  1. Jul 21, 2016 at 9:20 AM
    GreenMachine8
    GreenMachine8 Well-Known Member
    Elko, NV
    1996 Olive Drab Tacoma DLX 2.7L 4X4
    Off road fiber glass, rhino lined olive drab, retrofit headlights, kings/total chaos mid travel suspension.
    The nice thing is I would have the tools but not the skill probably... But definitely something I could learn and read up on and have my buddy help me. His grandpa used to be a mechanic and I'm sure he'd help us if we ran into a snag.
  2. Jul 21, 2016 at 9:27 AM
    j0shu4
    j0shu4 98 TRD 4x4, 3.4 Turbo, Full LT, Fully Locked
    98 TRD, Turbo, 3.4L, 4x4, LT
    Turbo, Fiberglass, Full Long Travel, Lockers, T100 axle, King Shocks
    Nice spydercos
  3. Jul 21, 2016 at 9:29 AM
    ronoc
    ronoc WisTaco Guy
    Madison, WI
    Bruce 2017 TRD OR DCLB 4x4
    Line-X coated Leer 180 topper Prinsu cab rack Ebay Pro Grill
    My '01 is B07A. 07 isn't in the 94-04 range. What's the deal there?
    EDIT:
    https://www.tacomaworld.com/threads/oem-gear-ratio-chart.365138/
    Says it is 4:30... so if I was looking at 33's with my 3rz manual, I'd want to regear as well...
    EDIT 2:
    03 05 aren't the same on both charts, 06 matches one... So I guess this means I can make up w/e gear ratio I want. Cool. Mine is 6:95
  4. Jul 21, 2016 at 10:05 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Google Zuk differqntials. That'll show you what you'll need. It's a lot of stuff.
  5. Jul 21, 2016 at 11:02 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Trucks currently under the knife, pictures to come
    jubei and scottalot like this.
  6. Jul 21, 2016 at 11:06 AM
    because_wumbo-truck
    because_wumbo-truck TTC#036 1st Degenerate Urban Off-Roader
    Jon
    Houston, Texas
    2006 Gordita Blanca V8 4x4 aka "Penelope"
    Sliders and bumper, DDI injectors, flowmaster 40
    I spy a 2nd gen
  7. Jul 21, 2016 at 11:23 AM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    That there my friend is the answer to all problems and predicaments.
    Deathbysnusnu, jubei and meatman like this.
  8. Jul 21, 2016 at 11:25 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Those second genners never were the sharpest knives in the drawer.
  9. Jul 21, 2016 at 11:28 AM
    snotaco
    snotaco Well-Known Member
    Lewiston, Idaho
    2003 prerunner tacoma
    2003 tacoma double cab, prerunner, 4wd conversion, 5 speed conversion, dual cases with inchworm clockable adapter, toytec ultimate coil overs, trd supercharger with urd 7th injector, 37 inch mastercraft mxt's, arb front locker
    put a different front bumper on the tacoma, like the look of the winch being hidden rather than looking ghetto fabbed and hacked up
  10. Jul 21, 2016 at 11:31 AM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    lots of setting preloads, backlash, and reading wear patterns. It can be assembled and seem to work fine only to prematurely wear out. And these particular diffs are a pain in the ass. attempt it at your own risk.
  11. Jul 21, 2016 at 11:36 AM
    devinzz1
    devin
    2023 aclb trd or mt
    Wired pods with the high beams instead of a switch
    because_wumbo-truck likes this.
  12. Jul 21, 2016 at 11:43 AM
    because_wumbo-truck
    Jon
    Houston, Texas
    And this one in particular is like a wet match in a dark cave :laugh:
    @scottalot
  13. Jul 21, 2016 at 11:44 AM
    because_wumbo-truck
    Jon
    Houston, Texas
    I wanna do this with my light bar, can you do a write up?
  14. Jul 21, 2016 at 12:25 PM
    thumper72
    thumper72 Well-Known Member
    Jon
    Ogden Utah
    2000 toyota tacoma prerunner v6 auto
    5100's, ome dakar leafs and ome coils, problem solver tie rods, eazycompany ditch light brackets and auxbeam osram 4" led pods, 2014 4runner wheels, 265/70/17 goodyear authority tires, soon to have 50" led bar on roof
    So finally picked up trailer and it's loaded with full fresh water and propane and dual battery right now and it sank 2" on rear of truck.. so please help me out to make a decision on what to get.... I know u can get air bags or AAL but what is best so I can still go off-road with truck and still tow trailer...it's a prerunner with Dakar's on rear any suggestion would be nice tyvm
  15. Jul 21, 2016 at 12:34 PM
    koditten
    Kirk
    Central Michigan
    Where is your weight distributing hitch? This is a requirement.
    Deathbysnusnu likes this.
  16. Jul 21, 2016 at 12:38 PM
    thumper72
    Jon
    Ogden Utah
    In the manual it says not to use one as it can cause frame damage.. so I didn't get one for that reason as I don't want to cause damage...I'm sure you can use one but I didn't want to chance it ...
  17. Jul 21, 2016 at 12:44 PM
    koditten
    Kirk
    Central Michigan
    Then you have to spring for air bags, then.
  18. Jul 21, 2016 at 12:54 PM
    koditten
    Kirk
    Central Michigan
    I just can't imagine towing a trailer without a WDH. Does it say not use one in our trucks manual or is it for the camper?
    Regardless, installing a WDH or air bags, pretty close to same money. The hitch will be the fastest. The air bags won't interfere with the regular suspension once you deflate them.
  19. Jul 21, 2016 at 1:12 PM
    devinzz1
    devin
    2023 aclb trd or mt
    With the retros only the drivers side headlight plug is used. I simply plugged into the unused passenger side connector. Took about 30 seconds. Its fused for 10 amps.
    BYJOSHCOOK likes this.
  20. Jul 21, 2016 at 1:21 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I've never though of a WDH on a first gen because they aren't really capable of towing much anyway at least safely. What do you tow that you use one with? I guess maybe with a really dense load like a bobcat or something it may be a good addition. Either way WDH is still nice to have I guess.
