  1. May 19, 2016 at 9:51 PM
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    yes somebody did, there are pics somewhere lol
  2. May 19, 2016 at 9:53 PM
    06toyoboy
    06toyoboy Well-Known Member
    Yea i thought i had seen one. But the damn interwebs are so big that i cant seem to find it anywhere. And that is something that i would like to do. It seems like that hump was mad for something like a switch panel
  3. May 19, 2016 at 9:56 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Steve did. Go to his build @sander1036
  4. May 19, 2016 at 10:21 PM
    alphabravo
    alphabravo Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    I was thinking about mounting one of those Switch Pro 8 panels in that spot behind the rear view mirror. There is a bezel now that you could use...
    https://www.tacomaworld.com/threads/switch-pro-8-switch-panel-group-buy.389851/page-24#post-12418060
    You'd want to use the flat version not the curved one so it would fit the headliner better I think. Much less wiring and trouble than trying to fit the carling switches in that spot.
  5. May 19, 2016 at 10:28 PM
    paranoid56
    San Diego
    14 double cab taco
    thats not all that bad of a price once you add up doing the carling ones and adding a nice relay setup
  6. May 19, 2016 at 10:43 PM
    Kacmartin
    Kacmartin Member
    2003 Toyota Tacoma
    Anyone ever had your fuel filter leak from the connection point?
  7. May 19, 2016 at 10:53 PM
    fiziks
    fiziks Well-Known Member
    Isaac
    El Paso TX
    01 DC Prerunner 4x4 5pd Conversion
    5 sp 4x4 conversion, OME lift, SCS F5s
    Started Day 1 of a long maintenance/mod adventure:
    -LCA bushing replacement with Whiteline bushings
    -Rear main seal replacement
    -Front diff outer seals
    -new engine mounts ( courtesy of @Bonzen)
    -New transmission mount (4xinnovations)
    -new front brake pads and rotors
    -new oil pan gasket
    -new timing belt, water pump, and timing belt idler pulleys
    -new crankshaft seal
    -LCE short shifter install
    -ARB diff breather kit install
    -BAMF bolt on sliders and LCA skids
    -RAT skid install
    Soflanick, TheSaint, Bonzen and 4 others like this.
  8. May 20, 2016 at 12:44 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I used plastidip, it sticks easily and since your using it on the interior it will likely never fail.
  9. May 20, 2016 at 12:45 AM
    Speedytech7
    Yes, when i put a new one in i didn't tighten it enough and had to tighten it more. It uses copper crush gaskets to make a seal.
  10. May 20, 2016 at 1:29 AM
    thumper72
    thumper72 Well-Known Member
    Jon
    Ogden Utah
    2000 toyota tacoma prerunner v6 auto
    5100's, ome dakar leafs and ome coils, problem solver tie rods, eazycompany ditch light brackets and auxbeam osram 4" led pods, 2014 4runner wheels, 265/70/17 goodyear authority tires, soon to have 50" led bar on roof
    And the tundra brake upgrade starts! going to be picking a set of 4 runner rims and tires 265/70/17 for $150 on saturday morning..tires still have some tread on them so i might run them a little bit until i can decide on what tires and size to get, this isnt the picture of them its just used to show the type of wheel is all...
    because_wumbo-truck likes this.
  11. May 20, 2016 at 3:53 AM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    How were the motor mounts install? I saw the thread and thought it'd be a good insurance sometime down the road
  12. May 20, 2016 at 5:07 AM
    Keep on Truckin'
    Keep on Truckin' Well-Known Member
    Jarvis
    Indiana
    02 Imp. Red - Ext. Cab SR5 4x4- 2.7- Auto
    Rear Locker, TRD Alloy Wheels & Cooper AT3 Tires, Camper Shell ,, K&N ,Icon AALS
    Use a Steering wheel puller, then when reassembling use a little grease on the shaft splines , my wheel comes off by just pulling on it by hand now
  13. May 20, 2016 at 6:16 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Yeah mine came sanded up pretty nice. I wiped it down with denatured alcohol and used the self etching primer I always use on bare metal projects. We'll see how it holds up. :thumbsup:
    Yeah it's Steve (@sander1036 ) who did that.
    https://www.tacomaworld.com/threads/sanders-02-dc-build.173699/page-45#post-8900048
    ronoc likes this.
  14. May 20, 2016 at 6:24 AM
    fiziks
    Isaac
    El Paso TX
    I plan on doing that today. I think my approach will be slightly different because I have dropped the transmission and entire front end components (with the exception of the engine)for other things. I will let you know nonetheless.
    BYJOSHCOOK[QUOTED] likes this.
  15. May 20, 2016 at 7:03 AM
    ronoc
    ronoc WisTaco Guy
    Madison, WI
    Bruce 2017 TRD OR DCLB 4x4
    Line-X coated Leer 180 topper Prinsu cab rack Ebay Pro Grill
    That looks really good right there. Would be easy to add a D-ring or two right to it as well for extra tie down spots.
    I put on this stubby antenna from amazon
    No more "TWAP" every time I drive in or out of the garage.
  16. May 20, 2016 at 7:20 AM
    oldschoolbmx
    oldschoolbmx Well-Known Member
    Harry
    02' Tacoma TRD, 14' T4R SR5, 17' Tundra CM Ltd
    Magnaflow cat-back, K&N, B&M short shifter
    Is the reception as good as factory? I like it and may consider ordering one.
  17. May 20, 2016 at 9:18 AM
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
  18. May 20, 2016 at 9:22 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Yeah I want to go in the headliner for in cab switches as well. I think it looks the cleanest and is really the only good spot since I have a CB in my ash tray and a double din head unit going in.
  19. May 20, 2016 at 9:26 AM
    AdeptFox
    AdeptFox Active Member
    Jake
    Vermont
    2015 Access Cab 4x4
    Not a big fan of mud but I got her a little dirty :eek:
  20. May 20, 2016 at 9:30 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Do you have a picture of where your CB is?
    Anyone have pictures of where they out there's? Thinking I might just put it on the back of my center console.
