  1. Aug 22, 2016 at 6:45 AM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    How is the butt dyno? Any notice in sound?
  2. Aug 22, 2016 at 7:08 AM
    TooMuchToDo
    TooMuchToDo Well-Known Member
    2002 Gold Tacoma XtraCab with 192k
    ...we'll get there.
  3. Aug 22, 2016 at 9:27 AM
    Arman Bagdasarov
    Arman Bagdasarov armbag
    2001 4x4 Tacoma
    Camburg UCA, King coil overs, Fox Shox, Deaver springs, BAMF sliders & LCA Skids, Relentless Skids. Lights on lights on lights
    So if you don't mind me asking, how much did it all end up costing you? Did you buy a new sc?
  4. Aug 22, 2016 at 10:11 AM
    Jarob11
    Jarob11 Well-Known Member
    Hilo/Tacoma/Evanston
    99 Taco Limited
    Badlands custom frt winch mount bumper. badlands RR bumper w/ spare swing out, jerry can holder. Leer Camper shell. Royal Purple synthetics. Baja fender flares. Entire truck rhino lined. 31's. Custom sound system. More to come.
    another question for the all knowing 1st genners..anyone have a part number for the GM alternator people are swapping to?? my battery light keeps coming on so I'm thinking it's time. Might as well step up in power since the dual battery set up is next on my list. one day I'll get enough time to post some photos. I've been a busy dude, but here's a quick update. newly installed= Bilstiens all around with OME medium springs for lift up front & dakar leafs w/ greasable shackles in the rear. then the wheel got ripped off due to ball joint failure which led to, new ball joints 1 upper & both lowers. used OEM because stuffing the wheel under the truck is no bueno. only one upper because uniball uca's are inbound and the other upper was good. oh and a new cv shaft since the old one didn't want stretch to under the cab with the wheel and knuckle as it all came apart. then i threw some 33 10.50's under it. with the new suspension & tires she rides 100% better. oh and of course a pair of shift knobs, got the power inverter put in & wired and the CB all hooked up.
    Adventurer_Alex and TooMuchToDo like this.
  5. Aug 22, 2016 at 10:44 AM
    fiziks
    fiziks Well-Known Member
    Isaac
    El Paso TX
    01 DC Prerunner 4x4 5pd Conversion
    5 sp 4x4 conversion, OME lift, SCS F5s
    http://www.expeditionportal.com/forum/threads/91996-Upgraded-alternator-for-the-5vz-fe-(-02-Tacoma)
    looks like its the GM CS-144
  6. Aug 22, 2016 at 11:03 AM
    Madjik_Man
    Colorado Front Range
    Threw a P0120 code. Throttle Position Sensor.
    The intake needs a serious douching so I'm hoping a cleaning of the MAF, throttle body and IAC takes care of it.
  7. Aug 22, 2016 at 11:14 AM
    520YOTA
    520YOTA Well-Known Member
    Robert
    Tucson
    '97 SAS 4Runner
    Butt dyno definitely noticed a difference. Better pull, cool swoosh sound, and no longer thethe *tick* tick * tick* of the cracked stocker. It was a solid $150 spent [found on craigslist].
  8. Aug 22, 2016 at 11:17 AM
    OneWheelPeel
    OneWheelPeel Well-Known Member
    Phoenix, AZ
    Now a member of the "Clutch pedal goes to floor" owners club.
  9. Aug 22, 2016 at 11:47 AM
    Madjik_Man
    Soon to be a member of the "new master cylinder" owners club.
    TooMuchToDo likes this.
  10. Aug 22, 2016 at 12:10 PM
    quetzal
    quetzal Well-Known Member
    Mario
    Long Beach, CA
    '02 XtraCab SR5 TRD 4x4 5spd
    All-Pro UCAs, King 2.5 C/Os, All-Pro Expo Leafs, Bilstein 10" Shocks
    Truck runs smooth at idle, shifts real well, but as soon as I press the clutch it, it starts to whine. Does not do it all the time. Are these the signs of a throw out bearing going bad?
  11. Aug 22, 2016 at 12:53 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Is there a certain wiring harness that's better than others? (I joined the lightbar club) I have the switch already.
    malburg114 likes this.
  12. Aug 22, 2016 at 1:00 PM
    FirstGen Jer
    FirstGen Jer Well-Known Member
    Jeromey
    big bear lake, CA / lake havasu, AZ
    1999 toyota tacoma 3.4l v6 sr5 4x4
    @eon_blue just replaced his. He might have some experience for ya.
    quetzal[QUOTED] likes this.
  13. Aug 22, 2016 at 1:04 PM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Thought you were hardcore selling?
    jubei, m3bassman and FirstGen Jer like this.
  14. Aug 22, 2016 at 1:06 PM
    JKO1998
    Utah
    Apparently you need to catch up with the times
  15. Aug 22, 2016 at 1:15 PM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    alot still need done
    That moment when you buy a 2.5" diameter exhaust pipe and it's only 2.5" on one side and 2.25" on the other. Wtf napa
  16. Aug 22, 2016 at 1:17 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    @Digiratus
  17. Aug 22, 2016 at 1:18 PM
    eon_blue
    Azusa, CA
    edit: sorry, I just read @quetzals post more closely and he says it starts to whine when the clutch is pressed, not before. Mine was doing it before and then went silent with the clutch pressed. Might be a bad throwout bearing but I'm leaning toward a cracked flywheel instead. Either way I bet it will be recommended to just replace the entire clutch assembly
    100% bad throwout bearing. Mine chirped like crickets real bad but went silent with the clutch even lightly pressed. Ive heard that a whine is also a sign of either the TOB or a cracked flywheel. Either way, its best to just replace the entire clutch assembly since it all has to come out anyway. I went with a Comepetition Stage 2 clutch kit from URD, love it so far.
    FWIW, I had my TOB chirping for a few months before I got around to doing it. Toyota told me it's basically a time bomb with no timer when it starts to go bad. Could continue to last another year or it could leave you stranded tomorrow.
  18. Aug 22, 2016 at 1:18 PM
    Speedytech7
    I have that lovely tick tick as well. Sounds like a motorcycle going up hills, gotta replace mine, maybe next paycheck.
  19. Aug 22, 2016 at 1:41 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Awesome find
    520YOTA[QUOTED] likes this.
  20. Aug 22, 2016 at 1:55 PM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Sorry I lost track after how many times you change your mind :brianr:
