  1. Aug 11, 2016 at 3:56 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    I don't think so
  2. Aug 11, 2016 at 4:24 PM
    JKO1998
    Utah
    Holy cow dude, I bought em used, almost 100% sure they are extended travel
  3. Aug 11, 2016 at 4:27 PM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
  4. Aug 11, 2016 at 4:29 PM
    JKO1998
    Utah
  5. Aug 11, 2016 at 4:32 PM
    Robmonster117
    Robmonster117 Well-Known Member
    Robert
    Gilroy
    02 ext. cab 4x4
    Truck parts
  6. Aug 11, 2016 at 4:34 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    "coilovers"
  7. Aug 11, 2016 at 4:44 PM
    JKO1998
    Utah
    Quote was accidental
  8. Aug 11, 2016 at 4:47 PM
    JdoubleD
    JdoubleD Member
    James
    98 extcab 3.4
    4 x 3.5 lift 33" 12.5 r16 TG front and rear bumper
    Made some scrap metal. . . Ditched the jenky nerf bars i folded last weekend and installed my new rear bumper. . . Lookin for some legit sliders, any recommendations?
  9. Aug 11, 2016 at 5:44 PM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    I quoted you saying he would need UCAs before a bumper because of extended travel. That may have been the confusion
  10. Aug 11, 2016 at 6:56 PM
    Cohbsteq
    Cohbsteq Hood Rat
    Jacob
    SL,UT
    02 Supercharged 4x4
    Pretty much stock with some crap welded to it.
    I've been really happy with my 4xinnovation sliders.
    getz411, m3bassman and Speedytech7 like this.
  11. Aug 11, 2016 at 7:28 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Well... lucky me got to spend my first day off in a long while pulling trees out with the truck. City gave us special access to a fire road that runs behind the house so we could get a tree out of a back yard, so at least that was fun. 4low did the trick all three times with little effort.
    macadood, sente3, malburg114 and 5 others like this.
  12. Aug 11, 2016 at 7:31 PM
    Adventurer_Alex
    Adventurer_Alex Generic mall crawler
    Alex
    AZ
    2013 Nissan XTERRA
    A while back somebody mentioned someplace that analyzed used oil, anybody remember where or who?
  13. Aug 11, 2016 at 7:35 PM
    Sloth
    Sloth Baby Ruth?
    Seth
    Democratic Peoples Republik of Massachusetts
    07 FJ Cruiser, 98 Landcruiser
    Stuff
    Blackstone
  14. Aug 11, 2016 at 7:36 PM
    Adventurer_Alex
    Alex
    AZ
    2013 Nissan XTERRA
    Thank-you!
  15. Aug 11, 2016 at 7:54 PM
    Sloth
    Sloth Baby Ruth?
    Seth
    Stuff
    I think CBI are the only true bolt on. I had BAMF bolt ons on my 1st gen and they were great, but required drilling. All others will require welding.
    There are tons of options, BAMF, CBI, Trail gear, all pro, relentless, 4x4 innovations, demello, brute force, etc..
    They will all work well, and almost all of them can get you basically the same options.
  16. Aug 11, 2016 at 10:07 PM
    LogCabins
    LogCabins Well-Known Member
    Robert
    Oahu
    99 SR5 3.4L 4WD
    Wow....amazing that Palm survives the winter
  17. Aug 11, 2016 at 10:10 PM
    Speedytech7
    There are only a couple types hearty enough to make it here in Washington (none of the really good looking ones). I'm not sure how this one does cause it's my neighbor's. Seems to hold up well though, been there a long time.
  18. Aug 12, 2016 at 1:56 AM
    UtahTacoma02
    UtahTacoma02 Well-Known Member
    Dave
    SLC
    02 Tacoma Double cab TRD Limited
    ARB front bumper, Old Man Emu suspension, on board air compressor, on board hot water converter, cb radio, safari snorkel, warn 8K lb. winch, AP rock slidders/rear bumper, gray wire mod
    Haha, I know right. My stock 03 had no issues with anything. Once you lift it everything goes haywire, haha. My vibration comes on and off at different speeds. 0-5, 20-30, and 55-70 all vibrate from the drive shaft. The vibrations aren't too bad just annoying and more noticeable on really smooth roads like Legacy Hwy. I think the improperly balanced wheels and bad LCA bushings are noticeable at higher speeds. I just replaced my cv axel boot that was ripped. It is a lot of work compared to just swapping out a whole new cv axel. But it came to spending 20 for a new boot or 125 for a whole new cv axel. I would check your tie rods are still being held on with all 4 bolts one each side if you are hearing a clunk or yeah it could be the cv gone bad. I'm always under my truck checking for new leaks and that things look normal.
  19. Aug 12, 2016 at 6:25 AM
    KeptOnChooglin
    KeptOnChooglin Well-Known Member
    Phil
    Houston, TX
    2003 Crew Cab PreRunner L4 Auto
    How did that work for the mechanism? I assume you are talking about the retention/roll up when you release it?
    I was under the impression that whatever was doing the auto roll-up was decaying with usage and wear, not getting clogged up or in need of lubrication. My approach was going to be to swap the rear driver side for the driver belt (yeah, double cab world problems), but if it just needs some maintenance ....
  20. Aug 12, 2016 at 6:27 AM
    KeptOnChooglin
    Phil
    Houston, TX
    So in other words, when you went looking for a Taco, you went looking for one that had been "rode hard and put up wet?"
