  1. Aug 18, 2016 at 4:17 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Mm how much would you guys say a shop would charge to change front wheel bearings (think that's what they are), and I guess lower balljoints cause you know.
  2. Aug 18, 2016 at 4:19 PM
    LogCabins
    LogCabins Well-Known Member
    Robert
    Oahu
    99 SR5 3.4L 4WD
    Change the LBJs yourself it's pretty easy....then take the spindle into a machine shop and have them press out/in your new bearings....save yourself some $$$$$
    jubei and Robmonster117 like this.
  3. Aug 18, 2016 at 4:20 PM
    Robmonster117
    Robmonster117 Well-Known Member
    Robert
    Gilroy
    02 ext. cab 4x4
    Truck parts
    Take your spindles off yourselve and youll save 6-700 in man hours. I found a machine shop that pressed my bearings in for 600 with Parts included. Do the ball joints your self. Super easy
    ^edit: he beat me to it
    LogCabins likes this.
  4. Aug 18, 2016 at 4:22 PM
    LogCabins
    Robert
    Oahu
    99 SR5 3.4L 4WD
    It's a "Robert" thing:rofl:
    And it cost $600 to press bearings?
    Robmonster117[QUOTED] likes this.
  5. Aug 18, 2016 at 4:24 PM
    Robmonster117
    Robert
    Gilroy
    02 ext. cab 4x4
    Truck parts
    Parts and labor yea. Our bearing are notoriously crappy to deal with. Got turned away by 4 other shops
  6. Aug 18, 2016 at 4:25 PM
    LogCabins
    Robert
    Oahu
    99 SR5 3.4L 4WD
    Gotcha ......understandable
  7. Aug 18, 2016 at 4:26 PM
    JKO1998
    Utah
    Man I was think LBJ would be not very much, like 200$...
  8. Aug 18, 2016 at 4:39 PM
    Robmonster117
    Robert
    Gilroy
    02 ext. cab 4x4
    Truck parts
    Oh my no. Sorry that wont even cover of the cost of the bearings and seals...
    Sorry for being negative nancy
  9. Aug 18, 2016 at 4:43 PM
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
    At least he's got a buttfuck of apples.
    alee891, jubei and devinzz1 like this.
  10. Aug 18, 2016 at 4:54 PM
    JKO1998
    Utah
    Don't know if positivity or
  11. Aug 18, 2016 at 6:10 PM
    FirstGen Jer
    FirstGen Jer Well-Known Member
    Jeromey
    big bear lake, CA / lake havasu, AZ
    1999 toyota tacoma 3.4l v6 sr5 4x4
    So are you sitting "level" now ;)
  12. Aug 18, 2016 at 6:29 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Goddamn really? For both sides or just one?
  13. Aug 18, 2016 at 6:30 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    What makes you think the wheel bearings are bad? 1st gens have massive WBs and are not prone to fail. Both going bad is even more rare.
  14. Aug 18, 2016 at 6:32 PM
    koditten
    Kirk
    Central Michigan
    If a shop has a strong enough press, the fee should not be more than $75 per side.
    $600 and you did the spindle removal and install? You got bent over.
    Holy schmidt likes this.
  15. Aug 18, 2016 at 6:35 PM
    koditten
    Kirk
    Central Michigan
    You can get WBs for less than $100 each with seal.
  16. Aug 18, 2016 at 6:36 PM
    koditten
    Kirk
    Central Michigan
    Hint:
    A bad carrier bearing will make you think you have a bad wb.
  17. Aug 18, 2016 at 7:14 PM
    Robmonster117
    Robert
    Gilroy
    02 ext. cab 4x4
    Truck parts
    I forgot I got a new hub assembly for one side so that added a little more to my price but you might be right maybe I did :boom:.Idk I got turned away by every other shop around. And the stealership wanted even more. And all they do is give it to a local machine shop to do, so I just tried to cut out the middle man. Oh well whats done is done. Hopefully I never have to do it again.
  18. Aug 18, 2016 at 7:15 PM
    Robmonster117
    Robert
    Gilroy
    02 ext. cab 4x4
    Truck parts
    Yea both sides. I forgot one side did get a new hub assemby but yea ir sucked pretty bad.
  19. Aug 18, 2016 at 7:17 PM
    JKO1998
    Utah
    Just seems like there's a constant hum, kinda hard to explain.
    Don't they make a drop kit for those? Could be it now that I think about it more.
    Heck honestly it didn't look like it lowered it too much. Probably did though.
  20. Aug 18, 2016 at 7:28 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    You get the hum after installing leafs?
