  1. May 20, 2016 at 7:07 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    IM trying to figure that out, too.
  2. May 20, 2016 at 7:16 PM
    Brake Weight
    Brake Weight But it hasn't rained in weeks...I'll make it.
    Deep South near the Third Coast
    Taco pulling 33s and a B6 pushing 33psi
    Weld on sliders, fiberglass shell, 12k winch in an Elite Offroad bumper, front Aussie Lunchbox
    Mine had some slop in it so I replaced it. The parts house replacement was barely any better.
    So Ima assUme that this will take out some of that slop.
  3. May 20, 2016 at 7:28 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Pull one of your pant legs down a bit. That'll help. :thumbsup:
    That is a 'summit series' tent. Not the same as what we have. Think Tepui ruggedized. Had to compete with the orange. :rolleyes:
  4. May 20, 2016 at 7:33 PM
    xcmtb83
    xcmtb83 Well-Known Member
    Iowa
    It takes the up and down slop out of the driveshaft that higher mileage manual transmission extended cabs develop. The up and down slop causes backlash or "play" in the drivetrain.
  5. May 20, 2016 at 7:35 PM
    Madjik_Man
    Colorado Front Range
    Not bad at all. The seat was a worn a bit.
    If your bushing and seat were shot, of course it will make a significant difference.
  6. May 20, 2016 at 8:14 PM
    alphabravo
    alphabravo Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    Anybody know how to pull the ABS rotor (and the extra bearing retainer) when changing out the rear axle bearing? I need a hint :D
    What is your oil level sitting at?
  7. May 20, 2016 at 8:16 PM
    The black taco
    The black taco Member
    Robby
    Merritt island, FL
    01 regular cab project
    HID lights (10k) LED tailights Black paint job (not the best) New tires and wheels
  8. May 20, 2016 at 8:20 PM
    Kotayota
    Kotayota Well-Known Member
    Sean
    Charleston, SC
    04 White DC
    Bilstein/Eibach combo, 1.5 rear shackles, 33/12.5/15 Duratracs wrapped around MT Classic IIIs, flowmaster 40, K&N intake, 4way pioneer speakers, mini d2s headlight retrofit, satoshi grill, interior leds
    Better make sure that hood doesn't go flyin up without havin those hood pins strapped down:D
  9. May 20, 2016 at 8:24 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    Lay a piece of hard wood on floor. Holding onto the hub slam the end of axle on the piece of wood. The weight of the whole assembly should slide everything off.
  10. May 20, 2016 at 8:36 PM
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    The closest thing I've found is a custom tool like this one. Maybe I can rig up something similar.
    I saw another guy pull it off with a couple of aircraft cables but he first cut the retainer off with a cut-off tool. I was hoping to avoid that but I have enough parts to cut everything off if I have to.
  11. May 20, 2016 at 8:38 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Well I've got some news, not that anyone cares, I wouldn't. I think my new leaf springs are gonna be paid for sooner than I thought. This lawn mowing business is pay way better than I thought.
    Hope the Alcan springs are worth the cash $$$.
  12. May 20, 2016 at 8:52 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Always good to see it being done the right way the first time :thumbsup:
    Adventurer_Alex likes this.
  13. May 20, 2016 at 8:54 PM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    Nice.
    Now when is the RTT and LEDs coming so you can join the cool kids club?
  14. May 20, 2016 at 8:56 PM
    JKO1998
    Utah
    I'm thinking sliders and bumpers first. And then maybe monstaline all the things.
    I don't wanna talk about it
  15. May 20, 2016 at 8:56 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Just remember you can't attend such and such wheeling/camping trip cause your rtt isn't in yet...
    ToyoTaco02 likes this.
  16. May 20, 2016 at 9:01 PM
    pittim
    Pennsyltucky
    Boujee Prius
    Yup. If your truck weighs less than 5000lb because you don't have f+r bumpers, sliders, skids, rack, and rtt, you're not allowed in.
  17. May 20, 2016 at 9:02 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Fucking told you to get a bigger one the first time
  18. May 21, 2016 at 12:19 AM
    xcmtb83
    Iowa
    A regular three jaw puller with custom extra length shackles.
    alphabravo[QUOTED] likes this.
  19. May 21, 2016 at 5:25 AM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Looks good! Not a big fan of that green but other than that :thumbsup:
  20. May 21, 2016 at 5:47 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    I actually dig the green haha.
    Boerseun and TacoVio like this.
