  1. Apr 23, 2016 at 8:59 PM
    alphabravo
    alphabravo Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    I'd only use SuperLube if you have polyurethane bushings. Any kind of dino grease will make poly bushings squeak.
  2. Apr 23, 2016 at 9:01 PM
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Low Range quick release mud flap brackets on today.
  3. Apr 23, 2016 at 9:03 PM
    lotsoftoys
    lotsoftoys pavement is boring....
    Jace
    Denver
    98 lifted panda taco
    bunch of crap
    What do u wanna know? I was on duratracs and now I'm on st Maxx 285s too
    JPinFL and malburg114 like this.
  4. Apr 24, 2016 at 7:14 AM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Thanks brotha
    Are we talking about the bushings? I was talking about the ball joint itself.
  5. Apr 24, 2016 at 7:25 AM
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
    The ball joint that I have on my Camburg UCA's is called a uni ball. Is that what you have? Or is yours more like a stock ball joint? I use a dry PTFE lubricant that you can get from a bicycle shop. That is what Camburg suggests for the uni ball. It keeps it clean & lubricated and doesn't attract any contaminants because it dries on contact.
  6. Apr 24, 2016 at 7:42 AM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Ohh my bad. These are stock uca's with a greasable ball joint
  7. Apr 24, 2016 at 7:48 AM
    Sicyota04
    Morgan
    California
    04 DC 4x4
    I didn't know they made stock UCA's that are greasable. I thought that boot between the ball joint and spindle was sealed?
  8. Apr 24, 2016 at 7:50 AM
    Willbeck
    Willbeck Well-Known Member
    Will
    Huntington Beach
    00 Reg Cab 4x4
    Bug deflector
    Still trying to wire up the dependent backlight for my switch panel. Where the heck can I tap into the dash lights circuit? I got a fuse tap for the "gauges" spot under the dash, but I'm not a fan of fuse taps in general, and haven't installed it yet.
    Someone said to use the harness under the center console meant for the auto Trans, as it had the dash light connection for the shift indicator. Well, mine is old and a 5spd, so no working under the console.
  9. Apr 24, 2016 at 7:51 AM
    Willbeck
    Will
    Huntington Beach
    00 Reg Cab 4x4
    Bug deflector
    Some replacement ball joints add a zerk fitting. The Oem ones don't, but can't be pressed out.
  10. Apr 24, 2016 at 8:04 AM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Check it out guys
  11. Apr 24, 2016 at 8:08 AM
    Sicyota04
    Morgan
    California
    04 DC 4x4
    Nice! My OEM one's had that boot just not a zirk fitting below it. They were completely sealed. I still have my stock UCA's just sitting around.
  12. Apr 24, 2016 at 8:10 AM
    TacoVio
    TacoVio Well-Known Member
    Kolton
    CO/WY
    R.I.P '04 Roy Super White ^^
    '00 Imperial Jade Flatty / '14 Spruce Mica, 6MT, Sick
    Looked like a good time! Truck looks good as does The other two!
    m3bassman[QUOTED] likes this.
  13. Apr 24, 2016 at 8:14 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Finally moved my shocks outboard
  14. Apr 24, 2016 at 8:21 AM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Thanks man...i think ill be ok with this grease
  15. Apr 24, 2016 at 8:22 AM
    Sicyota04
    Morgan
    California
    04 DC 4x4
    Yeah. You'll be fine. That's good grease too!
    Fernando[QUOTED] likes this.
  16. Apr 24, 2016 at 8:34 AM
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    Changed the carrier bearing.
    Deathbysnusnu and Fernando like this.
  17. Apr 24, 2016 at 8:51 AM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    What travel are those shocks?
  18. Apr 24, 2016 at 8:52 AM
    anthony250f
    Anthony
    San Diego, CA
    2.5x16"
  19. Apr 24, 2016 at 10:39 AM
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    bought some 4.88s and set the up and installed today. so far loving it, next up is doing the front, installing a J style Tcase and fix the speedo lol
    gPha9Lsr_l1-x7FgMBiRhtdjyDMcD9WzbtfhkAVN_89b8cdb8167948cb7fd49912acd706c2c3f4e03a.jpg
  20. Apr 24, 2016 at 12:29 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Just order the new ones. They just bolt in.
    Ha! nice! bet it rode smooth haha
    x2
