  1. Jun 16, 2016 at 11:48 AM
    thumper72
    thumper72 Well-Known Member
    Jon
    Ogden Utah
    2000 toyota tacoma prerunner v6 auto
    5100's, ome dakar leafs and ome coils, problem solver tie rods, eazycompany ditch light brackets and auxbeam osram 4" led pods, 2014 4runner wheels, 265/70/17 goodyear authority tires, soon to have 50" led bar on roof
    k so i have a great chance at getting a winch from HF for very cheap and was wondering what lbs rating should i look for like a 8k,9k or what? are these any good as i can get it for less then $200 right now.. yes it will be going on a prerunner. my daughters BF gave me a coupon code for 25% all purchased items for a family and friend event going on right now.. so id like to use it for this and some other stuff the CC is paid off and i have a hole in my pocket right now lol
    Dcsleeper408 likes this.
  2. Jun 16, 2016 at 12:00 PM
    Dcsleeper408
    Dcsleeper408 Well-Known Member
    Mark
    San Jose
    2000 Sr5 xtra cab
    Fishing pole antenna
    I was looking into those winches before as well.. would like to hear some ppl's reviews
  3. Jun 16, 2016 at 12:10 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Might as well just buy 10, sell em and make a profit
    thumper72[QUOTED] likes this.
  4. Jun 16, 2016 at 12:15 PM
    JPinFL
    JPinFL Well-Known Member
    '01 Tacoma Xtra Cab 4x4
    On the front page, there's a coupon for that winch: $249.99. A lot of times, they'll even apply that 25% off on top of the coupon price.
  5. Jun 16, 2016 at 12:22 PM
    thumper72
    Jon
    Ogden Utah
    That's what I'm saying $187+tax isn't that bad I just don't want to buy one use it once and it burns up on me is all...
    I have been on a few trails that I just can't make it up this short little hill but after that I'd be perfectly fine for wheeling and I thought this might help out in those situations for sure.thats what my buddy did on his Ford ranger edge that's 2wd..
  6. Jun 16, 2016 at 12:22 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I've got the 8k HF winch on my car hauler. It will pull cars up locked in gear. The tires are just skidding up the ramps. I've had it 10 years or so. If it dies tomorrow, ill put another one on.
    Ill most likely put a 6 or 4k on the next time. The 8k is just a waste of power if its not needed.
    thumper72 likes this.
  7. Jun 16, 2016 at 1:01 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    I have heard good and bad things. I would like to run one in the rear since they are so cheap. for $300 you can get a Smittybuilt
  8. Jun 16, 2016 at 1:08 PM
    koditten
    Kirk
    Central Michigan
    For an extra $30 you can get the replacement warranty.
    Test that bitch to failure and get it replaced.
  9. Jun 16, 2016 at 1:09 PM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    A cheap $200 winch sounds great until it fails on you and you need to pay a tow truck $1000 for an extraction.
    There's some things going cheap on is fine. A thing to get you outta shit when you're miles away from any help is not that thing. IMO.
    jubei and Yetimetchkangmi like this.
  10. Jun 16, 2016 at 1:10 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Yeah cheap recovery equipment makes about as much sense as bargain bin first aid.
  11. Jun 16, 2016 at 1:11 PM
    koditten
    Kirk
    Central Michigan
    That's not realistic. You should not be wheeling alone. 2 winch failures is very unlikely.
    Id bet there are more winch failures from not being used.
    j0shu4, Deathbysnusnu and thumper72 like this.
  12. Jun 16, 2016 at 1:13 PM
    koditten
    Kirk
    Central Michigan
    Most winch failures will be control issues. If you can't hot wire a winch, you should learn how.
    alphabravo and Deathbysnusnu like this.
  13. Jun 16, 2016 at 1:14 PM
    pittim
    Pennsyltucky
    Boujee Prius
    You should be able to rely on your equipment. If everybody has the mentality of "somebody else will get me out" then everybody is fucked.
  14. Jun 16, 2016 at 1:15 PM
    Speedytech7
    Yeah we would be bringing someone with a good winch for sure.
    Super easy... but knowing HF crap, a field winding would be shorted or one of the powdered gears they use would have shed it's teeth.
  15. Jun 16, 2016 at 1:20 PM
    koditten
    Kirk
    Central Michigan
    If I get so stuck that a HF winch can't get me out, I really made some bad decisions.
    Regardless, buy what you want. I just figured we all hung out here in the first gen section because we were cheap and had good taste:)
  16. Jun 16, 2016 at 1:21 PM
    pittim
    Pennsyltucky
    Boujee Prius
  17. Jun 16, 2016 at 1:22 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Realistically you shouldn't be relying on your winch to get out of a sticky situation if you are in fact solo wheeling. Can it potentially make the recovery process much faster? Yes. But if you are stuck because you are high centered your high lift and shovel can help you just as well, it will just take longer. If you are stuck in mud while solo wheeling though, you probably shouldn't have been going through that mud.
    nagorb and koditten like this.
  18. Jun 16, 2016 at 1:25 PM
    koditten
    Kirk
    Central Michigan
    What is the point? Im betting that's made over seas as well.
    Sorry, I don't see $175 more reliability with that winch.
    j0shu4 likes this.
  19. Jun 16, 2016 at 1:25 PM
    Speedytech7
    I'd imagine if it was functioning it would be fine, probably under what it's rated at but fine. But I wouldn't trust it as a main piece of recovery gear. At best it should be used as something people leave on a loading dock or a trailer. There's a difference between being cheap and careless.
  20. Jun 16, 2016 at 1:27 PM
    Speedytech7
    FWIW, Super winch has a good name in the business
    alee891 likes this.
