  1. Apr 26, 2016 at 7:26 PM
    -40
    -40 Well-Known Member
    North Dakota
    01 DC Camburg LT & 17 OR OME BP-51
    1 st Gen TRD Supercharger. URD 7th Inj. Camburg 4x4 LT Kit. Tundra Brakes. 3rd Gen just get’n started, OME BP51 Dakar HD, Camburg UCA & various armor.
  2. Apr 26, 2016 at 7:39 PM
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    I have not. I was interested in removing the mess on the rear frame rail and found that valve. Just haven't done it yet. That company specializes in Toyota so it should work.
  3. Apr 26, 2016 at 7:40 PM
    DSully72
    DSully72 2WD Problems
    Daniel
    Appling, GA
    04 PreRunner TRD Off Road
    Has anybody installed the sPod Universal kit? I got the standard 6 switch panel. I'm curious where you mounted your switch panel. Thanks!
  4. Apr 26, 2016 at 7:42 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Deathbysnusnu[QUOTED] likes this.
  5. Apr 26, 2016 at 7:49 PM
    -40
    North Dakota
    Is this all that's needed?. A few right ups mentioned it was a pain in the ass to go from NPT to stock fittings. 1 st gens have 10mm flare nuts I think?
  6. Apr 26, 2016 at 7:51 PM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    should be plug and play. After bleeding and adjusting of course.
  7. Apr 26, 2016 at 7:53 PM
    -40
    North Dakota
    Nice that's what I was looking for. Gonna order it tonight. Thanks for the info.
  8. Apr 26, 2016 at 9:08 PM
    Madjik_Man
    Colorado Front Range
    Monte, Old Brett @BDN ... explain how that works for me please.
    I'm still not sure my BPV is functioning properly. Whether it be the thing shit the bed when it was dry for years or I don't have the post-lift bracket adjust properly.
    This mechanism looks like a simple replacement. Just curious how it works.
  9. Apr 26, 2016 at 10:22 PM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    The factory BPV uses spring height (basically) to determine how much braking is in the rear. It adjusts braking by how much weight you have in the bed.
    With the in line valve, you set it to a certain proportion (say 65/35) and that's it.
  10. Apr 27, 2016 at 5:16 AM
    Madjik_Man
    Doesn't that defeat the whole purpose of a BPV? It shouldn't be a static proportion/ratio.
    Or does the inline valve somehow adjust to weight in the bed also?
  11. Apr 27, 2016 at 5:26 AM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    That BPV is not normal or standard on all vehicles. Most come from the factory with a set, non adjustable, bias.
    However there is some re-plumbing of the BPV in order to use the valve as there are two lines going to the rear, and we only need one.
    Mine doesn't work either, it's frozen but is allowing some rear brake action at the moment.
    I may get to it this summer.
  12. Apr 27, 2016 at 5:36 AM
    Madjik_Man
    You have piqued my interest.
  13. Apr 27, 2016 at 6:02 AM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Since it's a topic of discussion, I just NOW ordered one before they go on eternal back order. :D
  14. Apr 27, 2016 at 6:28 AM
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    Has anyone had this code and what did they do to fix it?
  15. Apr 27, 2016 at 6:52 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    This photo is fucking awesome.
  16. Apr 27, 2016 at 8:12 AM
    TacoVio
    TacoVio Well-Known Member
    Kolton
    CO/WY
    R.I.P '04 Roy Super White ^^
    '00 Imperial Jade Flatty / '14 Spruce Mica, 6MT, Sick
    That's what I did when I wrecked...went airborne...but my spindles/uca hit my wheel well and the ball joint bolt put a whole through my wheel well lol I was impressed with OME suspension and how it performed in that situation lol. That's suspension is now on the new truck still in use. Testimonial for OME! :D :cool:
  17. Apr 27, 2016 at 8:15 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    :thumbsup:
    Your are correct, in that disconnecting only one end of the sway bar effectively gives you the articulation benefit. I initially did that years ago, and found out that the disconnected end was banging into the LCA when flexing. I was a bit nervous about leaving it that way. So instead of 5 minutes, it takes me about 10 minutes :D
    Its possible that some grinding on that end of the sway bar would have corrected it, but I didn't know how much to grind, and didn't want to weaken the bar for when I occasionally reconnect it.
  18. Apr 27, 2016 at 8:25 AM
    TheSaint
    TheSaint Regular Guy
    Mark
    Prescott, Arizona
    White 2003 4x4 TRD DC
    OME lift, 265/75s, pickup shell, couple of dents.
    Oh, I also did this to my Tacoma yesterday.
    Just getting broken in....
    otis24, -40, Silver02Taco and 8 others like this.
  19. Apr 27, 2016 at 8:35 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    If you have a fully loaded down Expo vehicle the trick is keeping all four on the ground in the first place. That's the whole reason we mess with our suspension, at least those of us that aren't desert prerunners.
    Chipskip and TacoVio like this.
  20. Apr 27, 2016 at 8:36 AM
    TacoVio
    Kolton
    CO/WY
    You know that makes sense...it really does... :D
