  1. Sep 19, 2016 at 6:05 PM
    WinSlow939
    WinSlow939 Road Salt Life
    Nate
    The Rock, Mass
    2002 with some '99 thrown in for fun
    All the Money I Have
    Man those wheels are :drool: :drool: :drool:
    Reminds me of stock FJ80 wheels, though SCS prolly does a much better wheel
    Are you going full Icon pack or just AAL?
  2. Sep 19, 2016 at 6:14 PM
    retroboy1989
    retroboy1989 Single Cab 4x4
    99 2.7L 5spd 4x4
    Light rubbing on 265/70r17. Stock.
  3. Sep 19, 2016 at 6:16 PM
    FirstGen Jer
    FirstGen Jer Well-Known Member
    Jeromey
    big bear lake, CA / lake havasu, AZ
    1999 toyota tacoma 3.4l v6 sr5 4x4
    Did they warranty it?
  4. Sep 19, 2016 at 6:29 PM
    WinSlow939
    Nate
    The Rock, Mass
    Thought Rack Doctor had lifetime warranty?
  5. Sep 19, 2016 at 6:56 PM
    Taco Addiction
    Taco Addiction We found Jimmy
    Houston, TX
    2004 Black TRD Offroad
    Kings, SCS Wheels and other mall crawling crap
    Thanks Nate, appreciate it. Yeah, they look so much better in person like everyone says. Even the wife loves them and that's saying something :)
    King coil overs up front, billies in the back, Icon AAL. I think that set up will do nicely for me. Kings are on backorder so just waiting for them to ship.
    WinSlow939[QUOTED] likes this.
  6. Sep 19, 2016 at 7:58 PM
    Captain Magma
    Captain Magma Well-Known Member
    Patrick
    Tucson, AZ
    2002 4wd DblCab
    Kings and desert pinstripes
    You need a snorkel
  7. Sep 19, 2016 at 8:38 PM
    Tacomang
    Tacomang Well-Known Member
    Norcal
    Trd Taco
    Ya then you can taco submarine
  8. Sep 19, 2016 at 8:50 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Go through the biggest puddles in the parking lot
  9. Sep 19, 2016 at 10:00 PM
    vonellis
    vonellis Well-Known Member
    04 DLBC x4 S/C 97 2X 04 DBLC 4X S/C
    Some and some more
    image.jpg Got this running today so I left the Tacoma in the drive way :bananadance:
  10. Sep 20, 2016 at 5:13 AM
    rynod337
    rynod337 Active Member
    Charlotte, NC
    2004 SR5 Tacoma Double Cab
    anybody ever had an issue with the emergency brake light coming on even though the emergency brake isnt engaged?
  11. Sep 20, 2016 at 5:17 AM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Just have to tighten up the e-brake cable, mine does the same thing just too lazy to do it
  12. Sep 20, 2016 at 5:23 AM
    WinSlow939
    Nate
    The Rock, Mass
    Check your brake fluid, if its not near the top the light will stay on too
    jubei and Captain Magma like this.
  13. Sep 20, 2016 at 5:58 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Did you find that if you put it in with the collar too far out it would lock up the axle? I tried to have the collar at the very edge so the seal would ride in the middle and the collar would make contact with the inside of the axle and lock it up. I had to settle for a not as centered line unfortunately. I also had to gap out the ABS ring separate from the collar so it would ride in the right spot too. Toyotas redesigned seals really make it more complicated than it needed to be.
    Don't count on Toyota doing it right either since they fucked up @Reh5108's but at least then its got a warranty.
    Reh5108 likes this.
  14. Sep 20, 2016 at 6:16 AM
    WinSlow939
    Nate
    The Rock, Mass
    I didn't find that out personally, but I def heard thats what can happen. And yes the new seal design makes it more complicated, I didn't end up with mine riding perfectly in the middle, just close enough I guess. The one weird trick I tried and seemed to work was flipping the last retainer around so the bevel faces towards the wheel and not the axle:
    That way you get more seal to retainer contact without it hitting the housing....theres a good writeup somewhere that was pretty convincing of this trick. I've got 500+ miles since the operation and everything is dry
  15. Sep 20, 2016 at 6:18 AM
    AZ4x4Taco
    AZ4x4Taco Well-Known Member
    Jeremy
    Tucson AZ
    01 4x4 TRD
    Cheap spacers and blocks, 33's, poor man upgrades.
  16. Sep 20, 2016 at 6:32 AM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Fuck :annoyed:
    I think I saw that on TTORA, if I could find the correct size pipe I'd probably try and "press" it myself then. Along with the concrete method but wrap my axle up like a mother fucker
  17. Sep 20, 2016 at 6:34 AM
    WinSlow939
    Nate
    The Rock, Mass
    I'll go meassure the one I got
    BYJOSHCOOK[QUOTED] likes this.
  18. Sep 20, 2016 at 6:42 AM
    WinSlow939
    Nate
    The Rock, Mass
    UssMoGn and BYJOSHCOOK like this.
  19. Sep 20, 2016 at 6:43 AM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    I'll be going to the store on Friday perhaps. Did you have to cut all that shit off or did the concrete method take it all off?
  20. Sep 20, 2016 at 6:46 AM
    WinSlow939
    Nate
    The Rock, Mass
    I cut it all, takes no time with angle grinder and small dremel too. The main little bitch is that snap ring though, get that out and you prolly could smack it all off
