  1. Aug 10, 2016 at 9:28 PM
    retroboy1989
    retroboy1989 Single Cab 4x4
    99 2.7L 5spd 4x4
    Not sure on ADD, but with manual hubs...As long as I am going in a straight line with no wheel slip, and the hubs are locked, it pops in at any speed. All it is doing is locking shafts together that are already moving at the same speed.
    Again, I am not sure how ADD works. I don't know how it gets the stationary rotating mass up to speed before it locks.
  2. Aug 10, 2016 at 9:29 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I pop the clutch out. But it isn't required.
  3. Aug 10, 2016 at 9:56 PM
    willie64
    willie64 Willie64
    willie64
    BEND OR
    (slowly becoming less than) Stock '03 3.4L 4x4 TRD SR5
    144 watt led lights on front 36 watts x2 led on the back, cb, Kenwood ham, icon 3" lift, 285/75/16 Fierce Attitude tires, JoeZilla sliders, 4x innovation rear bumper, ARB front bumper. Snorkel. On the workbench: more stuff I can't afford.
    Well, I had all the front end taken apart when I noticed I was sent the wrong gear kit. Started greasing the driveline and looking around while waiting. I had a day to 'waste' waiting on the right kit. Wasn't much work to loosen some parts and squirt some grease in. Made a nice list of other upgrades while I was at it.
  4. Aug 10, 2016 at 10:01 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    Stereos dont come in "sizes". Either single or double din (thats the standard anyways). Either will fit with matching hard/trim.
  5. Aug 10, 2016 at 10:05 PM
    devinzz1
    devin
    2023 aclb trd or mt
    My truck wont let you engage 4x4 unless completely stopped. If its moving even slightly the light will flash and beeper comes on.
  6. Aug 10, 2016 at 10:10 PM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    alot still need done
    I never did trust those on the fly 4wd I always stop and engage it
  7. Aug 10, 2016 at 10:11 PM
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
    Why? Even 4hi?
  8. Aug 10, 2016 at 10:16 PM
    devinzz1
    devin
    2023 aclb trd or mt
    Push button 4x4 so no 2lo. Its always done it. The computer wont even let it try to engage unless stopped. You can disengage smoothly at any speed though.
  9. Aug 10, 2016 at 10:34 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    That's broken, you should be able to engage at any time while moving under 55
  10. Aug 10, 2016 at 10:39 PM
    devinzz1
    devin
    2023 aclb trd or mt
    Oh well. As long as it engages when i need it.
  11. Aug 10, 2016 at 10:51 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    My dollar is on the CVs being the root cause of you vibe. Most likely, too high of an axle angle.
  12. Aug 10, 2016 at 10:52 PM
    Cohbsteq
    Cohbsteq Hood Rat
    Jacob
    SL,UT
    02 Supercharged 4x4
    Pretty much stock with some crap welded to it.
    I'll be swapping it out soon as a precaution and getting another rebalance soon, so I can check both of them off the possible cause list
  13. Aug 10, 2016 at 10:56 PM
    snowboard704
    snowboard704 Well-Known Member
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    Alignment today, think it's the first time in awhile it hasn't pulled one way or the othe... Feels weird almost :rofl:
    Carrier bearing tomorrow hopefully to fix my 65-70 mph pulsing vibration :annoyed:
  14. Aug 10, 2016 at 11:01 PM
    Digiratus
    Roaming the PNW
    The RedHead
    The first time I lifted the redhead, I had the adjustable COs set with too much pre-load. This caused a high speed vibe in the 55-60 mph area. Almost ruined the fins on the cv boots before I lowered it some, so the fins no longer touched. It had worn a groove on both inner boots. Lowering it to ~2.75" of lift stopped the vibe and saved the boots. I got another 60K out of the boots before replacing both axles with 'new' CVJs.
  15. Aug 10, 2016 at 11:16 PM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    Had one. Weld rusted out and it wasn't worth it to me to get it put back on. Just went with an entire replacement for like $200.
    It was alright, but v6s will never sound deep and throaty like a v8 will. I like not alerting people within 1/4 mile that I'm driving.
  16. Aug 10, 2016 at 11:33 PM
    MatthewMay1
    MatthewMay1 I'm an amateur professional.
    Matthew
    Lone Star Republic
    Supercharged '01 TRD
    I used an adjustable hood hinge mount from FireStik. It doesn't even need to be bolted in. It fits perfectly beneath the tailgate latch catch. This is the only picture I have on my computer right now. Unbolt 2 bolts on the latch catch, place the mount behind it and bolt the catch back in place. It'll hold it nicely. I can get a better picture with my phone tomorrow if you need to see what I'm talking about.
    This is a very good and easy option too.
    DO ETTTT
    Exactly what I have. Fits fine behind the stock wheels with a little trimming of the dust shield.
    All double din units will be the same size. Here's mine.
    Yee
    Why? The whole point is so you don't have to stop...
  17. Aug 10, 2016 at 11:37 PM
    MatthewMay1
    Matthew
    Lone Star Republic
    I think the issue might be that I can't get a good seal on the bottom of the grommet. I've been having a terrible time trying to wedge my finger down there without making a mess with the silicone
  18. Aug 11, 2016 at 4:40 AM
    sente3
    sente3 -
    North Jersey
    '04 Xtracab 4x4 V6 5-Speed TRD SR5
    Sliders, rear bumper, front skid, lifted
    I have the same head unit in my truck. Overall, it's nice. Built quality is good and it has a good array of options. I like that it doesn't just have a dimming feature, you can set the lights to turn off entirely when buttons aren't being pressed. Great at night. But tell me this. Do find this thing to be the least intuitive system? Everything is hard to figure out. The software experience is not good.
  19. Aug 11, 2016 at 7:09 AM
    02TacoSteve
    02TacoSteve New Member
    2002 5spd Xcab
    Not much
    New here, I've had mine just over a year now.
    Did the diff breather extension this morning.
    This past Sunday I went offroading for the first time(in a truck anyway). Didn't do anything too challenging since I went alone and I didn't have the breather done. Didn't take any pics but below is a pic of it at work Monday afterwards. Might go again this weekend20160808_092301.jpg
    Boerseun, jubei, ronoc and 1 other person like this.
  20. Aug 11, 2016 at 9:50 AM
    MatthewMay1
    Matthew
    Lone Star Republic
    Good god I hate the UI on that thing. I would not recommend it to anyone. It pisses me off not having 6 preset buttons. You have to click through all of them to find the station you want
