  1. May 1, 2016 at 1:05 PM
    LogCabins
    LogCabins Well-Known Member
    Robert
    Oahu
    99 SR5 3.4L 4WD
    Mahalo'z!!!!!
  2. May 1, 2016 at 1:07 PM
    Madjik_Man
    Colorado Front Range
    When you're here for the bug shield remind me to have you look at my spare console to see if it's tan.
    ebbs15[QUOTED] likes this.
  3. May 1, 2016 at 1:10 PM
    ebbs15
    ebbs15 Lord Winchester
    Brandon
    Spokane Washington
    09 Lexus GX470
    yes the holes DO line up, however if you look at my picture, the tabs off the center console are pushed out a little, screwing them down pinches them and tweeks the plastic. I just used the two 10mm bolt in the center of the lower cubby in the center console and it's plenty stable.
  4. May 1, 2016 at 1:10 PM
    ebbs15
    Brandon
    Spokane Washington
    09 Lexus GX470
    yup... is your interior grey or tan in your truck?
  5. May 1, 2016 at 1:16 PM
    LogCabins
    Robert
    Oahu
    99 SR5 3.4L 4WD
    Raja....I'm not gonna screw the tabs in, may even get fancy with some trimming and make it flush somehow :D Truly appreciate your help!!!!
  6. May 1, 2016 at 1:27 PM
    SnowroxKT
    SnowroxKT Well-Known Member
    Kyle
    Anchorage Alaska
    2008 TRD OR
    Dumb question but did you tighten the belt? That's what my squeeling was...
  7. May 1, 2016 at 1:48 PM
    LogCabins
    Robert
    Oahu
    99 SR5 3.4L 4WD
    I think he has the "whinnying" noise, which usually indicates the bearing in the pulley
  8. May 1, 2016 at 1:50 PM
    SnowroxKT
    Kyle
    Anchorage Alaska
    2008 TRD OR
    Still worth a check...
  9. May 1, 2016 at 1:53 PM
    LogCabins
    Robert
    Oahu
    99 SR5 3.4L 4WD
    Very true.....now get back to hacking up your rig :D
    SnowroxKT[QUOTED] likes this.
  10. May 1, 2016 at 2:10 PM
    ffirg
    ffirg Well-Known Member
    mike
    Anchorage, Alaska
    2002 Tacoma SR5 TRD 4X4
    Yeah it felt good to me and the shop I had diagnose it said it felt good too.
  11. May 1, 2016 at 2:32 PM
    SnowroxKT
    Kyle
    Anchorage Alaska
    2008 TRD OR
    Carry on.
  12. May 1, 2016 at 2:37 PM
    Madjik_Man
    Mine is gray, now black. But I bought the console off a TW member here and can barely see what color it is in my garage.
  13. May 1, 2016 at 3:07 PM
    malburg114
    malburg114 Well-Known Member
    Las Vegas, NV
    2001 Toyota Tacoma TRD
    Anybody using these switches? Not looking to drop the money on otrattw switches. And anyone have a cigarette lighter in the bed with pictures? Trying to get an idea.
    http://amzn.com/B019XPG5N8
    And whos got a winch wired to a switch and can give me some insite on how to do it.
  14. May 1, 2016 at 3:18 PM
    eon_blue
    Azusa, CA
    Put on my new grill mounted TRD emblem for added boost...
  15. May 1, 2016 at 3:20 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    I tapped into the remote wires on the solenoid side and ran those to the cab with a power wire, it's worked great so far.
  16. May 1, 2016 at 4:47 PM
    UssMoGn
    UssMoGn That Vegas dude
    James
    Las Vegas NV
    05&04 Tacoma SR5
    Home Built Front Bumper HID Headlights LED Cab lights 2013 Radio swap MOLLE DC Insert Traffic Cam F&R 6'' Procomp lift Custom Grillie
    Got my lift in from Wheelers Offroad. I get it put on friday.
    ebbs15 likes this.
  17. May 1, 2016 at 4:52 PM
    KeptOnChooglin
    KeptOnChooglin Well-Known Member
    Phil
    Houston, TX
    2003 Crew Cab PreRunner L4 Auto
    Did most of the debadging. The SR- 5s came off easy, the door emblems, left a lot of crap, I didnt finish the tailgate Toyota. It says TOYO, I should have removed the TO and left it YOTA.
    I also removed the thin wire guards over the headlights. I think it looks better. Of course, Murphy will now sling a rock at one of the headlights this week, coming home from work.
  18. May 1, 2016 at 5:46 PM
    Burnett
    Burnett Well-Known Member
    Nolan
    North Georgia
    98' Xtra cab v6 4x4 evergreen pearl
    Bilsteins 5100's & 5125's, OME Dakar leafs Custom toolbox Custom bedstep/towhook/reverse light combo Custom Bedrack
    I got some switches with wiring harnesses on eBay for cheap that are similar to the otrattw switches. I also installed a 12v cig plug with dual USB ports in the bed for my RTT. Super easy, here's what I got.
    I can get some installed pics if you want.
    Are you wandering about how to install them?
  19. May 1, 2016 at 6:05 PM
    malburg114
    Las Vegas, NV
    Thats a lot cheaper than what I was looking at. Hows it all holding up? Wouldnt mind some pictures if you dont mind. I have an idea how to install them. Just got a blue seas fuse box to clean up the wiring and want to move the switches I have since I cut up my center console for twin sticks and the crawl box. And want to have 2 cigarrett lighters in the bed, One attatched to the fuse box and one attatched to the battery in the bed. Just not sure how I want to do everything just yet but need to decide soon.
  20. May 1, 2016 at 6:13 PM
    Burnett
    Nolan
    North Georgia
    Sounds like you know what you're doing :thumbsup:
    I'll grab you some pics. I bent some thin metal and cut slots to make a bracket to mount it to the bed of the truck. Just painted and popped a couple rivets, looks clean. I added a switch in the bed to cut the power to it (it had led bristle lights that stay on) I didn't figure the switch in when I made the bracket so the switch looks like an after thought. You'll see what I mean when I post a pic so that's something you might keep in mind when you do your install. Also on those rocker switches, the LED in the switch stays on all the time. I'm sure there's a way to splice into a power wire that goes off when the key is removed but I didn't think of that at the time. So something else to think about.
