  1. Jun 20, 2016 at 7:06 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Love the flush fit, great job dude!
  2. Jun 20, 2016 at 7:30 PM
    YotaOverAll
    YotaOverAll Backyard Performance
    Jessie
    Panama City, FL
    02 Prerunner SR5
    3" Toytec spacers, Bilstein 5100s in the back with add a leaf and overloads removed.
    Its high on the list now!
  3. Jun 20, 2016 at 7:46 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Woot! Pain in the ass but worth it!
  4. Jun 20, 2016 at 7:58 PM
    GreeGunc
    GreeGunc Full of regret
    Jacob
    North GA
    1st gen 3rz+18' inferno OR 6spd
    2lo mod. PIAA 510s. Green Floor Lights. Green dash swap. Axle dump exhaust. Husky floor mats. Moto metal mo970's. Shrockworks. Sundown sa-8. 9.5xrc. Kings
    Could make one
    TrailRider2002 and thumper72 like this.
  5. Jun 20, 2016 at 8:23 PM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Meh with how my steering wheel is (98-00 wheel) I can see it perfectly fine. But that's just me maybe :notsure: never complained about it with my 92 4Runner either
  6. Jun 20, 2016 at 8:24 PM
    JBTacoma
    JBTacoma Well-Known Member
    Jeff
    Cullman Alabama
    2000 SR5, 2003 Double Cab and a Suzuki Samurai
    I just put it there for now, not sure where it will end up?
    Thanks, I used a heat gun to soften up the air duct and used a board to push it in where the antenna 90 hit, worked great.
    ptoncannon and thumper72 like this.
  7. Jun 20, 2016 at 9:12 PM
    Robmonster117
    Robmonster117 Well-Known Member
    Robert
    Gilroy
    02 ext. cab 4x4
    Truck parts
    Here here! Definitely one of the toughest jobs to date but stuffing 35s at full lock gives me some kind of feelings :bananadance:
    jubei likes this.
  8. Jun 20, 2016 at 9:22 PM
    Ricky876
    Ricky876 Well-Known Member
    2002 Toyota Space Cab
    Under construction
    did my projector retofit with the morimoto mini h1
    ronoc likes this.
  9. Jun 20, 2016 at 9:25 PM
    Ricky876
    Under construction
    installed 2.5" lift
    stock height
    Lifted
    jjsul, BroTaco, ClevSix and 1 other person like this.
  10. Jun 20, 2016 at 9:53 PM
    thumper72
    thumper72 Well-Known Member
    Jon
    Ogden Utah
    2000 toyota tacoma prerunner v6 auto
    5100's, ome dakar leafs and ome coils, problem solver tie rods, eazycompany ditch light brackets and auxbeam osram 4" led pods, 2014 4runner wheels, 265/70/17 goodyear authority tires, soon to have 50" led bar on roof
    Why does that look way larger then 2.5" I did a 3 "on mine and it don't look that high even for a prerunner?? Mines the prerunner
  11. Jun 20, 2016 at 10:06 PM
    fiziks
    fiziks Well-Known Member
    Isaac
    El Paso TX
    01 DC Prerunner 4x4 5pd Conversion
    5 sp 4x4 conversion, OME lift, SCS F5s
    What lights are those? they look like baja designs, but what model?
  12. Jun 20, 2016 at 10:11 PM
    retroboy1989
    retroboy1989 Single Cab 4x4
    99 2.7L 5spd 4x4
    Ill trade you my blank panel for your clock.
  13. Jun 20, 2016 at 10:13 PM
    alphabravo
    alphabravo Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    They are Onyx spots.
    fiziks[QUOTED] likes this.
  14. Jun 20, 2016 at 10:14 PM
    because_wumbo-truck
    because_wumbo-truck TTC#036 1st Degenerate Urban Off-Roader
    Jon
    Houston, Texas
    2006 Gordita Blanca V8 4x4 aka "Penelope"
    Sliders and bumper, DDI injectors, flowmaster 40
    Mines always fast anyways. I fix it every daylight savings and by the next time change its 5 mins fast again
  15. Jun 20, 2016 at 11:00 PM
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    I think I lost about 1/2" at the wheel after I added the bumper and winch. I snapped a pic of my CV angles and bumps this evening.
    Also mounted the RTMR tonight.
    BYJOSHCOOK likes this.
  16. Jun 20, 2016 at 11:15 PM
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    2002 Toyota Tacoma 4WD
    Check Build
    Whats your opinion on 650 vs 700 lbs springs if I have skids winch and plate bumper? Planning on getting some ads shocks.
  17. Jun 21, 2016 at 12:55 AM
    LogCabins
    LogCabins Well-Known Member
    Robert
    Oahu
    99 SR5 3.4L 4WD
    Yup that's low.....like stock height low, your cv's almost look straight
  18. Jun 21, 2016 at 5:02 AM
    sente3
    sente3 -
    North Jersey
    '04 Xtracab 4x4 V6 5-Speed TRD SR5
    Sliders, rear bumper, front skid, lifted
    Yeah mine always ends up a few minutes ahead. Inevitably, at some point, I think I am going to be just on time for work or punch in just past my scheduled time and when I get there, I still have a few minutes.
  19. Jun 21, 2016 at 6:03 AM
    Ricky876
    Under construction
    all my friends said the very same thing....i find it strange but i dont mind as long as my CV's arent affected
  20. Jun 21, 2016 at 6:16 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Yeah when I did mine I used a map gas torch and a breaker bar. The heat gun would have probably been the much safer route to go. :anonymous:
    Also in response to your mic location, I mounted mine to the right of the front radio surround. I bought a plastic mic holder instead of using the one they gave and super glued it on since the adhesive backing came off when the truck got hot inside. Just another potential option.
    Same! Though I still don't have my rubber yet. Definitely getting it before an event at the end of July.
