  1. May 3, 2016 at 9:02 PM
    ebbs15
    ebbs15 Lord Winchester
    Brandon
    Spokane Washington
    09 Lexus GX470
    after getting them... honestly... I can't belive I didn't do it sooner. they're so fucking nice, especially not having to work around that fucking prop all the time
  2. May 3, 2016 at 9:19 PM
    taco terror
    taco terror 1st gen = best gen
    USA
    1996 Black Tacoma, 3.4L
    4.56 ECGS regear, Wheelers 6 leaf pack, Eibach coils, Bilstein 5100s, AR Baja wheels, 33 BFG ATs, Line-x
    My dang rpms are whack.
    It idles fully warmed up around 1000 now. Has been for about a year. And sometimes when warming up the idle will go up for a few seconds then down. It's also doing that fully warmed up at stop lights, feels like the rpms increasing for the A/C compressor but the air is off.
    It's bugging me
  3. May 3, 2016 at 9:21 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    Being a smaller person I decided id finally use the original wheels from my truck. So to lower the height of the truck I put a set of junk 205/60r16 tires on them and boom, instant easier access while I work under the hood. only down side is it looks ridiculous
    And its running open headers as of now. getting things ready to pull the trans later this week.
  4. May 3, 2016 at 9:29 PM
    Madjik_Man
    Colorado Front Range
    Sounds like a bad throttle position sensor.
    When's the last time you cleaned the MAF, throttle body, IAC and changed your spark plugs/wires?
  5. May 3, 2016 at 9:31 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Yes, yes it does.
  6. May 3, 2016 at 9:31 PM
    Madjik_Man
    We didn't do this.
    Is my truck going to blow up now? :(
    ebbs15[QUOTED] likes this.
  7. May 3, 2016 at 10:10 PM
    taco terror
    USA
    I'm not sure but I think the plugs and plug wires are stock. I think my grandpa had the intake cleaned before I got it, but that was before 70k and its at 118k now.
    You could say I have a lot to do this summer
  8. May 3, 2016 at 10:21 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    I had a 2300 rpm idle problem on two different throttle bodies...it was the iac valve twice
  9. May 4, 2016 at 2:33 AM
    JPinFL
    JPinFL Well-Known Member
    '01 Tacoma Xtra Cab 4x4
    Mine is doing the same.
  10. May 4, 2016 at 4:58 AM
    ebbs15
    Brandon
    Spokane Washington
    09 Lexus GX470
    Touchè
    lol just takes stress off the mounts when you first try to close them. They are really tough to cycle (comparatively) the first couple times then settle in.
  11. May 4, 2016 at 5:22 AM
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    yep.
    ebbs15 likes this.
  12. May 4, 2016 at 6:06 AM
    Roll Tide
    Roll Tide COO COO KACHOO
    Q
    Here and there. Sometimes.
    01 T4R
    Head unit. That's it.
    Why put tires on them at all? Save ya another 2-3 inches with no rubber!
  13. May 4, 2016 at 6:49 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Never skip leg day.
    jubei and alphabravo like this.
  14. May 4, 2016 at 7:21 AM
    ClevSix
    ClevSix Well-Known Member
    IL/IA
    01 DCSB SR5 TRD, 13 T4r SR5
    Suspension, 33s, some armor... Rust, Gray wire and 2Low, and more. T4r is stock.
    Refill the windshield washer fluid? :notsure:
  15. May 4, 2016 at 7:36 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Why would you do that? Just use the tears of all the haters. Or drive through a lake.
    thumper72 and ClevSix[QUOTED] like this.
  16. May 4, 2016 at 7:52 AM
    ronoc
    ronoc WisTaco Guy
    Madison, WI
    Bruce 2017 TRD OR DCLB 4x4
    Line-X coated Leer 180 topper Prinsu cab rack Ebay Pro Grill
    I see tires being referred to as 31's and 33's is that that diameter of the overall tire and wheel combined?
  17. May 4, 2016 at 7:55 AM
    bowyer2002
    bowyer2002 always tinkering
    NE Missouri
    01 Taco SR5 D-cab 4WD
    OME 882s, OME shocks all around and OME Dakar spring packs, ARB, Warn 8000, ARE shell, Custom rear bumper w/ reciever, 5-235/80R17 Cooper Discoverer ST MAXX on FJ wheels, grey wire mod, Hi-Lift, Hellas, Red-Line hood lifters, Scion radio, sliders, Safari snorkel & LED Ditch lights on CBI mounts.
    ^ yes- actual diameter may vary
    ronoc likes this.
  18. May 4, 2016 at 7:59 AM
    Madjik_Man
    I'm changing my radiator out soon. :notsure:
  19. May 4, 2016 at 8:03 AM
    KeptOnChooglin
    KeptOnChooglin Well-Known Member
    Phil
    Houston, TX
    2003 Crew Cab PreRunner L4 Auto
    Only if its Tuesday.
  20. May 4, 2016 at 9:05 AM
    Jarob11
    Jarob11 Well-Known Member
    Hilo/Tacoma/Evanston
    99 Taco Limited
    Badlands custom frt winch mount bumper. badlands RR bumper w/ spare swing out, jerry can holder. Leer Camper shell. Royal Purple synthetics. Baja fender flares. Entire truck rhino lined. 31's. Custom sound system. More to come.
    Mine did this exact same thing for about a year, would idle even warm around 1100 rpm, until last weekend when i changed all the timing pieces and water pump etc. Truck runs and sounds like a completely different truck. difficult to describe exactly how incredible the difference is. now oonce warm it idles at right around 650-700 rpm. night and day difference.
    taco terror[QUOTED] likes this.
