  1. Apr 24, 2016 at 9:20 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Woah look another thing to add to the "To Do List"..... Thanks...
    Matic[QUOTED] likes this.
  2. Apr 24, 2016 at 9:25 PM
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    The way Dylan and I figured it out. Note kids don't do this with anyone you don't trust. We both took turns laying under the truck putting it in forward and reverse feeling the front drive shaft and we would feel like a ball pin hammer tapped the shaft with a ping. Then move the shaft around the bearing and saw some excess play. What it was is that for some how the bearing wasn't seated on the shaft. I was able to pull the old bearing off in one piece. I put on the new bearing and pressed it on. Everything is in my build with pics.
    Dcsleeper408 likes this.
  3. Apr 24, 2016 at 10:04 PM
    Wulf
    Wulf no brain just damage
    rock raisin
  4. Apr 24, 2016 at 11:10 PM
    Dcsleeper408
    Dcsleeper408 Well-Known Member
    Mark
    San Jose
    2000 Sr5 xtra cab
    Fishing pole antenna
    Did my lift a while back.
    Eibach with 5100 billies all around and rear aal.. Stock leafs are tired gonna need to replace that soon. But overall happy with everything. Took it wheeling for the first time. Axles with high angle boots are in the near future.image.jpg
    Restored my headlights today and painted my grille. Used w/e I had in the garage. Sanded grille/etching primer/primer filler/ and SEM Honda bumper coating.
    Also grey wire mod!!!
    bowyer2002, BroTaco and JKU3000 like this.
  5. Apr 24, 2016 at 11:29 PM
    madrollaz
    madrollaz Member
    Installed the new tacoma bed rails in my tacoma
    Chipskip and TheSpeediTurtle like this.
  6. Apr 25, 2016 at 12:10 AM
    99PostWalker
    99PostWalker Active Member
    Shawn
    California
    99 v6 PreRunner
    Desire stages of 4x4 conversion
    Check your local craigslist. Try searching for all different names; camper shell, truck topper, truck cap, etc.
    Also check used trucks for sale on CL. You might be able to get a cap only from a seller selling their whole truck with cap.
  7. Apr 25, 2016 at 5:04 AM
    sente3
    sente3 -
    North Jersey
    '04 Xtracab 4x4 V6 5-Speed TRD SR5
    Sliders, rear bumper, front skid, lifted
    That's gorgeous. FJ40, right?
    I hadn't really put much thought into spray/roll on bedliners, but you make a good point. Spray on is far too pricey for me though. Roll on isn't so bad, however. I'll definitely give it some thought.
  8. Apr 25, 2016 at 5:35 AM
    Trevor99
    Trevor99 Member
    Trevor
    Charlotte, NC
    '04 xtra cab 4x4
    Color matched the front and rear bumpers, the flares, and painted the grill black.. Also plasti dipped the badges and smoked the headlights.
  9. Apr 25, 2016 at 6:18 AM
    SWYPER
    SWYPER Well-Known Member
    Dylan
    South Carolina
    1998 Tacoma 2.7L 4x4
    Is this In Horsepasture?
  10. Apr 25, 2016 at 6:54 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    True and almost no downtime when you are just swapping diffs too.
  11. Apr 25, 2016 at 8:59 AM
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    What kinda bike?
  12. Apr 25, 2016 at 8:59 AM
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
    Yeah I got a quote for a shop to prep the bed and spray on a rubberized bedliner and they wanted $400! Not sure how much a do it yourself roll on bedliner kit would cost. And of course some people are lucky and have buddies with shops that have a compressor and the whole spray on set up and all you have to do is prep, mix and spray
  13. Apr 25, 2016 at 9:02 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    That's pretty reasonable for a shop, most places around me charge 650-700 for a 6ft bed and the edges of the bed. At least for real Line-X. Got lucky that mine was Rhino lined in 08 I guess.
  14. Apr 25, 2016 at 9:02 AM
    gray223
    SE Missouri
    2014 Tundra Limited
    Monstaliners can be sprayed on if you have a air compressor. So much faster. Not sure if the other brands are strictly roll on or not.
  15. Apr 25, 2016 at 9:05 AM
    Sicyota04
    Morgan
    California
    04 DC 4x4
    Yeah that's what this is and he does the top edges of the bed and tail gate. I also have some rust forming right where he could sand it down and spray line X on it to save the rust from going any farther. Right now I just have a crappy plastic bed liner that shrunk and rattles after every bump I hit! Sounds so ghetto!
  16. Apr 25, 2016 at 9:22 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    I want to monstaliner but I have so many rust spots that need to be patched first and no ability to do so.
  17. Apr 25, 2016 at 9:46 AM
    RustyVT
    RustyVT Well-Known Member
    Vermont
    98 4Runner limited, 12 S60 T6
    OME overload springs, airlift bags, Hayden 679, 33x12.5 X-ATs
    Really nothing amazing. KLX300R, and so far my shit ass luck is continuing as usual. Went to do an oil change and the threads came with the drain bolt. I seriously can't have anything that works right the first time.... Helicoils or piggy back drain plug here I come :annoyed:
  18. Apr 25, 2016 at 9:47 AM
    JKO1998
    Utah
    I want to do my whole truck I. Monstaliner eventually. If someone wanted to donate to the cause that'd be great ;)
    gray223 likes this.
  19. Apr 25, 2016 at 9:51 AM
    gray223
    SE Missouri
    2014 Tundra Limited
    RustyVT[QUOTED] likes this.
  20. Apr 25, 2016 at 9:58 AM
    JKO1998
    Utah
    Hmm. Does anyone know of any good write ups on removing the sway bar? All I've found is stuff for second gen. I guess they might be close to the same. It doesn't seem like it's that hard but I just wanna read up on it first. Thanks.
