  1. May 18, 2016 at 9:15 PM
    Kotayota
    Kotayota Well-Known Member
    Sean
    Charleston, SC
    04 White DC
    Bilstein/Eibach combo, 1.5 rear shackles, 33/12.5/15 Duratracs wrapped around MT Classic IIIs, flowmaster 40, K&N intake, 4way pioneer speakers, mini d2s headlight retrofit, satoshi grill, interior leds
    Yeah now that I think about it I didn't check the clearance between that and the rotor. Just the shield and the inside rim. I'll give it a shot in the AM thanks for the tip
  2. May 18, 2016 at 9:16 PM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    So I've been wanting to deal my auto for a manual. There's a guy parting out a 2000, are they the same tranny? R150f?
  3. May 18, 2016 at 9:27 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    If it's a v6 it's an r150
    If it's a 4banger its a w58
  4. May 18, 2016 at 9:28 PM
    nagorb
    Alabama
    2001 dbl cab 4x4
    So no F then?
  5. May 18, 2016 at 9:28 PM
    nagorb
    Alabama
    2001 dbl cab 4x4
    It's a v6
  6. May 18, 2016 at 9:29 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    W59...
  7. May 18, 2016 at 9:44 PM
    TacoVio
    TacoVio Well-Known Member
    Kolton
    CO/WY
    R.I.P '04 Roy Super White ^^
    '00 Imperial Jade Flatty / '14 Spruce Mica, 6MT, Sick
    My tranny which is v6 5-speed is r150f
  8. May 18, 2016 at 9:46 PM
    nagorb
    Alabama
    2001 dbl cab 4x4
    Awesome! I didn't think I'd be able to find one anywhere close!
    TacoVio likes this.
  9. May 18, 2016 at 10:13 PM
    TacoVio
    Kolton
    CO/WY
    Yeah r150f is V6 5-speed 4x4 and r150 is V6 5-speed 4x2 I'm pretty sure. Someone will chime in
    nagorb[QUOTED] likes this.
  10. May 18, 2016 at 10:23 PM
    KeptOnChooglin
    KeptOnChooglin Well-Known Member
    Phil
    Houston, TX
    2003 Crew Cab PreRunner L4 Auto
    But it looks like it does, which may be all that matters. Well, that and if you smear some red paint on the axe head ...
  11. May 18, 2016 at 10:33 PM
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    Sold: 33's,armor,crawler,dents, ect. 2020 Gladiator
    OME lift CBI sliders, front bumper homemade rear bumper 33x12.50 m/t Gears Aussie locker inchworm crawlbox Homemade flat belly
    Kind of interesting not that it matters but the r150f and the jeep ax15 are the same minus a few bellhousing differences and some clutch stuff. It is possible to run an Ax15 in your Tacoma and throw a roc trac 4/1 atlas or 231/300 doubler in.
    nagorb and TacoVio like this.
  12. May 18, 2016 at 10:44 PM
    nagorb
    Alabama
    2001 dbl cab 4x4
    F is for 4x4 v6. I wasnt sure if there were any differences in years that would cause difficulties in a swap.
    Oh now you just want to throw my moneys away!
  13. May 18, 2016 at 10:47 PM
    TacoVio
    Kolton
    CO/WY
    I don't think either...need a j shift t case?manual shifter bezel and boots?
  14. May 18, 2016 at 11:18 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Whatever. I always mix up the two from my supra days.
    No..
    The ax15 is like the a340 I thought. Not the r150. Which is an auto.
  15. May 18, 2016 at 11:36 PM
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    As far as I know the ax15 and r150 are both manual transmissions. It's been awhile but iirc you can swap the bellhousing clutch and other parts and it will bolt right in. eitherway jeep is in bed with Toyota as far as transmissions go.
    Found it
    http://www.pirate4x4.com/forum/toyo...ota-w-o-adapters-hybrid-r150-ax15-tranny.html
    http://www.virtualjeepclub.com/showthread.php?73404-AX-15-strength
    nagorb and Blackdawg[QUOTED] like this.
  16. May 19, 2016 at 12:10 AM
    alphabravo
    alphabravo Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    Someone suggesting just removing the dust shield. I'll prolly do that next time I'm in there. I hate not being able to see the back side of the rotor. If the front can be open then why not the back?
    I got some air in the brake line somehow which caused the inner pad to not press hard on the rotor. The only way I figured it out is that I had the wheel off and noticed that the inner pads were not wearing and were thicker. I could just barely see that the inner side of the rotor was all oxidized and obviously not making good contact which I would have noticed immediately if the dust shield had not been on there.
  17. May 19, 2016 at 5:48 AM
    ptoncannon
    ptoncannon Member
    Preston
    2003 Toyota Tacoma Limited Double Cab
  18. May 19, 2016 at 6:53 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    If it is a frozen caliper and you have 16" rim's you might wanna just consider doing the Tundra upgrade.
  19. May 19, 2016 at 9:11 AM
    Kotayota
    Sean
    Charleston, SC
    04 White DC
    I know. I was hoping this would give me an excuse to spend the money to do it but as of now I have 15" rims. Ima see how long I can get by I took it for a test drive today and no swooshing sound. Maybe something was in there or the dust shield fixed itself. I plan on changing the brake pads and rotors for now and while I'm in there inspect everything and if it all checks out good, save up some cash from the new summer job and hopefully I can redo the front brakes before fall semester
  20. May 19, 2016 at 10:11 AM
    JRaymundo8
    JRaymundo8 Member
    Jesus
    Las Vegas
    99' Tacoma 4x4 TRD SR5 Manual
    •Arb front bumper •4" ProComp lift kit •Bilstein 5125 shocks •K&N Air Filter •2013 Toyota 4Runner trail edition wheels (powdercoated black) X2 •Toyo Open Country H/T LT285/70R17 street tires •Cooper Discoverer STT Pro LT285/70R17 Offroad Tires •Airaid Modular Intake Tube •Halo Projector headlights w/ 55w Kensun 6k HIDs •LED Smoke Taillights
    Sorry for the late post, went offroading with a few people from vegas on sunday
    alphabravo and bowyer2002 like this.
