  1. May 3, 2016 at 10:49 AM
    DIRT YOTA
    DIRT YOTA Aka EL ROJO
    Cory
    Camarillo, CA
    03' dbl cab with some stuff
    I used triflow dry lube on the uniballs but never lasted long. Lol. Like u said race truck parts make race truck noises!
    ebbs15 likes this.
  2. May 3, 2016 at 10:58 AM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    I got jipped then. My truck has no racecar parts but still makes racecar noises.
  3. May 3, 2016 at 10:58 AM
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    Tailgate net doesn't improve anything. Mythbusters busted that one... http://www.discovery.com/tv-shows/m...s-database/driving-tailgate-fuel-consumption/
    bowyer2002, thumper72 and Soflanick like this.
  4. May 3, 2016 at 10:59 AM
    FirstGen Jer
    FirstGen Jer Well-Known Member
    Jeromey
    big bear lake, CA / lake havasu, AZ
    1999 toyota tacoma 3.4l v6 sr5 4x4
    thumper72 likes this.
  5. May 3, 2016 at 11:06 AM
    gray223
    SE Missouri
    2014 Tundra Limited
    Pretty much. The air in the bed forms a bubble and allows passing air to go along the top of the cab and right over the tailgate. With the tail gate down or a net, this effect doesn't happen and apparently creates more drag...
    thumper72 and ebbs15 like this.
  6. May 3, 2016 at 11:44 AM
    ebbs15
    ebbs15 Lord Winchester
    Brandon
    Spokane Washington
    09 Lexus GX470
    yup! to further fuck things up... I'm getting BETTER MPG with my RTT than before... don't belive me? check out my link for Fuely... I put the tent on 3 April. filled up 4 april... since then
    Date Miles MPG
    4/29/16 262.00 17.20 100% in town
    4/24/16 186.00 13.90 Play'n in the snow
    4/16/16 277.00 17.71 100% In Town
    4/10/16 261.00 19.80 Mostly Freeway (descending 3500+ft of elevation)/loaded for camping
    4/10/16 62.00 15.74 mostly Off road/loaded for camping
    4/9/16 124.00 16.16 mostly Off road/loaded for camping
    4/8/16 175.00 17.03 Freeway (ascending 3500+ft of elevation)/loaded for camping
    4/8/16 271.00 17.48 50% Freeway/in town
    4/4/16 252.00 16.57 Last MPG before RTT 100% in Town
    Digiratus likes this.
  7. May 3, 2016 at 11:45 AM
    pittim
    Pennsyltucky
    Boujee Prius
    transitioning to summer gas perhaps?
    koditten and Deathbysnusnu like this.
  8. May 3, 2016 at 11:55 AM
    ebbs15
    Brandon
    Spokane Washington
    09 Lexus GX470
    Maybe... who knows... I can see the Aerodynamics being a little better (kinda)... but it's about 500Lbs worth of weight I'm always hauling around now... so who knows. but I'm not complaining. 17mpg in town with my heavy ass 33's is great! my Toyo's weigh almost 70lbs each! add the 30lbs of weight they took to balance LOL and it's quite impressive!
  9. May 3, 2016 at 11:59 AM
    BroTaco
    BroTaco Well-Known Member
    Ian
    Cashmere, WA
    2017 TRD OR
    Mounted the 30" for some serious back up lighting.
    SWYPER, JKU3000, TuckGraham and 6 others like this.
  10. May 3, 2016 at 12:03 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    This has been my experience as well. Wost MPGs are with an empty bed. Having a canopy improves on those numbers. But the RTT on is definitely best of all for MPGs.
    jubei and ebbs15[QUOTED] like this.
  11. May 3, 2016 at 12:05 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    I only get 17 stock....
  12. May 3, 2016 at 12:06 PM
    JKO1998
    Utah
    I only get 17 stock.... Don't pay attention to the graph thing...
    ebbs15[QUOTED] likes this.
  13. May 3, 2016 at 12:16 PM
    ebbs15
    Brandon
    Spokane Washington
    09 Lexus GX470
    well... I drive like a grandma, can't go fast if I wanted to, so I shift at like 2500rpms and chill... I do the speed limit just about everywhere, on long freeway jaunts I actually will just sit at 65 (speedlimit is 70-75 here). my MPG's drop like a brick at the 70mph line. If my foot gets heavy, I end up with the 15's or the 13 like I did in the snow (but that was with hubs locked in)
    I also run high pressure (35-40psi) in my tires unless it's bad weather (25-30psi) or I'm off road(10-15psi). I have a 20gal CO2 tank that I can easily air them back up when I need to.
  14. May 3, 2016 at 12:26 PM
    Soflanick
    Soflanick Well-Known Member
    Nick
    FLORIDA
    2001 tacoma prerunner
    5100 front, 5125 rear, 2"all, old ARE topper, 16x8 XD enduro's on 265/75r16 KO2's
    To think I bought the taco to get good gas mileage
    ebbs15 and ronoc like this.
  15. May 3, 2016 at 12:29 PM
    ebbs15
    Brandon
    Spokane Washington
    09 Lexus GX470
    it's ok... just think about all the Jeep owners who bought it because they thought they could go anywhere off road with them
  16. May 3, 2016 at 12:30 PM
    JKO1998
    Utah
    I was just stating that he got better gas mileage on his 33"s than I do on my 31"s
  17. May 3, 2016 at 12:32 PM
    pittim
    Pennsyltucky
    Boujee Prius
    Considering 3rd gens still dont get above 20mpg for the most part, I'd say 1st gens get good gas mileage for the vehicle class.
    But then again full sizes regularly see 20mpg too now lol.
    ebbs15 likes this.
  18. May 3, 2016 at 12:33 PM
    ebbs15
    Brandon
    Spokane Washington
    09 Lexus GX470
    are you geared at all? I'm geared to 4.30's which puts me almost exactly stock ratio for 33's. my speedo is pretty much dead on until like 60... then it's slightly optimistic.
  19. May 3, 2016 at 12:34 PM
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    It's because you are now running the much better summer blend of gas.
    :boink:
  20. May 3, 2016 at 12:35 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Guys, I think my Dakars might be broken. They don't squeak, maybe I should ask ARB for a replacement set.
    ronoc, taco terror, BroTaco and 6 others like this.
