 2016 at 8:42 PM
    LogCabins
    Robert
    Oahu
    99 SR5 3.4L 4WD
    Looks good bro......yeah I'm sure the silver bolts were like :anonymous:
  9. Apr 21, 2016 at 8:47 PM
    CHPTR11
    Dan
    Pacific NW
    2004 TRD Tacoma
    Thanks man! They didn't look terrible in silver, but with the truck being red and the wheels being grey it just looked busy:
    Also, it appears the only pictures I take of my truck are of the passenger front wheel...:rofl:
    malburg114 and Silver02Taco like this.
  10. Apr 21, 2016 at 8:48 PM
    LogCabins
    Robert
    Oahu
    99 SR5 3.4L 4WD
    Oh yeah doesn't look bad at all.....but I agree, I like the blacked out look better :thumbsup:
  11. Apr 21, 2016 at 8:52 PM
    ClevSix
    ClevSix Well-Known Member
    IL/IA
    01 DCSB SR5 TRD, 13 T4r SR5
    Suspension, 33s, some armor... Rust, Gray wire and 2Low, and more. T4r is stock.
    The Stock UCA should be fine. You can improve caster angles with a different UCA but it shouldn't be necessary with the Kings you have.
  12. Apr 21, 2016 at 8:59 PM
    JKO1998
    Utah
    I'm not even lifting atm just leveling. Hopefully caster won't be too terrible
  13. Apr 21, 2016 at 9:05 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    While caster numbers is concern, the bigger concern is that if they are extended travel, they can potentially droop more than the stock upper ball joint will allow.
  14. Apr 21, 2016 at 9:06 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    You can't tell by looking at them whether they are extended travel or not. The only difference is an internal bump stop that is either there or it's not.
    BYJOSHCOOK[QUOTED] likes this.
  15. Apr 21, 2016 at 9:07 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Fixed my busted pressure washer and pressure washed my Tacoma....It still needs proper washing but at least its white again ;)
  16. Apr 21, 2016 at 9:09 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Those look great Dan. Is that the dark anthracite?
  17. Apr 21, 2016 at 9:10 PM
    snowboard704
    snowboard704 Well-Known Member
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    So if it has the internal bump it's extended travel?
  18. Apr 21, 2016 at 9:11 PM
    CHPTR11
    Dan
    Pacific NW
    2004 TRD Tacoma
    Thanks Mike! Yeah they are the matte gunmetal finish.
    Silver02Taco likes this.
  19. Apr 21, 2016 at 9:17 PM
    Digiratus
    Roaming the PNW
    The RedHead
    No, on extended travel version, the stop is not present, which allow the shock to extend further.
    I love them. They look great on tour truck
  20. Apr 21, 2016 at 9:19 PM
    snowboard704
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    So if you run the extended travel without internal bump.. you would need to run a air bump or some sort of aftermarket bump right?
