  1. Sep 9, 2016 at 12:10 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    https://youtu.be/xlvJGunwQe4
    It's from a cold start and edited down over the course of 15mins or so.
    jjsul, wildfyr3[QUOTED] and sente3 like this.
  2. Sep 9, 2016 at 12:45 PM
    sente3
    sente3 -
    North Jersey
    '04 Xtracab 4x4 V6 5-Speed TRD SR5
    Sliders, rear bumper, front skid, lifted
    This sounds really nice.
  3. Sep 9, 2016 at 12:50 PM
    Speedytech7
    Thank you! :)
  4. Sep 9, 2016 at 12:52 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Tundra brakes showed up. Calipers are huge.
    UssMoGn, jjsul, jubei and 4 others like this.
  5. Sep 9, 2016 at 1:01 PM
    w:ll:s
    w:ll:s Well-Known Member
    Nashville, TN
    2001 Tacoma v6 4x4 SR5 - Imperial Jade
    sweet! Those are a direct bolt on, correct?
    Do you mind putting me on to where you purchased those? Thanks! :oldglory:
  6. Sep 9, 2016 at 1:06 PM
    Bobert14
    Bobert14 .
    It's nice to have a functional tailgate again.
    because_wumbo-truck likes this.
  7. Sep 9, 2016 at 1:32 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea direct bolt on. Although I'm going to a whole other level and doing a major brake overhaul. Large MC and new rear brake proportio ing valve and gettin rid of the abs.
    I got them off ebay. Callahan calipers. But I bought a different kit with the rotors and pads. Didn't want the drilled and slotted rotors that come with the Callahan kit.
    w:ll:s[QUOTED] likes this.
  8. Sep 9, 2016 at 1:53 PM
    OneWheelPeel
    OneWheelPeel Well-Known Member
    Phoenix, AZ
    First time hauling my bike I put a nice crease in my brand new (Taiwan) replacement tailgate...
  9. Sep 9, 2016 at 1:58 PM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    I believe they are on Amazon again
  10. Sep 9, 2016 at 1:58 PM
    w:ll:s
    Nashville, TN
    Thanks!
  11. Sep 9, 2016 at 2:00 PM
    wildfyr3
    wildfyr3 KEØGLC
    Forrest
    Eagan, MN
    2000 xtracab 2.7L manual
    DR coilovers Dakar Leaves Icon rear shocks BFG 33x10.5x15 KM2 Trail Gear front bumper Relentless fab rear bumper DIY sliders
    Here's what I got from a few random crappy clips I had laying around. And ya shut up my engine is cold, don't worry about it. It was winter. It's fine.
  12. Sep 9, 2016 at 2:33 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    Depending on what you're planning, you might run into the same issue I'm having.
    I upgraded to a dual diaphragm booster with 1-1/16" bore MC, both from a early tundra, to go with the 231mm calipers. Figured it's all from the same truck, should work right? Not exactly. Line pressure went way down, have to stand on them to lock it up. I may try a 1" MC from a pre-01 TRD to see if line pressure returns to a normal level.
  13. Sep 9, 2016 at 3:06 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    That makes no sense.
    Tundras come with a single diaphragm booster. Not a dual.
    Tundras mc is also 15/16s. Only t100s with the heavy duty 1ton package came with a 1-1/16" MC.
    You kinda did a down grade switching out the booster and mc. Keep the tacoma boost and put a t100 mc in. Should change.
    Or sit back and wait for me to do it and see if it works haha
  14. Sep 9, 2016 at 3:25 PM
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
    Ah, sorry - T100 booster and MC, not Tundra.
    You want the increased vacuum assist from the dual diaphragm booster for the larger MC, right?
  15. Sep 9, 2016 at 3:34 PM
    Taco Addiction
    Taco Addiction We found Jimmy
    Houston, TX
    2004 Black TRD Offroad
    Kings, SCS Wheels and other mall crawling crap
    SCS F5 wheels arrived!! :dancingbacon:
    Relentless Tailgate Reinforcement Arrived!! :broccoli:
    Relentless Hi Lift Bar getting installed tomorrow!! :kona:
    UssMoGn, Silver02Taco, jjsul and 3 others like this.
  16. Sep 9, 2016 at 3:53 PM
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
    Damn, any idea what it is? You gonna fix it up or just sell it?
  17. Sep 9, 2016 at 4:34 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Not sure. Odd to hear that though. Supposed to help a ton.
    Yea. I can't aford to fix both trucks. Where have you been?
    Idk yet.
  18. Sep 9, 2016 at 5:53 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Igor. Has a warped rotor. May as well upgrade. Can't fit on Frank due to 15" rim.
  19. Sep 9, 2016 at 6:34 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea. Just gonna make Igor more trail ready for trips with you and mike. Not worth taking Frank anymore either.
    Hmm..can't order the seal either I bet.
  20. Sep 9, 2016 at 7:17 PM
    CruisD64
    CruisD64 Well-Known Member
    Andrei
    Truckee, CA
    2003 Tacoma TRD 4x4
    Line-X, LED Gauges, Bluetooth Stereo, TracRac, OME 2.5 Lift, Relentless Fab rear bumper, Shrockworks front. Bleh. So much good stuff.
    Welded on the sliders that I bolted on yesterday. Was a pain in the ass because I was grounding incorrectly at first so some of the welds are not pretty. Turns out the rear spring hanger is a bad grounding location for frame welding. Funny thing happened though. Because of the bad ground the welds were popping and one of the molten pieces of steel hit my shirt and it caught fire. "OH SHIT OH SHIT OH SHIT!!!!". After I put it out I stood there and laughed for a couple of minutes... :)
    bowyer2002 and Taco Addiction like this.
