  1. May 14, 2016 at 7:36 PM
    gipsyfetus
    gipsyfetus Well-Known Member
    Hell's Half-acre, KY
    13 Tundra DC 4wd
    3in Level, Rage Roof Basket, Yakima Roof Rack, Bug Deflector, Tint, AVS Vent Visors, Maglite 4D, Nitto Terra Grappler G2s
    Plaid door panels, not perfect but beats the stock cardboard looking stuff.
    AdeptFox, ronoc, BroTaco and 7 others like this.
  2. May 14, 2016 at 7:39 PM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
  3. May 14, 2016 at 7:48 PM
    gipsyfetus
    13 Tundra DC 4wd
    Dapper indeed!
    nagorb likes this.
  4. May 14, 2016 at 7:51 PM
    malburg114
    malburg114 Well-Known Member
    Las Vegas, NV
    2001 Toyota Tacoma TRD
    Whose got a driver side grab handle? My 01 doesnt have one and I really want to add one. Curious if the bolt holes are behind the trim.
  5. May 14, 2016 at 7:51 PM
    nagorb
    Alabama
    2001 dbl cab 4x4
    Nice Sig btw
  6. May 14, 2016 at 8:00 PM
    Bigbudpat
    Bigbudpat Member
    Patrick
    2004 Black Tacoma Xtra Cab 4x4 TRD Off-Road SR5
    *K&N cold air intake *Leer XR 100 camper shell w/ LED lighting, insulated lined interior *custom carpeted sleeping platform/modular storage unit in bed *Yakima roof rack bars on camper
    Thanks guys. The lights are TYC brand NFS certified. I ordered the lights from Rockauto using a discount code I found on this site. I think they were $62 shipped and they arrived in a few days. They definitely look a lot better than the old grayed set that came off. I've only driven it a mile or so to the store & back tonight but so far so good. MUCH better visibility over the old ones. I need to adjust them a little bit but that's it.
  7. May 14, 2016 at 8:03 PM
    gipsyfetus
    13 Tundra DC 4wd
    Thanks, I painted it since.
    nagorb[QUOTED] and Bigbudpat like this.
  8. May 14, 2016 at 8:15 PM
    Kotayota
    Kotayota Well-Known Member
    Sean
    Charleston, SC
    04 White DC
    Bilstein/Eibach combo, 1.5 rear shackles, 33/12.5/15 Duratracs wrapped around MT Classic IIIs, flowmaster 40, K&N intake, 4way pioneer speakers, mini d2s headlight retrofit, satoshi grill, interior leds
    Do I just not use my cupholders enough or something?? I feel like this happens to everyone. Mine are perfectly fine I don't get it
  9. May 14, 2016 at 8:17 PM
    Kotayota
    Sean
    Charleston, SC
    04 White DC
    Me and my girl just went last night. Got a $7 twin size blow up mattress and a $8 pump that works from your power outlet from Wally World and it fits and works perfect with the tail gate down.
  10. May 14, 2016 at 8:20 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Did you give the oil some time to settle? Might have looked full because of air bubbles when you filled it up last time.
  11. May 14, 2016 at 8:53 PM
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    eh, i wouldnt bother with those, all they do is hold small rocks against the rotor and make bad noises lol
    thumper72 likes this.
  12. May 14, 2016 at 8:57 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    This. I took both mine off.
  13. May 14, 2016 at 9:05 PM
    oldschoolbmx
    oldschoolbmx Well-Known Member
    Harry
    02' Tacoma TRD, 14' T4R SR5, 17' Tundra CM Ltd
    Magnaflow cat-back, K&N, B&M short shifter
    I did this also. Not a big deal price wise, but my local dealer has these for $15 and some change. Call the dealer if you have one close by before buying from feebay.
  14. May 14, 2016 at 9:08 PM
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    Yes. I let it warm up then shut it off and let it cool and checked it again as well.
    I'm just going to have to see what happens at the next oil change.
  15. May 14, 2016 at 9:16 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Finally finished installing my Kenwood TM-V71A ham radio today.
  16. May 14, 2016 at 9:28 PM
    gmr102
    gmr102 Well-Known Member
    Utah County
    Formerly: 2002 Silver Stepside TRD OR Ext Cab V6 Current: 2008 Lexus GX470
    Yea it has the rear e-locker on it stock with the full TRD package on it. My father in law has a red one though just like it with no locker. His is the automatic. I doubt it makes a difference but mine is the manual transmission.
  17. May 14, 2016 at 10:57 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Yeah I honestly don't know, they were what the truck came with...
  18. May 14, 2016 at 11:06 PM
    JKO1998
    Utah
    Bean bag for the win
    Kotayota[QUOTED] likes this.
  19. May 14, 2016 at 11:35 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    I've honestly never had anything get stuck behind these on this truck. My Avalon on the otherhand likes to pick up small rocks inbetween the rotor and backing plate.
  20. May 15, 2016 at 1:35 AM
    sente3
    sente3 -
    North Jersey
    '04 Xtracab 4x4 V6 5-Speed TRD SR5
    Sliders, rear bumper, front skid, lifted
    I wonder this too. My truck's 12 years old now and all of my rubber bits look fine. At least it's nice to know that if they do go, they're not expensive to replace.
