  1. May 23, 2016 at 1:49 PM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Damn that sucks! Go 285s if you plan to wheel it. I got 265s and regret it
    Only got 265s because I couldn't afford 285s at the time and needed new tires
    thumper72[QUOTED] likes this.
  2. May 23, 2016 at 2:40 PM
    Chipskip
    Chipskip N7MCS
    Chip
    Green Ridge, MO
    07 Tundra
    It is a bitch, take your time and go thru the side.
    Also, save yourself a Metric sh!t ton of money and just rebuild it. The bushings and spring are super easy to replace and cost ~$9.
    j0shu4[QUOTED] likes this.
  3. May 23, 2016 at 3:19 PM
    thumper72
    thumper72 Well-Known Member
    Jon
    Ogden Utah
    2000 toyota tacoma prerunner v6 auto
    5100's, ome dakar leafs and ome coils, problem solver tie rods, eazycompany ditch light brackets and auxbeam osram 4" led pods, 2014 4runner wheels, 265/70/17 goodyear authority tires, soon to have 50" led bar on roof
    So if I do the 285s then pinch well mod is required correct? Even on prerunner right...
  4. May 23, 2016 at 3:24 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    which wheels?
  5. May 23, 2016 at 3:36 PM
    thumper72
    Jon
    Ogden Utah
    I got these... from a 4runner they are 17" , and just bought brake lines from wheelers as they said no mods are needed to do the conversion..let's hope he's right
  6. May 23, 2016 at 3:44 PM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    I wanna say do that and just beat the shit outta it with a BFH
  7. May 23, 2016 at 3:53 PM
    thumper72
    Jon
    Ogden Utah
    Lmao bought a 5 lb sledge a while ago lol
  8. May 23, 2016 at 3:57 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    Yes.
  9. May 23, 2016 at 4:38 PM
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    Not today but yesterday. Took the truck out for its first mountain 4x4 since all the work got done on it. Flexed it out.
    j0shu4, ronoc, Blackdawg and 10 others like this.
  10. May 23, 2016 at 4:41 PM
    sente3
    sente3 -
    North Jersey
    '04 Xtracab 4x4 V6 5-Speed TRD SR5
    Sliders, rear bumper, front skid, lifted
  11. May 23, 2016 at 4:57 PM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    I've got this clunk, well I've got many, but this one's new, when I hit the brakes in reverse I get a clunk. I thought it might be drive line or suspension, but it seems to brake pads shift a good amount as the brakes are applied. Might be an easier fix then I thought, but they're relatively new brakes...
  12. May 23, 2016 at 5:01 PM
    thumper72
    Jon
    Ogden Utah
    Spring break loose some how..
  13. May 23, 2016 at 6:31 PM
    CStoy
    CStoy mountain-top maniac.
    majestic gold 4x4... 1/4 million miles and counting!
    improved toyota goodness.
    cleaned the MAF sensor and throttle body as well as dielectric greased all fuses and electrical connections... seems to sound different but only drove 18 miles since ... touchier exhaust note change on throttle input.
  14. May 23, 2016 at 6:43 PM
    nagorb
    Alabama
    2001 dbl cab 4x4
    Spring brake?
  15. May 23, 2016 at 7:00 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    image.jpg How about some weak lawn mower curb flex for your Monday.
    Willis_Boy, jubei, ronoc and 3 others like this.
  16. May 23, 2016 at 7:04 PM
    thumper72
    Jon
    Ogden Utah
    Rear brakes ? Spring break inside or come loose
  17. May 23, 2016 at 7:28 PM
    nagorb
    Alabama
    2001 dbl cab 4x4
    No front. Pretty sure either the pins are loose or the holes have worn, I haven't turn into it yet though.
  18. May 23, 2016 at 8:09 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Well, you asked if 285s will only require pounding on the pinch weld to clear. :notsure: Depends on the wheels too.
    I am always suspicious of 2nd gen wheels on our trucks because they have so much backspacing. Do you have stock UCAs? With too much BS, 285s are known to interfere with the upper ball joint area in stock arms.
    I am unfamiliar with those particular wheels. How wide are they. What is their offset (typically stamped on the inside of Toyota wheels) or backspacing? Are you running or plan to run wheel spacers?
  19. May 23, 2016 at 8:11 PM
    KeptOnChooglin
    KeptOnChooglin Well-Known Member
    Phil
    Houston, TX
    2003 Crew Cab PreRunner L4 Auto
    Pulled the steering wheel, put in a used OEM which had stock CC and attached wire from CC stalk to plug. No joy with aftermarket CC still attached.
    I need to find aftermarket CC install instructions to see if they disconnected unused OEM line to stalk plug or did something else. I didn't look through all or trace CC line to ECU. Will have to do that. I wasn't about to blindly sever its wires without learning more about the hookup.
    Also junkyard wheel did not have upper metal add on that flexes, dunno what that is, I will have to take a pic. If you are looking at wheel without the horn pad, it's on the straddles to top of the center, metal, has a couple screws attaching and can be pushed slightly.
    Ok. It's a Rostra 250-1223 kit.
  20. May 23, 2016 at 8:22 PM
    thumper72
    Jon
    Ogden Utah
    I'll get you those specs in 30 minutes as I'm about to get off work and gave them in back of truck and figured I would have to use spacers to make them work...if I recall correctly we have et15 and these are et30.. il put up picture shortly and measure them.i know they are 17"s lol and came from a 2014 4runner he said
