  1. May 2, 2016 at 1:42 PM
    Yetimetchkangmi
    Yetimetchkangmi Well-Known Member
    Benjamin
    Newcastle, WA
    03 Tacoma 4x4 The Yeti
    ARB front locker, Custom high clearance rear bumper, Custom plate front bumper, mile marker winch PE8, safari snorkel, Deck Plate Mod Fox 2.5 rr DSC, Camburg UCA, squeaky Dakar leafs, 5125 10" and custom 7.5" shackles, thee finest PNW pinstripes, MT-R, Nissan crew cab roof rack??? wtf is that about??? Allpro skids, Rigid duallys President McKinley CB with PA Recaro SRD with Wedge Engineering Morimoto retrofits Champion Rad - Failed Tundra brakes
    Kings or Icons will surely solve that..
    I was thinking you were on leaf springs
  2. May 2, 2016 at 2:03 PM
    TheSaint
    TheSaint Regular Guy
    Mark
    Prescott, Arizona
    White 2003 4x4 TRD DC
    OME lift, 265/75s, pickup shell, couple of dents.
    I just put an OME kit on my '03 Tacoma back in January, and I have no squeaks from the suspension at all. But I greased up all the bushings with silicone plumbers grease before I installed them (mostly just to make it easier to squeeze them in). That said, I'm fully aware that grease will eventually break down/squeeze out and things will start squeaking. It's a thirteen-year-old truck, not an Aston Martin.
    So, I suspect that if you install any new suspension kit that replaces the springs and struts, and take the time to swap out the all the bushings at the same time, and lube everything carefully, it will take care of your squeaking issue (assuming that said squeaking issue is in fact coming from the suspension). I like OME, I think it's a great value, but there are other great choices at other price points as well.
  3. May 2, 2016 at 2:04 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    My current setup doesn't squeak either. Kings up front. Foxes out back and Alcan leafs. All used stuff too.
    willie64 likes this.
  4. May 2, 2016 at 2:06 PM
    Roll Tide
    Roll Tide COO COO KACHOO
    Q
    Here and there. Sometimes.
    01 T4R
    Head unit. That's it.
    Its like Uncle Buck's car...
    Toyko Joe likes this.
  5. May 2, 2016 at 2:07 PM
    Roll Tide
    Q
    01 T4R
    The incessant squeak happens with suspension cycle. That's why I targeted the suspension. Is there some other part that would squeak like that?
  6. May 2, 2016 at 2:10 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Sure.
    Body mounts. Body panels. Steering components. Ball joints.
    Lots of stuff
    ebbs15 likes this.
  7. May 2, 2016 at 2:19 PM
    Roll Tide
    Q
    01 T4R
    Its not body panels. For sure. Maybe body mounts and I intend to replace the ball joints anyhow.
  8. May 2, 2016 at 3:05 PM
    Yetimetchkangmi
    Benjamin
    Newcastle, WA
    Ironically, my leaf packs JUST started squeaking about two weeks ago.
    It was being drowned out by the center support bearing washer that was rubbing against the supported driveline flange for a lovely and glorious grinding sound and rattling washer ringing!
  9. May 2, 2016 at 6:19 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Kinda wanna do the Chevy 63" swap.... Random I know... Gonna have to weld new mounts for Allpro springs anyway.... Decisions decisions....
  10. May 2, 2016 at 6:22 PM
    malburg114
    malburg114 Well-Known Member
    Las Vegas, NV
    2001 Toyota Tacoma TRD
    Just did it on mine. Have yet to drive it yet though. Was pretty easy to do and I did it different than most.
  11. May 2, 2016 at 6:25 PM
    JKO1998
    Utah
    How far do you move the spring hangers back/forward? It doesn't seem too complicated...
  12. May 2, 2016 at 6:30 PM
    malburg114
    Las Vegas, NV
    I think it all depends. Some say 7.5 but mine ended up being closer to 9 I think. I moved mine rather by setting the shackle at 90 degrees to the frame figuring the springs where at full droop. I notched the front of the frame and put my front hanger there. I also used a plumb line and marked where the center pin was on the leafs that where on the truck. The chevy center pin was about 3/4 of inch foward of the stock pin so I moved the axle back 1 inch and that centered the wheel in the wheel well and I will have to do no to very minor trimming with 35s. Check my build for all the details and pictures. They are in the last two pages.
    Fernando likes this.
  13. May 2, 2016 at 8:54 PM
    Burnett
    Burnett Well-Known Member
    Nolan
    North Georgia
    98' Xtra cab v6 4x4 evergreen pearl
    Bilsteins 5100's & 5125's, OME Dakar leafs Custom toolbox Custom bedstep/towhook/reverse light combo Custom Bedrack
    You should spray your suspension parts with some penetrating fluid just to see if it stops the squeaks. Won't hurt anything...
  14. May 2, 2016 at 9:39 PM
    Tacomang
    Tacomang Well-Known Member
    Norcal
    Trd Taco
    Thats what I have to do sometimes. Its because theres rust between the packs in my dakars and when the suspension cycles it squeeks.
    ebbs15 likes this.
  15. May 2, 2016 at 9:42 PM
    taco terror
    taco terror 1st gen = best gen
    USA
    1996 Black Tacoma, 3.4L
    4.56 ECGS regear, Wheelers 6 leaf pack, Eibach coils, Bilstein 5100s, AR Baja wheels, 33 BFG ATs, Line-x
    My wheelers 6 pack squeaks like a mofo going over speed bumps. It's embarrassing when pulling into the apartment and there's chicks out
    Soflanick likes this.
  16. May 2, 2016 at 9:44 PM
    willie64
    willie64 Willie64
    willie64
    BEND OR
    (slowly becoming less than) Stock '03 3.4L 4x4 TRD SR5
    144 watt led lights on front 36 watts x2 led on the back, cb, Kenwood ham, icon 3" lift, 285/75/16 Fierce Attitude tires, JoeZilla sliders, 4x innovation rear bumper, ARB front bumper. Snorkel. On the workbench: more stuff I can't afford.
    Chicks hear it like a mating call. That's what got me my wife.
    WildLand, alee891, Roll Tide and 7 others like this.
  17. May 2, 2016 at 9:45 PM
    taco terror
    USA
    On another note at around 45 mph with the window down I can hear an intermittent squealing/screeching that is very high pitched. I think it's coming from the front drivers side wheel but idk what it is
  18. May 2, 2016 at 9:48 PM
    Tacomang
    Norcal
    Trd Taco
    #marryingbrohoes
    DustStorm4x4 likes this.
  19. May 2, 2016 at 9:58 PM
    taco terror
    USA
    There aren't many ladies around here who like nice 20 year old trucks sadly. It's surprising how at my college I have one of the oldest vehicles of people I know.
  20. May 2, 2016 at 11:52 PM
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    Sold: 33's,armor,crawler,dents, ect. 2020 Gladiator
    OME lift CBI sliders, front bumper homemade rear bumper 33x12.50 m/t Gears Aussie locker inchworm crawlbox Homemade flat belly
    I would suspect your forward leaf spring hanger, then I would check the friction pads between the leaves. There is a metal sleeve inside the leaf eyelet that causes all sorts of fucked up noises. Replaced mine twice now.
