  1. Sep 8, 2016 at 7:50 AM
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    That's how mine is. One piece.
  2. Sep 8, 2016 at 8:36 AM
    jubei
    jubei would rather be doing something else
    NoCo
    White 2002 XC TRD and Yellow 1971 JEEP CJ5
    Stuff. Also things.
    Will do, Mike! Is your speedo reading fast or slow right now?
    I would think so too, but I'm more than a little overgeared with 5.29s. But that's exactly where I wanted to be. This truck is worlds better off the line, even with the added rotating mass of the 35s.
    I'm no expert, and I don't pretend to be, but I'm guessing that is the issue. Roughly speaking, a 4.7 gear set would put me right back to factory performance, but of course you can only get 4.88, which is slightly overgeared, and would cause the speedo to be slightly off by the same percentage. 5.29s would just make that percentage larger.
    Again, that's just what 'seems' plausible to me.
  3. Sep 8, 2016 at 8:44 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    It's reading slow. So 65 on the speedo means I am doing 70. I think... it's been a while since I've driven it with the new DD lol
    jubei likes this.
  4. Sep 8, 2016 at 8:45 AM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    This. Think about it in percentages. (rounded)
    I went from 4.10s to 4.88s, that's a 19% difference.
    I went from 31" tires to 33" tires, that's a 6.5% difference.
    Speedo will read 19% higher because of the gears, and 6.5% lower because of the tires: net of 12.5%
    Stock speedo gear is a 30 tooth, times 112.5%, get's us a 33.75 tooth, but 33 is the biggest Toyota makes.
  5. Sep 8, 2016 at 9:09 AM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
  6. Sep 8, 2016 at 9:13 AM
    wildfyr3
    wildfyr3 KEØGLC
    Forrest
    Eagan, MN
    2000 xtracab 2.7L manual
    DR coilovers Dakar Leaves Icon rear shocks BFG 33x10.5x15 KM2 Trail Gear front bumper Relentless fab rear bumper DIY sliders
    Sorry, I'm gonna get a little pedantic, hopefully not dickish.
    You can't subtract ratios, they're multiplied. The gears cause a 19% increase in revs (or 119% revs) while the tires decrease revs, the inverse, so 31/33 = 93.93%, not 106.5%. Multiply those suckers 1.190*0.939=1.117 (11.7% increase).
    Check out this gear ratio calculator to corroborate the point.
    http://www.grimmjeeper.com/gears.html
    None of this really amounts to much in our situation, seeing as the difference of 0.8% equates to....bupkis (0.5mph difference @ 70mph). Just an FYI, because for instance my total gear ratio from trans/tcase/rear axle would be 38.72 being multiplied, not 10.53 from being added which is a lot bigger of a deal than in our case.
  7. Sep 8, 2016 at 9:16 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    This ^^^
    Larger tires lowers the indicated speed. A regear raises the indicated speed.
    FWIW, I am on 33s (33x10.5r15), regeared to 4.88s and have the 33 tooth speedo gear. With the auto trans, at 70 mph (GPS), the tach reads 2500 rpms, and the speedo reads 72 mph.
    Silver02Taco and jubei like this.
  8. Sep 8, 2016 at 9:26 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
  9. Sep 8, 2016 at 9:26 AM
    Squeaky Penguin
    Brett
    Close enough. I'm an accountant, not an engineer, so I normally just plug numbers. :p
    wildfyr3[QUOTED] likes this.
  10. Sep 8, 2016 at 9:26 AM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    I hate math!!!
    WinSlow939 and FirstGen Jer like this.
  11. Sep 8, 2016 at 9:35 AM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    I see. I just assumed everone went with 5.29s because it would match the factory ratio.
  12. Sep 8, 2016 at 9:38 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    No 5.29's are quite a bit overgeared. I plan on going 5.29's because I am hoping to avoid a crawl box since I am a manual.
    jubei likes this.
  13. Sep 8, 2016 at 9:38 AM
    jubei
    NoCo
    Stuff. Also things.
    Good stuff, fellas! That's pretty much what I thought.
    WARNING: Nerding out to follow...
    I just used my stock tire size (30.5, I think) and my new size, 35.
    35/30.5 = 1.15
    Stock gears are 4.1, so
    4.1 * 1.15. = 4.70 (ideally)
    Closest gear set is 4.88, and I'm running 5.29, so
    4.88/4.7 = 1.04, or a +4% error with 35s
    5.29/4.7 = 1.13, or a +13% error with 35s
    All assuming the stock speedo gear is used, of course. Stock speedo gear is a 30 tooth, so to mitigate that 13% error,
    30*1.13 = 33.76 tooth, ideally. 33 tooth actual.
    33/30 = 1.1, which is only a 2.72% difference from ideal case to actual.
    So using a 33 tooth with 5.29s and 35s should get me pretty close, I think.
    Or my math is bogus and I'm completely full of shit.
  14. Sep 8, 2016 at 9:44 AM
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    I don't know math at all.
    However, you need the 33 tooth.
    jubei[QUOTED] likes this.
  15. Sep 8, 2016 at 9:46 AM
    Squeaky Penguin
    Brett
    Guess and check method works well too.
  16. Sep 8, 2016 at 9:51 AM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
  17. Sep 8, 2016 at 9:58 AM
    jubei
    NoCo
    Stuff. Also things.
    I don't get to use my math skillz much anymore, so I saw the opportunity to need out and took it! Thanks for your help, man!
    Did your get your speedo gear from the dealership?
    Yep, I might as well just throw that thing in there and see what I get. Now I just need to get a GPS...
    Thanks, Tim! I'll check that out tonight!
  18. Sep 8, 2016 at 10:06 AM
    pittim
    Pennsyltucky
    Boujee Prius
    If you want to do the math check out the 2nd link I added. Since the TTORA page says each tooth is "about 3%" I guess that isn't too accurate of a method either haha.
    But the 33t speedo gear is what will get you closest with 35s/5.29s. Pt# 33403-39415
    jubei likes this.
  19. Sep 8, 2016 at 10:08 AM
    devinzz1
    devin
    2023 aclb trd or mt
    These are the kinda math problems we need in high schools!
  20. Sep 8, 2016 at 10:16 AM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Yes, just took a day to get it in. It might be local stock to the Denver dealers.
