  1. Aug 15, 2016 at 11:41 AM
    2002Tacoma4x4
    2002Tacoma4x4 TRD 4x4 double cab
    C K
    Limited Edition Double Cab TRD off road 4WD
    Bumper was hit backing up so chrome paint pop up and 1st owner didn't take care.
    Now looking for solutions on how to fix it to prevent a search for another bumper?
    My none-experience plan is:
    1. remove all rusted chrome as much possible to clean metal
    2. then rust encapsurator chasis saver paint black
    3. fill up and level with J&B as filler.
    4. then black rustoleom bedliner paint the square base area around.
    Can you share any better ideas ?
  2. Aug 15, 2016 at 11:51 AM
    Robmonster117
    Robmonster117 Well-Known Member
    Robert
    Gilroy
    02 ext. cab 4x4
    Truck parts
    Amazon has a bunch of different kinds, thats where I got this one. The mounting brackets are flimsy so I made my own, and I got better hose than what came with it.
    QMEDJoe[QUOTED] likes this.
  3. Aug 15, 2016 at 12:06 PM
    QMEDJoe
    QMEDJoe Proverbs 3:5-6
    Joe
    Columbus Grove, Ohio
    2003 Tacoma, V6, 5 speed, 4x4.
    Fox 2.0 Coilovers in the front and Fox 2.0’s in the rear, Total Chaos UCA’s, Al-lpro expo leafs, K&N cold air intake, TRD headers,Magnaflow catback exhaust,URD short throw shifter, switched out my 60/40 bench seat for some Tacoma Limited seats, Replaced the vinyl shift boot for a leather one, completely soundproofed the cab w/ Frost King. Replaced stock radio with a Pioneer AVH series head unit. Focal component system w/a 10" sub powered by 2 Alpine amps. Weathertech floor mats. Line-X'd the bed. SCS Ray 10’s, Installed an A.R.E. MX series camper shell. All-Pro Apex front bumper w/ All-Pro skid plates all the way back to the Trans. Low Range fuel skid plate.
    Thanks! I'll check em out. Can't wait to have my own shop so I can fabricate stuff for the Taco at home.
  4. Aug 15, 2016 at 12:11 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    Having a problem with my passenger front window today, it will roll down and up but only a little at a time, it acts like there's a capacitor in the assembly that has to charge up to keep the motor moving.
    It'll move some and then stop, if I let it sit for a minute or two it'll move some more.
    None of the connections that I found are loose and the voltage on the battery is good.
  5. Aug 15, 2016 at 12:15 PM
    eon_blue
    Azusa, CA
    Installed a Smittybilt compact Defender roof rack on my truck over the weekend :dancingbacon:
    Had to drill 8 half inch holes into the sheet metal of the roof to mount the well-nuts that attach to the mounting brackets...talk about nerve wracking.
    Screen Shot 2016-08-15 at 12.13.34 PM.jpg Screen Shot 2016-08-15 at 12.13.43 PM.jpg
  6. Aug 15, 2016 at 12:50 PM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    I've done 10 into mine....:anonymous:
    eon_blue[QUOTED] likes this.
  7. Aug 15, 2016 at 12:53 PM
    eon_blue
    Azusa, CA
    It's a terrifying feel right? lol. Especially when you go to line the rack up to the holes you just drilled, praying it works.
    I messed up one of the 8 holes though, when I was drilling I didn't keep a tight grip on the drill for a split second and the 1/2" bit caught on the metal and twisted the drill in my hand, screwing up the hole :( My heart dropped when it happened. Fortunately it wasn't TOO bad, I was able to trim the haggard edges a bit and smooth it out. I sealed up every hole with silicone around the well nuts just to be sure they don't let any water leak through, that's the only one I'm really worried about though...
  8. Aug 15, 2016 at 12:58 PM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    It was but after you get one down there no going back. We lined up my rack used a punch and a marker to get the hole started. Plus my rack can slide for adjustments so as long as the hole was in the slot I was good. It looks dead on to me tho
  9. Aug 15, 2016 at 1:09 PM
    vonellis
    vonellis Well-Known Member
    04 DLBC x4 S/C 97 2X 04 DBLC 4X S/C
    Some and some more
    Need quick help here. Will a 2004 tundra rear break line work worth a 2004 Tacoma ? My stock line is looking a tight luckily it didn't break.image.jpg
  10. Aug 15, 2016 at 1:24 PM
    batcat420
    batcat420 I'm a Blue Ribbon man.
    Scott
    Atlanta
    2022 Lunar Rock SR5 Trail Edition
    Can anyone show me where the coolant temp sensor is located in the 2.7L engines, please? Google wasn't much help.
  11. Aug 15, 2016 at 2:04 PM
    MatthewMay1
    MatthewMay1 I'm an amateur professional.
    Matthew
    Lone Star Republic
    Supercharged '01 TRD
    I have seen so many bumpers bent up and rusted in that exact spot. Mine is as well.....I just don't care enough to do anything about it. It's an old truck
  12. Aug 15, 2016 at 2:13 PM
    pupdrew
    pupdrew Well-Known Member
    Andrew
    805 SLO- 951 Riverside
    04 4x4 Dbl Cab TRD
    working on it!
    originally I was gunna go with 2 10's (which is possible) but the cone of the sub would hit the back of the seat and possibly tear it. so I went with 4 pioneer 150 rms subs across the whole back behind the rear seats . all together pushing a little over 700 watts. I can post pics when I get home
  13. Aug 15, 2016 at 2:25 PM
    Pandito
    Pandito Well-Known Member
    Frankie
    San Francisco, CA / Modesto, CA
    01 PreRunner SR5 TRD DCSB
    Major late to the camper party, but I FINALLY found (and instantly bought upon inspection) a SnugTop camper for my boy. Fortuitously enough, the color was a perfect match, condition was VERY good, has the roof racks, carpet interior is near perfect, AND it came with the keys. Just needs an adjustment on one striker as well as tightening of the latch release mechanism. It was also missing three of the interior tie-down hooks on the passenger side but still had one good one. Purchased two deep-C clamps from a local dealer and it works perfect. This thing ain't flying off any time soon. Now to wire the brake and interior lights!
    Here he is, before it was washed.
    And a close-up. Looks even better when washed :D
    JKU3000 likes this.
  14. Aug 15, 2016 at 2:28 PM
    Pandito
    Frankie
    Sounds like you know your audio. In that case, a little Q for you: when I bought my ride, it had a lot of audio stuff already set up but I'm still trying to figure out how everything correlates to one another and if I should be aware of anything. Mind lending a little advice?
  15. Aug 15, 2016 at 2:34 PM
    pupdrew
    Andrew
    04 4x4 Dbl Cab TRD
    working on it!
    what do you have ?
  16. Aug 15, 2016 at 2:39 PM
    Pandito
    Frankie
    I'll see if my father can get a pic for me. Install is pretty damn clean, but I'd just like to confirm that my understanding of how it's set up is correct.
    pupdrew[QUOTED] likes this.
  17. Aug 15, 2016 at 3:10 PM
    WildLand
    WildLand Does Ursus arctos defecate in deciduous forest?
    Josh
    NM
    16T4RSR54WD
    Is your bug shield color matched? If so can I see a picture of your truck head on?
  18. Aug 15, 2016 at 3:19 PM
    pupdrew
    Andrew
    04 4x4 Dbl Cab TRD
    working on it!
    rngr, jjsul, JKU3000 and 2 others like this.
  19. Aug 15, 2016 at 3:21 PM
    pupdrew
    Andrew
    04 4x4 Dbl Cab TRD
    working on it!
    do you have
    stereo
    subs
    amp
    speakers
    etc
  20. Aug 15, 2016 at 3:33 PM
    Pandito
    Frankie
    No sub, but it's wired (I can see the wire sticking out from under the seat). If memory serves, there are two amps (maybe one pre-amp and one amp). Honestly, I can't remember what's back there but am working on getting pics. Stereo is a Pioneer DEH-X9600BHS (acquired by me). I haven't removed the door panels yet, but it's possible the speakers may also be aftermarket; if not, still stock. I actually just need to get myself time to put some Dynamat into the doors.
