  1. May 7, 2016 at 6:10 PM
    sente3
    sente3 -
    North Jersey
    '04 Xtracab 4x4 V6 5-Speed TRD SR5
    Sliders, rear bumper, front skid, lifted
    The little Taco that couldn't :sadviolin:
    j0shu4 likes this.
  2. May 7, 2016 at 6:37 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Your rig looks so beefy
  3. May 7, 2016 at 6:56 PM
    Gary3
    Gary3 Member
    Gary
    Melbourne, FL
    2003 Tacoma PreRunner Deluxe Cab 4Cyl 2.7L (4 Door)
    ALifted, Larger tires, LED Headlights, a *few* dents
    Replaced a shock the other day in my pursuit to eliminate this scrapping/knocking sound coming from my front right side tire.
    Didn't fix it unfortunately. But the shock was bad. I could compress it with my hands and it would very slowly extend back out.
    Small update:
    Ripped open my dash and hooked a wire to my fuel sender wire on the gauge. This is so I will be able to measure my fuel level with my little car display that I'm working on.
    Kinda annoying, it's an unregulated connection to the power. So the voltage from the fuel sender varies depending on the state of the alternator/battery. Something I will have to pay attention to in order to ensure an accurate reading.
    alphabravo, ronoc and Deathbysnusnu like this.
  4. May 7, 2016 at 7:06 PM
    Bigbudpat
    Bigbudpat Member
    Patrick
    2004 Black Tacoma Xtra Cab 4x4 TRD Off-Road SR5
    *K&N cold air intake *Leer XR 100 camper shell w/ LED lighting, insulated lined interior *custom carpeted sleeping platform/modular storage unit in bed *Yakima roof rack bars on camper
    Ordered some new headlights & TRD decals. Made a few mods to the bed...suggestions welcome.image.jpgimage.jpg image.jpg image.jpg image.jpg
  5. May 7, 2016 at 8:33 PM
    imcafee195
    imcafee195 Well-Known Member
    Isaiah
    Chattanooga TN
    98 tacoma on 35s
    Lift Raptor lined
    What are the best upper control arms to correct alignment issues?
  6. May 7, 2016 at 8:53 PM
    TacoVio
    TacoVio Well-Known Member
    Kolton
    CO/WY
    R.I.P '04 Roy Super White ^^
    '00 Imperial Jade Flatty / '14 Spruce Mica, 6MT, Sick
    Depends on what you want as in a uniball or sealed ball joint.
  7. May 7, 2016 at 9:14 PM
    imcafee195
    Isaiah
    Chattanooga TN
    98 tacoma on 35s
    Lift Raptor lined
    What are the pros and cons of each one?
  8. May 7, 2016 at 9:26 PM
    TacoVio
    Kolton
    CO/WY
    Uniballs are typically used with extended travel coilovers and allow more travel mainly down eliminating binding like the oem ball joints bind when downtravel happens. It also allows a better alignment especially with caster allowing 2°+. Now aftermarket sealed ball joints like SPC do The same thing (not as good travel as uniball) but are cheaper and are used alot more often in places with snowy salty roads because a uniball is an exposed joint slowing grime and dirt to get into it. SPC still usually allow a good alignment allowing very close if not 2°+ caster. Just depends on personal preference. Uniballs squeak more but I wouldn't let that stop you as race truck parts will make race truck sounds lol. Hope this helps!
    imcafee195[QUOTED] and ronoc like this.
  9. May 7, 2016 at 9:38 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    Have you checked to make sure your swaybar is torqued properly? I had a noise in my front end that disappeared when the swaybar did.
  10. May 7, 2016 at 9:58 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    It really depends on what the alignment issues are.
  11. May 7, 2016 at 10:48 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Keeping with the original theme of this thread ... installed some LED hood lights.
    Burnett, BroTaco, ronoc and 1 other person like this.
  12. May 7, 2016 at 11:01 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Thank you sir :)
  13. May 8, 2016 at 4:45 AM
    tacomatrd22
    tacomatrd22 TRD SuperCharged Tacoma
    Daniel
    Fort Smith, AR
    Supercharged tacoma
    FlowMaster Super 44 2" lift Gray wire Fog light
    That's what sucks about our trucks. Gov limits us to 95 mph :( but I only took mine to 95 for a mile at most. But it does show Toyotas reliability
  14. May 8, 2016 at 4:58 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Our trucks can only go 95?
    BYJOSHCOOK likes this.
  15. May 8, 2016 at 5:30 AM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    They can go 90 :anonymous:
  16. May 8, 2016 at 5:38 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Yeah I've definitely done 90 but I could have sworn I've tried 100 at some point.
  17. May 8, 2016 at 6:21 AM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    A 5 lugger goes 110
  18. May 8, 2016 at 6:59 AM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    This different in Canada? cause ive been over 90mph before seeing the too speed. I hit 170kmh before i had to slow down (took embarrassingly long).
  19. May 8, 2016 at 7:52 AM
    Lifted 03 Tacoma
    Lifted 03 Tacoma Well-Known Member
    Nathan
    2003 Tacoma TRD off-road
    3in lift, wheels and tires, k&n intake, Gibson exhaust, headache rack, side steps, 42in curved light bar, CBI Moab 1.0 bumper, Rigid Dully spot cubes, 285/75r16 Toyo MT's
    I have gotten mine to 104 once before I started to slow down.
    KeptOnChooglin likes this.
  20. May 8, 2016 at 8:58 AM
    Gary3
    Gary3 Member
    Gary
    Melbourne, FL
    I'll take it off and drive it around a bit to see if the sound goes away. Thanks!
